More modern design, and I have been wanting a big Karlsonator 🙂
But, of course, the old adage "just because you could, didn't mean you should" applies.
I've had a real stiffy for karlson types of speakers lately 🙂
I would say go for it! Why you may ask, fair enough here is my reasoning. I got a pair of 0.53x Karlson's with 5" Dayton PA130-8. The speaker itself is really small and it sounds like a big speaker when located properly near a corner. I also got a pair of these 15" Fane's (still) playing around free-air. I've never heard anything quite similar with any speaker in free-air. So much clean and clear sound. If I had really big room with really big volume level needs, I would most definitely build a pair of Karlson's for the Fane's.
There you are!
We did ask X in one of his threads, haven't gotten a possible solution yet.
Are you still on no eq?
Pictures please!
What kind of baffle are you using?
Pictures please!
Anyone try this driver with a SET tube amp, particularly a 300B? I am interested in a vented box with a horn, probably crossed over at 1200hz or above.
Thanks!
Jp
Thanks!
Jp
I'm using the 12's in 7 cubic foot vented box and driving it with a 3 watt el84 se amp. Plays quite loud in my 20 by 14 foot room!
Larry
Larry
I have 12's with SE DHT pre and EL84 PP, weaving all the magic. 14 x 23 room and scaringly loud. Not sure about @1200 Hz. Kind of pretty high for the FR. I like to confine all the vocals to the Fanes and xo at 120 hz. Even 200 hz starts splitting the vocals.
Sam.
Sam.
100-160 is where I usually cross subwoofers, and it works out nicely that way. I agree that much higher is too noticeable usually, except in certain instances.
Some situations crossing just at 300 or so works, but it depends on the room.
And the setup.
I used to think everything over 120hz was too high. Had the same opinion on 80hz before that.
Does it increase with age? Or do maybe with increasing age comes increasing quality of the sound system?
That does not depend on the room, that only works if the sub is directly below what's playing over it.
I`ve been listening for a few days and am still impressed with how they sound. These drivers are made for instruments that can dig down and have big dynamic range like a piano, cello or tenor sax. I cut the baffles down to 24x40 inches (60x100 cm) and put them on 6 inch (15 cm)legs. Also made an open back box the depth of the drivers because I`d like to hide them. Would have a grill on the front and cover the back with fabric. This seems to have helped the high end as cymbals are more evident on jazz recordings. Hasn`t affected the low end to my ears. Will upload pics as soon as I can find young person to help me.
Little update. Now couple hours of listening with an open baffle setup. Baffles are really simple 18 mm birch plywood, two of them stacked measuring 60 cm wide, 120 cm tall and the center of the drivers are approx 40 cm from the top.
How do they sound? Absolutely brilliant! All the good things, that have made full range speakers so popular are there, with the beauty of an open baffle speaker. One thing that is really impressive is the sheer amount of volume that these speakers can deliver with which seems to be no effort at all. I personally really enjoy how these speakers fill the room with sound. I don't mind listening these speakers as they are, there is plenty of bass, but I can definitely see that there is still room for subwoofers. If you haven't heard any big full range speakers, that is something that I can highly recommend trying out. At the end of the day these speakers did cost me less than 300 euros for the pair and that includes everything.
As the drivers break in they sound better and better. I have 2 full range and 2 LF 15 inch Fane drivers which cost me $760cad, a minidsp $150cad and Baltic birch ply, cut at the lumber yard, for the final cabs $93cad for a total of almost exactly $1000cad. I had to buy a second amp, a Crown D75, more cables and connectors but expect the total to be under $1500cad. A great price to performance ratio.
I keep hoping for updates in this thread and reading more and more experiences. I was expecting more mixed reviews, and some sort of indication that it's for very specific use cases or tastes. But so far, experiences seem to indicate it sounds good and isn't hard to live with. Very nice!
I keep getting mental images of the Jensen corner imperials, Tannoy horns etc. I'm finalizing a smallish off-set driver backloaded horn that looks nice in hornresp and maybe I will even order a pair of these drivers.
Would you mind sharing some info about those hornresp sims?
... And smallish is somewhere under 200 liters, right? 🙂
Sure, I'll share.
Smallish is about 315 liters. Maybe not your definition of smallish. (It's "just" 120 cm high instead of the 216 cm BiB of the same footprint I have now.)
It's standalone, though. In combination with room gain, it gets down below 30 Hz. No direct need for a sub.
I am using a Fane Sovereign 15-400LF per side for low frequencies and am satisfied with the response.
At which frequency are you crossing over?
I'll post a sketch and some sims/parameters.
This is the closed side.
Long story short, it's essentially a reverse-engineered Olson backloaded corner horn, which was then re-engineered as an off-set driver pipe horn with parabolic expansion (a BIB but with less volume) and folded into a rectangular box. The mouth fires down and exhausts to the sides and back. Response is smooth and rolls off gently towards the lower range. With room gain, extension should go below 30 Hz. I'll show a sim next and an interior view. I am still working out a bracing scheme.
Size is 43.6 cm wide, 120 cm high, 60 cm deep.
- Full Range
- New 15" full range - FANE
