Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
Founder of XSA-Labs
Joined 2012
With the 22V transformer, you get 26.4V plus U use CRCRCRC power supply. With the 3pc R you burn up some power also. I hope you not using any high-value resistors there to burn up more power. Your 25.6V is absolutely normal with your setup.
When you buy a transformer to regular Class A bias calculation(not talking about Alep X where the total bias is over 7A per channel) 22ACV x 1.2 under load =26.4V DC.
I am using 0.15R - ok so normal. My problem is that I have been using 1.4x and subtracting 3-4v for load. But 1.2x multiplier seems way to go for Class A. My CRCRCRC burns off 1.2v.
I recently bought a pair of 22VAC 300VA Anteks, hoping to get a solid 27vdc under load of 1.6amps. After the CRCRCRC, I am getting 25.6v. This is for a high output variant of the Alpha 20 that I am testing - just seeing if pushing higher voltage and increased cooling via CPU coolers and fans can work to boost power output.
Hi X
Antek supplier specifies output voltage under specific load current (not much data though) with 120vac input. In my area line voltage from provider can vary from 115 to 122vac (I have a real time indicator) in normal situation (not too cold/hot weather). Mostly depends on time of the day with demands from all houses/buildings.
Also, rectifier diodes have different voltage drop depending on their temperature. Check the specific data sheet of your diodes.
And then you add the voltage drop of the resistors in series in your PSU.
Fab
Joined 2014
With my 600va, 32v transformers, my BB’s are running at 37.5vdc with a CRCLC. If I use a capMx instead of the CRCLC the voltage increases to 38vdc.
Since it’s summertime, my line voltage varies widely during a 24 hr period. Anywhere from 112vac to 125vac.
I think my ALPHA20 is running 23vdc, I’d have to check (don’t remember).
I did notice that the DC offset increased from 10mv @36vdc to 25mv @37.5vdc?
Some small progress on the Alpha
The two feet and the faceplate got stained.
X, I have another song for listening tests. I haven't been able to find a CD yet, but in the mean time check on YT, this performance is amazing.
Ennio Morricone's 1966 main theme for the "Good, Bad, and Ugly" performed by the Danish National Symphony Orchestra in a live performance earlier this year. Better than the original.
Enjoy,
David
Founder of XSA-Labs
Joined 2012
Enjoy,
David
Superb recording and rendition! Makes me want to watch the movie again.
Thanks for the tip!
Founder of XSA-Labs
Joined 2012
The speakerlab where Alpha B.B. was playing is now under renovation. I had a basement flooding over the weekend and dealing with cleanup. All amplifiers were ok but I lost several foam core speakers. It will be a while before back up and running. I do miss listening to this amp. All wet carpeting pulled out and now in process of drying. Things will be a bit quiet on DIY front for a while.
