Moode Audio Player for Raspberry Pi
Hi Eric,
Interesting. System time is pretty much 100% good when using the USB-SDCard method because fake-hwclock.data will have a reasonably current timestamp from the last boot of the host system. It's supposed to be updated each hour by a cron job but cron is disabled in moode os, this is not a problem btw.
The direct method however may be vulnerable to a window where the system time may not be updated yet by timesyncd before user starts mosbuild.
Maybe just prompt for current time??
Code:
timedatectl set-time TIME
Even w/o a timezone it will be current enough.
References:
man systemd-timesyncd.service
systemd-timesyncd - ArchWiki
-Tim
Yes something like this for direct method ... however usually certificate do not use timezone.
Long time picore user here.. I am trying other distros time to time. Among all others most unique one is moode IMO.
Using 4.0. But every mpd based player has same problem with my source drive. Picore scans and adds everything to dbase correctly. But all mpd based players not scanning entire drive and contents. I tried ntfs,fat32,ext4 filesystems. Tried to give full rights to every directory. For an example; One directory contains 8 subdir and all of them has same kind of flac & cue sheet file.But mpd scan and add only one of them to the library. Couldnt find any clue about this issue.
Anyone has same problem?
as a side work, i installed Volumio
i see it guides me setting up wifi, nas and so on at the init setup
Good to have it in moode.
Like an initial setup screen on first run?
It would be nice to streamline some of the steps that require a reboot when setting things up if there aren’t any dependencies. Not like you do it often but if you could set wifi/network, audio card, expand fs (optional), updated mpd and rebooted (once!) after it was finished that’d be pretty sweet.
Examine MPD log for an indication of what might be going on. If there are errors then post a sample and I'll have a look.
cat /var/log/mpd/log
-Tim
Similar issue, but not same solution
Unable to use the graphic equalizer. Doesn't seem to be an option to turn on, off is only option.
Symptom suggests one of the other DSP features is on. Only one of Crossfeed, Parametric EQ or Graphic EQ can be on.
-Tim
Ah! Thanks Tim, that was indeed the case. These functions are fabulous, I'm finally getting my speakers balanced to match my damaged hearing range. Thanks for your wonderful program. Donation headed yer way.
This was asked and addressed way back in Feb, but I have been unable to get the same simple solution to work. I have searched this thread, but maybe I haven't gone back far enough.
Whenever I try to turn on either the parametric or graphic equalizer, Moode seems to get stuck and will no longer play any tracks. I cannot get the Playback screen to show anything.
My setup:
RBPi 3B ---> MoOde Release 4.0 2018-01-26 ---> Allo Piano 2.1​
What I've tried:
  • Turning on either Parametric EQ (with default settings) or Graphic EQ (Lo boost, Hi boost, tried several) under the Aduio Config page.
  • Tried just waiting awhile, refreshing, emptying caches, and also tried rebooting.
  • Playback screen has audio controls but no tracks, playlist, or album art.
  • Playback controls don't do anything.
  • Nothing seems to enable playback except going back to config and turning off the EQ.
  • Reboot required for playback.
My setup:
What I've tried:
Post the output from System info and I'll have a look.
Menu, Configure, System
Menu, System info
or from ssh
sudo /var/www/command/sysinfo.sh
Menu, System info
or from ssh
Tim, I have seen you do this so many times for so many people, I feel bad...
