Baffle Diffraction
We're absolutely NOT disagreeing! Do you think that every comment that I make is a disagreement? I agree with you about the audibility of high Q resonances, I was just trying to explain why Toole's comment has to be considered in light of how they did the tests.
I was just responding to your comment saying "I would have agreed with you on this except when I went back and reread Floyd's claim" where you went on to point out that the comparison was done with equal amplitudes - I was just pointing out that I was aware of that and mentioned it already and thus didn't think we were actually in disagreement.
I've always meant to work this out mathematically because I believe that it is true on a log-log curve, but probably not true on a linear-linear one. Since the energy requires a linear-linear calculation, the energy (area under the curve) would drop substantially as the damping is increased. Let's face it, it has to.
I had a quick look and found two different mentions speaker dave made in relation to the audibility of cabinet resonances with changes in Q:
http://www.diyaudio.com/forums/mult...a-speaker-based-t27s-b110s-6.html#post4166507
I have no argument with the Olive data on audibility of resonances. It is good to expand our understanding of the topic. I would repeat my caution on its interpretation, especially when applied to mechanical systems. Adding damping to reduce resonance Q is always desrable because the peak level drops at twice the rate that the perceptability increases. This needs to be understood.
and
http://www.diyaudio.com/forums/multi-way/245965-cabinet-sound.html#post3710117
I like the Barlow paper but it is misapplied whenever referenced in cabinet discussions. He and others looked at a situation with electrical filters in parallel with a flat straight through chain. He found that raising Q made a resonance less audible. Specifically, if Q was doubled the resonance would need to go up 3dB for similar audibility.
This implies that if we had a fixed peak height that higher Q will be less audible than lower Q. Trouble is, with mechanical resonance and assuming that damping is being varied, peak height goes up 6dB when Q is doubled. So the 6dB level gain is twice the perceptual loss. Cabinet resonances are, in net, 3dB more audible when Q is doubled.
To me that's pretty clear advice that when a mechanical resonance is involved - whether a panel resonance or a driver cone resonance, that improving the damping of that resonance to lower it's Q will make it less audible, and that is certainly my experience.
As you point out another way of looking at it is the amount of energy in the resonance - the high Q resonance will have more energy in it, how could it not ?
The artificial scenario of different Q resonances with the same peak amplitude, which doesn't happen in mechanical resonances when you are only varying the damping just serves to confuse the situation.
Simon - you see I completely agree with your previous comments (#200). I think that we are on the same page. The difference between fused signals and non-fused ones IS fundamental.
As to "I was just responding to your comment saying" - you are correct, I worded that badly. I should have stated that "I agree with you, however ..."
Is there a trade off between better imaging and a smaller sweet spot?
No, my speakers have a huge sweet spot which I think is because of the brick wall crossover around 1000 hz. They're actually on both sides of a plasma tv, and I know I get reflections off the TV so that could affect things as well.
I’d have to disagree. Anecdotal, but comparison between our CGR rectangular monkey coffin box, and the same alignment in a box with a crude teardrop plan section with big chamfers on the sides, shows that the 2nd box has the capability to disappear to a greater extent, ie it has a lower diffraction signature. Something of significant importance if you are looking for the best image/soundstage capability.
dave
That's really the issue. Diffraction might result in simple peaks and dips in the frequency response at a position. However, I assume our brains process these peaks and dips to form a picture of what's going on.
Its not just the instantaneous FR but the changes in FR over time as the later reflections arrive. Its a bit like lobing.
The fact that we have two ears and can locate sounds so well suggests that we must be very sensitive to timing. I don't understand the whole phase thing, but if the FR is flat across time and direction that is the best. I would think phase isn't as issue till it affects the FR in some way.
Yes, but this is the thing. At small timing differences from the direct it may only affect the response, but at slightly higher differences it can cause fatigue trying to sort it out. Then at large differences it becomes an echo, ie ambience, which is fine if it is nicely balanced.
What I'm saying is that with diffraction and early reflections what we actually hear are the changes in FR. Out of phase waves are interfering with the sound in various ways over time. Also differences in how the direct sound itself reflects off the baffle. Our brains process the change in FR and tell us one speaker sounds boxy and another smooth.
