Aksa Lender P-MOS Hybrid Aleph (ALPHA) Amplifier
Output is proportional to input. The simulation used a 100mVpp square wave input. There is more ringing than that because the HP filter attenuates it a bit.
You would get more ringing in proportion to the input square wave level, but it would still be hidden in the root of the wave and undetectable, hence the HP filter to make it detectable.
Watchtmouse,
You are moving fast. 100uF 16v is all you need and not 1000uF 50v. That was my fault for over spec. I would use 220uF 25v if you have it. It doesn’t see anything higher than rails / 10 or 2.5v.
Hi X,
Exactly which position is being discussed here? A 100uF to 220uF cap for C103?
IIRC the bill of materials had 47uF for C103 - a change to that is being suggested?
Hi X,
Hi Zman,
The cap I was referring to is the feedback shunt cap C111 below (220uF 25v is plenty here):
660029d1517503984-aksa-lender-mos-hybrid-aleph-alpha-amplifier-alpha-20w_schematic-v4-png
Thanks, Irrebeo,
My mistake - C103 needs to be 1000uF and at least 35v and the large value is for the anti thump feature.
Folks:
In the future please attach schematic and specify part label when asking questions about specific parts and mods. Hugh’s schematic and JPs64’s Schematics have different labels.
Thanks, Irrebeo,
Folks:
Wasted some shipping costs here, yesterday I ordered the wrong value, no big deal.
Then again the question, but with more context ;-)
1). Alpha 20 JPS64 schematic, The C103 cap, Due to the limited size on the Alpha 20 board, a 1000uF capacitor will not fit, the max diameter for the C103 cap is 10 mm and the RM is 5 mm, this gives me a max of 470 uF 50 V (10 times the original of 47 uF (C103 is named C2 in the original AKSA schematic).
Now to the question, is the 1000 uF important or will any bigger cap as 47 uF do?
Sorry for being a nucance
Happy listening
Bert
If you look at the bottom of the first schematic by Hugh on Post #1, you will recommendation for Fairchild parts:
FDA38N30
FQA36P20 (but I think Hugh meant FQA36P15 as I could not find a P20)
Capable of 300w dissipation.
Can use this in place of FDA38N30?
TK39J60W5,S1VQ(O Toshiba | Toshiba TK39J60W5,S1VQ(O N-channel MOSFET, 39 A, 600 V DTMOSIV, 3-Pin TO-3PN | 799-5135 | Welcome to RS Online
And the FQA36P15 is
FQA36P15 ON Semiconductor | ON Semiconductor FQA36P15 P-channel MOSFET, 36 A, 150 V QFET, 3-Pin TO-3PN | 671-4938 | Welcome to RS Online
FR and Phase relationship of ALPHA20
Here it is, pretty good too! 7 degrees at 20KHz, and 33 degrees at 100KHz. Much of this is due to the input LP filter; I have set it a 330R//1nF at the input.
The LF depends on the size of the input cap. I have set this to 10uF but down to 1.5uF is acceptable if you want really good caps (large!)
FDA38N30 OR FQA40N25
FQA36P15 is correct, thanks X and Danny!
HD