Code:
pi@moode:~ $ sudo /var/www/command/sysinfo.sh
	  S Y S T E M    P A R A M E T E R S
	Date and time	= 2018-03-25 02:09:29
	System uptime	= up 2 hours, 56 minutes
	Timezone	= America/Detroit
	moOde		= Release 4.0 2018-01-26
	Host name	= moode
	ETH0  IP	= unassigned
	ETH0  MAC	= b8:27:eb:0a:d1:84
	WLAN0 IP	= 192.168.1.30
	WLAN0 MAC	= b8:27:eb:5f:84:d1
	HDWR REV	= Pi-3B 1GB v1.2
	SoC 		= BCM2835
	CORES		= 4
	ARCH		= armv7l
	KERNEL		= 4.9.79-v7+
	KTIMER FREQ	= 100 Hz
	USB BOOT	= not enabled
	Warranty	= OK
	ROOT size	= 15G
	ROOT used 	= 15%
	ROOT avail	= 12G
	FS expand	= expanded
	MEM free 	= 591 MB
	MEM used 	= 58 MB
	Temperature 	= 55.3°C
	CPU GOV		= performance
	MPD SCHDPOL	= TS
	P3-WIFI		= On
	P3-BT		= On
	HDMI		= On
	ETH0 CHECK	= On
	MAX USB CUR	= Off
	UAC2 FIX	= Off
	SSH server	= Off
	LED0		= on
	LED1		= on
	  C O R E    S E R V E R S
	PHP-FPM		= 7.0.27
	NGINX		= 1.10.3
	SQLite		= 3.16.2
	Bluetooth	= 5.43
	  C P U    L O A D
	CPU	%usr	%sys	%idle
	all	0.00	0.50	99.50
	0	0.00	0.00	100.00
	1	0.00	0.00	100.00
	2	0.00	1.00	99.00
	3	0.00	1.00	99.00
	  P R O C E S S    L O A D
	PRI RTPRIO COMMAND         %MEM PSR %CPU
	 29      - mpd              2.2   1 13.5
	 19      - sysinfo.sh       0.2   2  1.3
	 19      - sshd             0.6   1  0.4
	 19      - bash             0.4   0  0.4
	 19      - sudo             0.3   1  0.3
	 19      - worker.php       1.1   1  0.2
	 19      - systemd          0.5   3  0.1
	 19      - systemd          0.6   2  0.0
	 19      - kthreadd         0.0   0  0.0
	  C L O C K    F R E Q U E N C I E S
     	arm   = 1200 MHz      	 pwm   = 0 MHz
     	core  = 400 MHz	      	 emmc  = 249 MHz
     	h264  = 300 MHz	      	 pixel = 25 MHz
     	isp   = 300 MHz	      	 vec   = 126 MHz
     	v3d   = 300 MHz	      	 hdmi  = 163 MHz
     	uart  = 47 MHz	      	 dpi   = 0 MHz
	SD card	= 50 MHz
	  S Y S T E M    V O L T A G E S
	core			= 1.3250V
	sdram controller	= 1.2000V
	sdram I/O		= 1.2000V
	sdram chip		= 1.2250V
	  U I  C U S T O M I Z A T I O N S
	Theme			= Standard
	Accent color		= Bluejeans
	Alpha blend		= 1.00
	Adaptive background	= Yes
	Background image	= No
	Playback history	= Yes
	Extra metadata		= Yes
	Library			= Use AlbumArtist
	  A U D I O    P A R A M E T E R S
	Audio device		= Allo Piano 2.1 Hi-Fi DAC
	Interface		= I2S
	Hdwr volume		= 100
	Mixer name		= Master
	Output stream		= Closed
	ALSA version		= 1.1.3-5+rpi3
	SoX version		= 0.1.2-2
	Volume knob		= 4
	Volume mute		= Off
	Volume limit		= 60
	Bluetooth controller	= Off
	Airplay receiver	= On
	Squeezelite		= Off
	UPnP renderer		= Off
	DLNA server		= Off
	Rotary encoder		= Off
	Encoder params		= 100 2 3 4 5
	Crossfeed		= Off
	Parametric EQ		= Off
	Graphic EQ		= Off
	Auto-shuffle		= Off
	Autoplay		= Off
	MPD crossfade		= Off
	  M P D    S E T T I N G S
	Version			= 0.20.12
	Volume control		= software
	ALSA device		= hw:0
	SoX resampling		= 352800:32:2
	SoX quality		= very high
	SoX multithreading	= on
	Audio buffer (kb)	= 4096
	Buffer before play	= 10%
	Output buffer size (kb)	= 81920
	Volume normalization	= no
	DSD over PCM (DoP)	= no
	Replay gain		= off
	  A I R P L A Y    S E T T I N G S
	Version			= 3.1.7