I think this is the case for all linear distortion, its the various changes in FR over time, and probably the difference between sounds that reach our two ears. Nonlinear OTOH is basically extra noise. I think its easier to mentally adjust to nonlinear.
I think too much is getting lumped together here. What we hear is more complex, timing clearly plays a role, so its more than just FR.
For example, in our latest study (incomplete at this time, but dozens of screened listeners in controlled double blind testing) we can not detect image location blur for steady state random noise signals, but we can with the same FR impulsive signal. But, on the other hand the noise signal is best at detecting coloration, and finally each is relatively immune to what the other is best at. Clearly there is more to things than just FR.
Is any of this relevant to Floyd Toole's research that he speaks about here? He mentions how important off axis FR is and the resulting sound power. Mostly way above my head but very interesting to listen to:
YouTube
Yea that's what I took away from his lecture. Basically the frequency response decays over time.
So even if the direct sound from a speaker is flat the sound that arrives later might not be. This creates a mismatch. This is why we can hear things like an off axis suckout.
Apparently its part of how we locate sounds which we are designed to be sensitive to.
I assume that FR and the changes to it are how we can tell phase. Lobing is essentially a phase problem and is creates a different FR at a different angle.
YouTube
Of course it's all relevant, and you should understand everything that Floyd says because it's all valid. But when we talk about the nuances of image that might result from cabinet diffractions, it's kind of beyond what Floyd is talking about. Think of it as Floyd's comments are the basics that you must understand to really follow what we are talking about in regards to diffraction. Floyd's stuff is the big picture and here we are into the details.
Without getting into Toole and pinna theory, I will point out that dipoles and de-emphasis on room colouration (such as with neutrality of non-direct sound) help reduce the salience of room cues relative to the reproduced signal.
My point is that you can't escape sound cues that tell your brain you are in your room. No way.
B.
Simon is correct (I think Ben is just being difficult), one could not do any reasonable measurement in-situ. There will be too many nearby wall and other diffractions/reflections to get any decent idea of the grills effect. But it is well known that grills are a problem in general. That's why I never used them.
Earl - is seems self-evident to some others posting here that before-and-after measurements - even just a single run of the sort DBMandrake posted - definitely illustrate the extent of grill influence on FR, if present, even if they don't tell the story in 100 charts.
Of course, the grill plot DBManddrake shows is the worse grill ever designed by humankind since approximately the year Homer was born. Have a close look at the picture.
I finally had the opportunity to make some quick grill on, grill off measurements of my main speakers, so as promised, here they are.
I was able to move the speakers to get a little to get a bit more reflection free time however the measurement environment was still far from ideal, so I've still had to use a rather short gate time of 2.5ms, so the measurement is only sufficiently detailed down to perhaps 1Khz.
So, not ideal, but it does give some idea of the effect of the grill cloth and it's frame on higher frequencies. The front panels are flat, 39cm wide 59cm tall, the "midbass" driver is centrally located while the tweeter is about half way between the mid bass and the top of the cabinet with a 20cm centre to centre spacing. The crossover is a 4th order LR at 3Khz.
The grill cloth is very simple - a wooden frame about 15mm tall and 10mm wide with black acoustic cloth pulled tight. There are no struts or braces - just a frame around the perimeter. The mounting pegs cause there to be about a 3mm gap between the frame and the surface of the panel.
The first is an on axis measurement:
attachment.php
The blue grill off measurement is clearly significantly smoother right from about 2Khz up to about 15Khz. In particular notice the peaks at 8Khz and about 6.5Khz.
Subjectively, putting the grill on loses some of the "airiness" of the treble and sounds slightly sibilant, but not to an objectionable degree. There is no sibilance with the grills off. The peaks at 6.5Khz and 8Khz in particular explain this sibilance.
There are noticeable dips at 3Khz, 4Khz, 9Khz and 11Khz that all probably contribute to a small loss of presence and airiness when the grill is on.
Next is 30 degrees off the horizontal axis:
attachment.php
In this one the difference between grill on and off is significantly less at lower frequencies, with only a small dip at about 4Khz being present until about 7Khz.
