Hello. I work with amplifier 4000.1. Driver board, part of the circuit and oscillogram attached. The problem is that the meander disappears at the output of LM311 when I solder the output 24N40F. Changed LM311, TL 072 and IR21844. What would you recommend?
On the filter inductor voltmeter shows minus 1.6 Volt. The waveform at the same point applied.
Clarification: the first couple seconds of operation of the amplifier is a square wave at the output of the LM311 is present.
English is not my native language, sometimes I do not understand something about your questions. For example: "Do you have a rail-rail output on the output transistors at any time?" Do you mean to check the ripple on the rails plus and minus the output transistors? If not, please ask otherwise. I hope for your understanding
Go the following location on the basic repair page. If it does not load the r-r oscillation section, simply reload the page.
Basic Amplifier Repair
Do you get rail to rail oscillation on the output transistors with the output transistors in the circuit?
No. Only DC +/- 104Volt (divider by 10 is switched )
Sometimes, the tv sync can make the scope trigger when nothing else helps.
You should see something like you saw in the r-r section of the basic repair page. Right now, it's showing that you have r-r oscillation but you need to determine why the scope won't trigger. If you have a switchable probe, set it to 10x and set the scope vertical amp to 1x.
- General Interest
- Car Audio
- 4000.1