	Friendly name		= Moode Airplay
	Metadata display	= Off
	ALSA device		= hw:0
	Volume mixer		= auto
	Resume MPD after	= No
	Output bit depth	= S16
	Output sample rate	= 44100
	Session interruption	= no
	Session timeout (ms)	= 120
	Audio buffer (secs)	= 0.0
	  S Q U E E Z E L I T E    S E T T I N G S
	Version			= 1.8.7-1020 "DSD/SRC enabled"
	ALSA device		= hw:0
	ALSA params		= 80:4::1
	Output buffers		= 40000:100000
	Task priority		= 45
	Codec list		= flac,pcm,mp3,ogg,aac,alac,dsd
	Other options		= -W -D 500 -R E
	  M O O D E    L O G
    20180324 231313 worker: - Start
    20180324 231313 worker: Successfully daemonized
    20180324 231313 worker: - Init
    20180324 231314 worker: Session loaded
    20180324 231314 worker: Debug logging (off)
    20180324 231315 worker: Host (moode)
    20180324 231315 worker: Hdwr (Pi-3B 1GB v1.2)
    20180324 231315 worker: Arch (armv7l)
    20180324 231315 worker: Kver (4.9.79-v7+)
    20180324 231315 worker: Ktyp (Standard)
    20180324 231315 worker: Gov  (performance)
    20180324 231315 worker: Rel  (Moode 4.0 2018-01-26)
    20180324 231315 worker: Upd  (None)
    20180324 231315 worker: MPD  (0.20.12)
    20180324 231315 worker: USB boot not enabled yet
    20180324 231315 worker: File system expanded
    20180324 231315 worker: HDMI port on
    20180324 231315 worker: File check ok
    20180324 231315 worker: - Network
    20180324 231315 worker: eth0 exists
    20180324 231316 worker: eth0 wait 0 for IP address
    20180324 231319 worker: eth0 wait 1 for IP address
    20180324 231322 worker: eth0 wait 2 for IP address
    20180324 231325 worker: eth0 wait 3 for IP address
    20180324 231328 worker: eth0 wait 4 for IP address
    20180324 231331 worker: eth0 wait 5 for IP address
    20180324 231334 worker: eth0 wait 6 for IP address
    20180324 231337 worker: eth0 wait 7 for IP address
    20180324 231340 worker: eth0 wait 8 for IP address
    20180324 231343 worker: eth0 wait 9 for IP address
    20180324 231353 worker: eth0 address not assigned
    20180324 231353 worker: wlan0 exists
    20180324 231353 worker: wlan0 trying SSID (The Speedy Basset)
    20180324 231354 worker: wlan0 (192.168.1.30)
    20180324 231354 worker: - Audio
    20180324 231354 worker: ALSA outputs unmuted
    20180324 231354 worker: Audio out (I2S audio device)
    20180324 231354 worker: Audio dev (Allo Piano 2.1 Hi-Fi DAC)
    20180324 231354 worker: ALSA mixer name (Master)
    20180324 231354 worker: MPD volume control (software)
    20180324 231354 worker: Hdwr volume controller exists
    20180324 231354 worker: Chip options (Burr Brown PCM5142)
    20180324 231354 worker: Piano output mode (2.1)
    20180324 231356 command/moode: Connection to MPD failed
    20180324 231358 command/moode: Connection to MPD failed
    20180324 231401 worker: Piano 2.1 initialized
    20180324 231401 worker: - Services
    20180324 231403 worker: MPD started
    20180324 231403 worker: MPD scheduler policy (time-share)
    20180324 231403 worker: MPD output 1 ALSA default (off)
    20180324 231403 worker: MPD output 2 ALSA crossfeed (off)
    20180324 231403 worker: MPD output 3 ALSA parametric eq (on)