It's obvious though that the peak at 8Khz is still the same as is the dip at 9Khz.
This suggests the 8Khz peak and 9Khz dip is a cavity resonance formed between the tweeter and the grill cloth, and this peak/dip combination is probably present at most if not all off axis angles.
On the other hand most of the fluctuations seen at lower frequencies on axis are gone off axis, suggesting that the frame of the grill cloth was responsible for those.
Despite both drivers having a significant amount of high frequency directivity the frame of the grill cloth still has a significant effect, although nowhere near as bad as the Technics speaker I posted earlier.
On the other hand, the cavity resonance at 8Khz could probably be avoided by reducing the distance from the grill cloth to the tweeter. If it was halved it would shift it up to 16Khz so a bit less than half the gap should move it out of the audible region.
Unfortunately I can't move it any closer because while the tweeter is flush mounted on the panel the mid bass drive is mounted on the front of the panel. (For various reasons) So I had to make the frame of the grill cloth a lot taller than I would have preferred.
Do these grill cloths and frames introduce the horrific response aberrations of the Technics speaker I posted earlier in the thread - absolutely not. That was an example of how bad it can be if grills are designed with no consideration for diffraction. By comparison the changes here are much more subtle, and they still sound good with the grills on.
But there is an obvious improvement in the quality with them off, both subjectively and in measurements, so for critical listening I always remove them.
Yup maybe different from some other truly bad box coverings. But it looks like this covering would make no audible difference to persons of ordinary human hearing acuity in a blind test, based on the remarkably similar near-field plots.
Thanks for providing measurements.
B.
I just bought one of these waveguided tweeters. It has a nice rainbow off axis response (at least to 45 deg)
Dayton Audio ND25FW-4 1" Soft Dome Neodymium Tweeter with Waveguide 4 Ohm
I don't think I would bother building a speaker without dealing with diffraction in the high frequencies. Its just not worth the trouble. A waveguide is easier than making a rounded enclosure.
The choice comes down to either more or less directionality. Directionality is better in a large room or if the speakers are near walls or objects.
...- both advantageous, but for different reasons.
In a larger sense, it isn't only dispersion control (that Earl favours for his well-argued reasoning) but what tone colour reaches your ears.
For days, I've been thinking that diffraction is not much different than "borrowing from Peter to pay Paul". Maybe the best analogy is "gain management" theory, really the same concept.
Subject to EQ etc, a driver emits whatever it emits and according to its Toole total polar plot, and room structural acoustics and furnishings*. The question is what gets to your ears and how we "colour manage" it.
Of course, folks who love dipoles (and we are a very dedicated lot) just laugh at talk of box diffraction since our systems diffract all over the room and we love the ambience... and think there's got to be more important stuff to think about.
B.
*pity the new acoustics forum was hidden away, far away
It seems to me that the exact opposite would be the case. High directivity limits the early reflections that are so problematic in small rooms. Directivity is also advantageous in large rooms to direct the energy to where it is needed - both advantageous, but for different reasons.
B.
Too much direct sound without enough late reflections will sound lifeless and fatiguing. This is more true for music than home theater. Music is meant to interact with a space and produce reverb and harmonics.
Which leads to a much larger point, which is that most people (including me) don't have a properly sized and treated listening room. So most people are getting too much direct sound and not enough indirect. And the indirect they get may not be very good.
So FWIW in my hobbyist opinion, the reason why people gravitate towards certain kinds of lower fidelity options like tube amps and vinyl is they are unwittingly trying to dirty up the sound a bit and replace some of the harmonics that are missing.
If you are stuck with a small space something like a small spheroid high dispersion speaker might be your best option but only then if you can clear the area around it. Another option might be a larger speaker with a more resonant cabinet design.
Small dead rooms are indeed bad. That's why mine are as lively as possible. High DI gives a good clean direct sound with low early reflections and the room adds in the later reflections because it is reverberant. A small reverberant room with a low DI speaker will have poor to no imaging. A low DI speaker in a dead room just sounds dead.
I would assume if the room is dead you would want to have more dispersion and less directivity.
