Mark Audio Alpair 10.3/A10p MLTL
Shirokuma,
Just to be sure that you have the design for my 10.3 MLTL please see the first post in this thread for my MLTL enclosure. In Post #7 of this thread I detail the change ( a port tube length difference) for the 10P variant.
I have several other MLTL designs and successful project builds on DIYAudio if you search. I am very confident that this design will please you.
Several members have in fact built the 10.3 MLTL design as you can discern when you read this thread.
Jim
Thanks alot Jim,
Really looking forward to this build. Recently fell in love with the sound of a full rullrange.
Just a small question about the port placement, 36" from top internal,... is that centre of the port? Front side?
Is it ok to round of the edges of the baffle (sides and top, just for the looks...) with a rooter or do I have to keep the edges scharp?
Shirokuma,
The port location is the center of the tube. The port can be located either on the front or rear of the enclosure. If the port is on the rear of the enclosure, you need to have some distance (say 0.33 meter or greater) between the box and the wall behind it.
It is OK to round the edges for both looks and function. A small round over is mainly for looks while a larger radius will reduce small ripples in the higher frequency response curve. My prototype MLTL models all have a modest round over as larger round overs would necessitate thicker wall material than the normal 18 mm thickness I use.
Jim