    20180324 231403 worker: MPD output 4 ALSA graphic eq (off)
    20180324 231403 worker: MPD crossfade (off)
    20180324 231403 worker: Airplay receiver started
    20180324 231403 worker: Airplay volume mgt (auto)
    20180324 231403 worker: - Last
    20180324 231403 worker: USB sources (none attached)
    20180324 231403 worker: NAS sources (mountall initiated)
    20180324 231403 worker: Volume level (13) restored
    20180324 231403 worker: Maintenance interval (21600)
    20180324 231403 worker: Watchdog started
    20180324 231403 worker: Ready
    20180324 231451 worker: Job alsavolume
    20180324 231603 worker: Job eqfa4p
After turning on graphic EQ, this is what I get:
Code:
	Date and time	= 2018-03-25 02:16:47
	System uptime	= up 3 hours, 3 minutes
	Host name	= moode
	SoC 		= BCM2835
	CORES		= 4
	ARCH		= armv7l
	KERNEL		= 4.9.79-v7+
	Warranty	= OK
	ROOT size	= 15G
	ROOT used 	= 15%
	ROOT avail	= 12G
	MEM free 	= 582 MB
	MEM used 	= 64 MB
	Temperature 	= 55.8°C
	MPD SCHDPOL	= TS
	P3-WIFI		= On
	P3-BT		= On
	HDMI		= On
	ETH0 CHECK	= On
	MAX USB CUR	= Off
	UAC2 FIX	= Off
	SSH server	= Off
	LED0		= on
	LED1		= on
	PHP-FPM		= 7.0.27
	NGINX		= 1.10.3
	SQLite		= 3.16.2
	Bluetooth	= 5.43
	  C P U    L O A D
	CPU	%usr	%sys	%idle
	all	0.00	0.00	100.00
	0	0.00	0.00	100.00
	1	0.00	0.00	100.00
	2	0.00	0.00	100.00
	3	0.00	0.00	100.00
	 29      - mpd              2.9   1 12.9
	 19      - sysinfo.sh       0.2   1  2.5
	 19      - sudo             0.3   2  0.5
	 19      - kworker/u8:2     0.0   0  0.1
	 19      - php-fpm7.0       1.1   1  0.1
	 19      - systemd          0.6   1  0.0
	 19      - kthreadd         0.0   1  0.0
	 19      - ksoftirqd/0      0.0   0  0.0
     	uart  = 48 MHz	      	 dpi   = 0 MHz
	SD card	= 50 MHz
	core			= 1.3250V
	sdram I/O		= 1.2000V
	Theme			= Standard
	Alpha blend		= 1.00
	Interface		= I2S
	Hdwr volume		= 100
	Mixer name		= Master
	Volume knob		= 10
	Volume mute		= Off
	Volume limit		= 60
	Squeezelite		= Off
	UPnP renderer		= Off
	DLNA server		= Off
	Crossfeed		= Off
	Parametric EQ		= Off
	Graphic EQ		= Lo Boost
	Auto-shuffle		= Off
	Autoplay		= Off
	MPD crossfade		= Off
	Version			= 0.20.12
	ALSA device		= hw:0
	Replay gain		= off
	Version			= 3.1.7
	ALSA device		= hw:0
	Volume mixer		= auto
	ALSA device		= hw:0
	Task priority		= 45
	  M O O D E    L O G
    20180325 021555 worker: Job alsaequal
I am just not experienced enough to sort out what is going on.
Thx so much!
Sorry can someone tell me the the exact steps to reproduce this, so at which menu level they start the search, what term they use and which item they select.
As unfortunately I cannot reproduce this in either Bubbleds or Kazoo, I am on the latest version of upmpdcli but I think the only differences between the patched version and mine are outside of Tidal and Qobuz.
Also check to see if there are any upmpdcli errors in syslog as mentioned above.
I will look at reverting my upmpdcli tonight.
Sorry for only responding now SB but this is the log from /var/log/syslog that may be relevant. This happens when searching for an album or a track using both Linn Kazoo and Lumin.
