Dear Apex Sir please check and confirm this layout is correct or need any rectification.
Thanks & Regards
Anand Kumar
cont: +918318685681(India)
no chance that anyone except layout designer should or will tell you if it is right or not. I believe that apexaudio is not a designer of this layout...
liempoo layout
liempoo layout
in this layout c4793 base connected with hv through 100r .is this ok?
HI ... it's not the base but its the emitter with 100R to HV...
thanks but i think this is mirror of pcb if not then how you attach with heat sink?
[/QUOTE]just need to use the holes on the board to fasten the screws on the heatsink,,,
just need to use the holes on the board to fasten the screws on the heatsink,,,[/QUOTE]
best worst idea.
H900 with MJL4281/4302 .Test voltage 0 40 80 dc.sound good .I have test with 2ohms .
don't be crazy young man we respect your skill but don't try these amp in 2ohm in field .
I have tested it in high volume in 2ohms load .My DC voltage was +80 +40 0 -40 -80 sir.
Hello.. if you are interested... check out this modified version.
password please h900 zip with protectpassword please,..........!!!thank's
3 step tier
Hello Sir Mile... how are you? Hoping you can help me out for the 3 step tier. I am planning to try and use this option. With the schematic... which is the proper one for the R14 & R15 connection? thanks and regards
Greetings sir Tony and all diyer.
I want to ask u something sir..
What is the difference between diode zy15 and zf15.
Any help is greatly appreciated
sorry for this silly question and my bad english, im using g. Translate.
Regards.
ZY15 is 15V 1.3W
ZF15 is 15V 400mW
ZF15 is 15V 400mW
Regards.
- 900W H-class PA Amp with Limiter
