Pass Labs B4 crossover questions
Just went through this thread again. There seem to be different "versions" of the FirstWatt active filters. B4 and B5 are described on the FirstWatt website, and some others that I don't understand.
Which "version" will be available in kit form in the diyAudio store? When? I wouldn't mind a B4 right now 😀
Farther along than you might think.
That is the easy way. By the time I have have converted balanced to
single-ended and back again, it costs as much as two boards. The
boards would work fine with 6 RCA and 3 XLR.
Actually, I don't need to convert unbalanced to balanced and vice versa.
I want it to fully balanced, along the full path.
If counting my unbalanced sources there are quite few, perhaps a Revox B261, Revox A77 and an AKAI GX630D can be.
Quite rarely using them.
An NP designed crossover will be perfect for this system.
The ribbon tweeter I have posted recently will be driven by the F4 Beast with unlimited current.
The 4 x midranges will be driven by a simple F7 variant.
A separate subwoof will be driven by an Adcom GFA555.
All in all, a 100% NP active signal chain.
I will want a stereo 3-way with crossover points of 100Hz an 3 kHz. If this requires 2 2-way crossovers, that would be just as sweet as a single-box 3-way.
I am stoked that an NP designed crossover will be available in the DIY audio store.