I apologise if it looks a bit messy but I do not now how else to post the extract from syslog
Mar 25 14:59:40 moode upmpdcli[1008]: CMDTALK: tidal-app.py: Tidal running
Mar 25 14:59:40 moode upmpdcli[1008]: CMDTALK: tidal-app.py: pCmdTalkProcessor.process: [{u'cmdtalk😛roc': 'browse', u'flag': 'children', u'objid': '0$tidal$'}]
Mar 25 14:59:40 moode upmpdcli[1008]: CMDTALK: tidal-app.py: browse: [{u'cmdtalk😛roc': 'browse', u'flag': 'children', u'objid': '0$tidal$'}]
Mar 25 14:59:57 moode upmpdcli[1008]: Dispatching to 'root', args: {}
Mar 25 15:00:04 moode upmpdcli[1008]: :2:src/mediaserver/contentdirectory.cxx:429::ContentDirectory::actSearch: Can't search in root. Substituting last browsed contain$
Mar 25 15:00:04 moode upmpdcli[1008]: CMDTALK: tidal-app.py: pCmdTalkProcessor.process: [{u'objkind': 'artist', u'value': 'p', u'cmdtalk😛roc': 'search', u'field': 'tr$
Mar 25 15:00:04 moode upmpdcli[1008]: CMDTALK: tidal-app.py: search: [{u'objkind': 'artist', u'value': 'p', u'cmdtalk😛roc': 'search', u'field': 'track', u'objid': '0$$
Mar 25 15:00:11 moode upmpdcli[1008]: :2:src/mediaserver/contentdirectory.cxx:429::ContentDirectory::actSearch: Can't search in root. Substituting last browsed contain$
Mar 25 15:00:11 moode upmpdcli[1008]: CMDTALK: tidal-app.py: pCmdTalkProcessor.process: [{u'objkind': 'artist', u'value': 'p', u'cmdtalk😛roc': 'search', u'field': 'tr$
Mar 25 15:00:11 moode upmpdcli[1008]: CMDTALK: tidal-app.py: search: [{u'objkind': 'artist', u'value': 'p', u'cmdtalk😛roc': 'search', u'field': 'track', u'objid': '0$$
Mar 25 15:00:16 moode upmpdcli[1008]: :2:src/mediaserver/contentdirectory.cxx:429::ContentDirectory::actSearch: Can't search in root. Substituting last browsed contain$
Mar 25 15:00:16 moode upmpdcli[1008]: CMDTALK: tidal-app.py: pCmdTalkProcessor.process: [{u'objkind': 'album', u'value': 'p', u'cmdtalk😛roc': 'search', u'field': 'tra$
Mar 25 15:00:16 moode upmpdcli[1008]: CMDTALK: tidal-app.py: search: [{u'objkind': 'album', u'value': 'p', u'cmdtalk😛roc': 'search', u'field': 'track', u'objid': '0$t$
Mar 25 15:00:16 moode upmpdcli[1008]: CMDTALK: tidal-app.py: processmessage: processor raised: [local variable 'searchresults' referenced before assignment]
Mar 25 15:00:16 moode upmpdcli[1008]: :2:src/mediaserver/cdplugins/plgwithslave.cxx:651:😛lgWithSlave::search: slave failure
Mar 25 15:00:16 moode upmpdcli[1008]: CMDTALK: tidal-app.py: pCmdTalkProcessor.process: [{u'objkind': 'artist', u'value': 'pretty ', u'cmdtalk😛roc': 'search', u'field$
Mar 25 15:00:16 moode upmpdcli[1008]: CMDTALK: tidal-app.py: search: [{u'objkind': 'artist', u'value': 'pretty ', u'cmdtalk😛roc': 'search', u'field': 'track', u'objid$
Mar 25 15:00:23 moode upmpdcli[1008]: :2:src/mediaserver/contentdirectory.cxx:429::ContentDirectory::actSearch: Can't search in root. Substituting last browsed contain$
Mar 25 15:00:23 moode upmpdcli[1008]: CMDTALK: tidal-app.py: pCmdTalkProcessor.process: [{u'objkind': 'track', u'value': 'pretty ', u'cmdtalk😛roc': 'search', u'field'$
Mar 25 15:00:23 moode upmpdcli[1008]: CMDTALK: tidal-app.py: search: [{u'objkind': 'track', u'value': 'pretty ', u'cmdtalk😛roc': 'search', u'field': 'track', u'objid'$
Mar 25 15:00:23 moode upmpdcli[1008]: CMDTALK: tidal-app.py: processmessage: processor raised: [local variable 'searchresults' referenced before assignment]
Mar 25 15:00:23 moode upmpdcli[1008]: :2:src/mediaserver/cdplugins/plgwithslave.cxx:651:😛lgWithSlave::search: slave failure
Code:
	Host name	= moode
	SoC 		= BCM2835
	CORES		= 4
	ARCH		= armv7l
