Hello guys, here are my Nelson Pass F5 + Bride of Zen preamp.
Cases have two interchangeable versions: matt black or glossy white.
Label NELSON PASS lights up when switch on.
Small arrows show you the direction of motor volume pot (ALPS) with remote control.
Case are HiFi2000 with MDF handmade front panel.
The sound is amazing, thanks Nelson!
Bye
Delicious [emoji1303]
drpro,
Is that a soft-start board in there? Please note that the M2 starts up slowly and there is no turn on thump, so you probably don't need an additional soft-start with the M2.
Well executed build - congratulations!
Joined 2009
F5...not so pretty.
What R your thoughts on relative sound of these amps?
It's like with vine, everyone likes something else.
Seriously, they all sound very good. In general, classA has a tendency to have softer top, with heights less pronounced, while classAB is slightly sharper, maybe more sparkly on top, which some may preffer for rock music.
I do not use classA for woofers, all my systems are biamplified.
It's hard to run classA in summer all the time, there is danger of overheating something, so i ofter swap just a lm3886 amp there, and i am always surprised how good it sounds.
I am working on m2 now, plus few more aca, and goldmund clone...plenty fun to come.
I too tend to switch out for something cooler in the heat of summer. I run tubes (usually SE/class A) in the cooler seasons, then often switch to solid state/class D or class T in summer. We don't have air conditioning and with 90F + outside, I just don't want to run anything that warms up...at all. But I like to have Class A when I can.
- Pictures of your diy Pass amplifier
