Here it is.Would you share the anti riaa circuit you are using ?
You can use either a source of 0 Ohm or 50 Ohm by changing the value of {Cx}.
Input is at the top, output has to be loaded with 10 Ohm.
Read the next line:You have C=6.1135 nF at Rin = 0 ohm but .param C=6.1135 why not nF?
Rx=C*1e-9
Thank you
Would you also share the math behind your calculated values ?
Laplace with the 3 time constants
Thank you so much Hans
Now I have another question..... is it possible to use your tech http://www.diyaudio.com/forums/anal...universal-diff-diff-head-amp.html#post5428617
To eliminate current in the IPS on the original Paradise ?
It was not my intention to be so active in Joachims thread.Thank you so much Hans
Maybe you should ask the question in the other thread and explain the same time what you mean with IPS.
Hans
O.k. a quick sim, all BC-327/337(40)'s
Gain about 28dB
Noise about 24nv/Hz1/2
THD near -85dB
PSU-load 75mA
As one can see, the design has a 'not do good' PSSR and the 75mA (per 15V rail) is thus demanding, it (the PSU) needs to be firm and precise.
The output offset (with the ideal transistors) is 11mV (not to bad at all).
Gain about 28dB
THD near -85dB
PSU-load 75mA