	KERNEL		= 4.9.79-v7+
	Warranty	= OK
	ROOT size	= 15G
	ROOT used 	= 15%
	ROOT avail	= 12G
	MEM free 	= 591 MB
	MEM used 	= 58 MB
	MPD SCHDPOL	= TS
	P3-WIFI		= On
	P3-BT		= On
	HDMI		= On
	ETH0 CHECK	= On
	MAX USB CUR	= Off
	UAC2 FIX	= Off
	SSH server	= Off
	LED0		= on
	LED1		= on
	PHP-FPM		= 7.0.27
	NGINX		= 1.10.3
	SQLite		= 3.16.2
	Bluetooth	= 5.43
	  C P U    L O A D
	CPU	%usr	%sys	%idle
	all	0.00	0.50	99.50
	0	0.00	0.00	100.00
	1	0.00	0.00	100.00
	2	0.00	1.00	99.00
	3	0.00	1.00	99.00
	 29      - mpd              2.2   1 13.5
	 19      - sshd             0.6   1  0.4
	 19      - bash             0.4   0  0.4
	 19      - sudo             0.3   1  0.3
	SD card	= 50 MHz
	core			= 1.3250V
	sdram I/O		= 1.2000V
	Theme			= Standard
	Alpha blend		= 1.00
	Interface		= I2S
	Hdwr volume		= 100
	Mixer name		= Master
	Volume knob		= 4
	Volume mute		= Off
	Volume limit		= 60
	Squeezelite		= Off
	UPnP renderer		= Off
	DLNA server		= Off
	Crossfeed		= Off
	Parametric EQ		= Off
	Graphic EQ		= Off
	Auto-shuffle		= Off
	Autoplay		= Off
	MPD crossfade		= Off
	Version			= 0.20.12
	ALSA device		= hw:0
	Replay gain		= off
	Version			= 3.1.7
	ALSA device		= hw:0
	Volume mixer		= auto
	ALSA device		= hw:0
	Task priority		= 45
	  M O O D E    L O G
Code:
	Host name	= moode
	SoC 		= BCM2835
	CORES		= 4
	ARCH		= armv7l
	KERNEL		= 4.9.79-v7+
	Warranty	= OK
	ROOT size	= 15G
	ROOT used 	= 15%
	ROOT avail	= 12G
	MEM free 	= 582 MB
	MEM used 	= 64 MB
	MPD SCHDPOL	= TS
	P3-WIFI		= On
	P3-BT		= On
	HDMI		= On
	ETH0 CHECK	= On
	MAX USB CUR	= Off
	UAC2 FIX	= Off
	SSH server	= Off
	LED0		= on
	LED1		= on
	PHP-FPM		= 7.0.27
	NGINX		= 1.10.3
	SQLite		= 3.16.2
	Bluetooth	= 5.43
	  C P U    L O A D
	CPU	%usr	%sys	%idle
	0	0.00	0.00	100.00
	1	0.00	0.00	100.00
	2	0.00	0.00	100.00
	3	0.00	0.00	100.00
	 29      - mpd              2.9   1 12.9
	 19      - sudo             0.3   2  0.5
	SD card	= 50 MHz
	core			= 1.3250V
	sdram I/O		= 1.2000V
	Theme			= Standard
	Alpha blend		= 1.00
	Interface		= I2S
	Hdwr volume		= 100
	Mixer name		= Master
	Volume knob		= 10
	Volume mute		= Off
	Volume limit		= 60
	Squeezelite		= Off
	UPnP renderer		= Off
	DLNA server		= Off
	Crossfeed		= Off
	Parametric EQ		= Off
	Auto-shuffle		= Off
	Autoplay		= Off
	MPD crossfade		= Off
	Version			= 0.20.12
	ALSA device		= hw:0
	Replay gain		= off
	Version			= 3.1.7
	ALSA device		= hw:0
	Volume mixer		= auto
	ALSA device		= hw:0
	Task priority		= 45
	  M O O D E    L O G
Thx so much!
I don't see anything suspicious in the Sysinfo output so not really sure whats going on but the UI symptoms suggest that MPD has crashed. Maybe take a look at MPD log for an indication of what might be going on.
-Tim
Works ok here on my end.
pi@rp3:~ $ sudo git clone https://@opensourceprojects.eu/git/p/libupnppsamples/code libupnppsamples-code
Cloning into 'libupnppsamples-code'...
remote: Counting objects: 62, done.
remote: Compressing objects: 100% (62/62), done.
remote: Total 62 (delta 19), reused 0 (delta 0)
Unpacking objects: 100% (62/62), done.
pi@rp3:~ $
Here is the URL. Just remove the space between the https:// and the @ sign
https:// @opensourceprojects.eu/git/p/libupnppsamples/code libupnppsamples-code
You can post accurate urls by disabling the parse ‘feature’
I just could not reproduce this, unfortunately on holiday for a couple of days so will not be able to look again for perhaps a week or so. The only thing I could think of iis that I have built the latest release
@Mars67, @Serverbaboon
@Serverbaboon's conjecture is spot on.
With stock moOde r40, BubbleUPnP failed when I tried to browse Tidal Playlists. Once I overwrote /usr/share/upmpdcli/cdplugins/tidal/tidalapi/__init__.py with the latest __init__.py this problem went away.
Even so, when I tried to search in the ways @Mars67 indicated, I repro'ed the the failure he reported.
I then cloned the git repo for upmpdcli and replicated what mosbuild_worker.sh does by changing to the repo's top-level directory ./upmpdcli-code and running through the usual steps of
Code:
./autogen.sh
./configure --prefix=/usr --sysconfdir=/etc
make
sudo make install
The configuration file loaded in the moOde build process and managed by the moOde UI, /etc/upmpdcli.conf, was not overwritten but for some reason I found its permissions set to 600 which prevents upmpdcli from starting and spawning a second process so I changed them to 644.
I rebooted moOde and now I can search Tidal content to my heart's content using BubbleUPnP.
YMMV
Kent
Code:
./autogen.sh
make
sudo make install
YMMV
Kent
how to do it ?
Give instructions for beginners
Code:
./autogen.sh
make
sudo make install
YMMV
Kent
@Kent
The make install does the permission thing, it was an attempt by the developer to improve the security by only allowing the upmpdcli user to read the config file. As you stated this does not work in the case of Moode.
He did say that he would be doing another release soon so was hoping I could just give out the repository addition steps to upgrade rather than the build steps.
As a matter of interest did you use automake and did you have to apt-get install it? I have lost track whether it's required.
Steve
@Kent
Steve
Hi, Steve.
I just repeated the steps taken in mosbuild_worker.sh, as I outlined. All the necessary tools are already present because of prior steps.
@Rucia1
I'm on my way to a birthday party. I'll post a more detailed description either tonight or tomorrow morning.
Kent
I am using two streamers with Moode (old 4.0 beta with LL and RT kernels), one with pi3-Digi+ Pro-i2s-Buffalo DAC and second with Pi3-Dac+pro (with three dedicated ps).
IMHO the best sound with i2s Buffallo is with LL kernel, the best sound from Dac+ Pro is with RT kernel. Is there any chance to get at least LL and maybe RT kernel back in Moode ? Without support, just as an option. I tried official 4.0, now i am back with 4 beta ...
Moode has more and more options, but finally most important is the sound quality and IMHO older Moode with LL and RT delivered the best sound quality, better than any other pi players, which i tested.
-Tim
Sweet. Thanks for you prompt response so far. Here is the log before turning the equalizer on and after a reboot:
Code:
pi@moode:~ $ cat /var/log/mpd/log
Mar 25 12:24 : player: played "NAS/OMV/Billy Joel - The Stranger (Legacy Edition)/7 - Billy Joel - She's Always a Woman.flac"
Mar 25 14:48 : exception: Failed to open "ALSA default" [alsa]
Mar 25 14:48 : exception: nested: Failed to open ALSA device "hw:0,0": Device or resource busy
Mar 25 14:48 : player: problems opening audio device while playing "NAS/OMV/James Taylor - Greatest Hits/1 - James Taylor - Something In The Way She Moves.flac"
Mar 25 14:49 : player: played "NAS/OMV/James Taylor - Greatest Hits/1 - James Taylor - Something In The Way She Moves.flac"
Mar 25 14:49 : exception: Failed to open "ALSA default" [alsa]
Mar 25 14:49 : exception: nested: Failed to open ALSA device "hw:0,0": Device or resource busy
Mar 25 14:49 : player: problems opening audio device while playing "NAS/OMV/James Taylor - Greatest Hits/1 - James Taylor - Something In The Way She Moves.flac"
Mar 25 14:53 : player: played "NAS/OMV/James Taylor - Greatest Hits/1 - James Taylor - Something In The Way She Moves.flac"
Mar 25 14:57 : player: played "NAS/OMV/James Taylor - Greatest Hits/2 - James Taylor - Carolina In My Mind.flac"
Mar 25 15:00 : player: played "NAS/OMV/James Taylor - Greatest Hits/3 - James Taylor - Fire And Rain.flac"
Mar 25 15:03 : player: played "NAS/OMV/James Taylor - Greatest Hits/4 - James Taylor - Sweet Baby James.flac"
Mar 25 15:06 : player: played "NAS/OMV/James Taylor - Greatest Hits/5 - James Taylor - Country Road.flac"
Mar 25 15:11 : player: played "NAS/OMV/James Taylor - Greatest Hits/6 - James Taylor - You've Got A Friend.flac"
Mar 25 15:13 : player: played "NAS/OMV/James Taylor - Greatest Hits/7 - James Taylor - Don't Let Me Be Lonely Tonight.flac"
Mar 25 15:17 : player: played "NAS/OMV/James Taylor - Greatest Hits/8 - James Taylor - Walking Man.flac"
Mar 25 15:20 : player: played "NAS/OMV/James Taylor - Greatest Hits/9 - James Taylor - How Sweet It Is (To Be Loved By You).flac"
Mar 25 15:23 : player: played "NAS/OMV/James Taylor - Greatest Hits/10 - James Taylor - Mexico.flac"
Mar 25 16:00 : player: played "NAS/OMV/James Taylor - Greatest Hits/11 - James Taylor - Shower The People.flac"
Here is the log after turning on EQ. After clicking the set button, I also tried restarting MDP:
Code:
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/11 - James Taylor - Shower The People.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/11 - James Taylor - Shower The People.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/11 - James Taylor - Shower The People.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/12 - James Taylor - Steamroller.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/12 - James Taylor - Steamroller.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/12 - James Taylor - Steamroller.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/1 - James Taylor - Something In The Way She Moves.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/1 - James Taylor - Something In The Way She Moves.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/1 - James Taylor - Something In The Way She Moves.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/2 - James Taylor - Carolina In My Mind.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/2 - James Taylor - Carolina In My Mind.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/2 - James Taylor - Carolina In My Mind.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/3 - James Taylor - Fire And Rain.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/3 - James Taylor - Fire And Rain.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/3 - James Taylor - Fire And Rain.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/4 - James Taylor - Sweet Baby James.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/4 - James Taylor - Sweet Baby James.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/4 - James Taylor - Sweet Baby James.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/5 - James Taylor - Country Road.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/5 - James Taylor - Country Road.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/5 - James Taylor - Country Road.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/6 - James Taylor - You've Got A Friend.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/6 - James Taylor - You've Got A Friend.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/6 - James Taylor - You've Got A Friend.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/7 - James Taylor - Don't Let Me Be Lonely Tonight.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/7 - James Taylor - Don't Let Me Be Lonely Tonight.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/7 - James Taylor - Don't Let Me Be Lonely Tonight.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/8 - James Taylor - Walking Man.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/8 - James Taylor - Walking Man.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/8 - James Taylor - Walking Man.flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/9 - James Taylor - How Sweet It Is (To Be Loved By You).flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/9 - James Taylor - How Sweet It Is (To Be Loved By You).flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/9 - James Taylor - How Sweet It Is (To Be Loved By You).flac"
Mar 25 23:09 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/10 - James Taylor - Mexico.flac
Mar 25 23:09 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/10 - James Taylor - Mexico.flac: No such file or directory
Mar 25 23:09 : player: played "NAS/OMV/James Taylor - Greatest Hits/10 - James Taylor - Mexico.flac"
Mar 25 23:10 : exception: Failed to decode /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/12 - James Taylor - Steamroller.flac
Mar 25 23:10 : exception: nested: Failed to open /var/lib/mpd/music/NAS/OMV/James Taylor - Greatest Hits/12 - James Taylor - Steamroller.flac: No such file or directory
Mar 25 23:10 : player: played "NAS/OMV/James Taylor - Greatest Hits/12 - James Taylor - Steamroller.flac"
Here's a screenshot of my MDP settings if that helps. Could it be the SoX settings?
________________________________________________________
UPDATE: After disabling SoX resampling and setting SoX quality to medium, it looks like the EQ is working. What was going on? Should I have SoX resampling off anyway?
Caution, NOOB question incoming ----> Doesn't SoX upsampling get me a higher sound quality? What should these setting be? Or what should they not be?
Thx again for your assistance! 🙂
