Moode Audio Player for Raspberry Pi
trying to expand the root partition.
Clicking EXPAND doesn't trigger anything.
am using 32G uSD with 3G occupied.
any suggestion?
You should see the confirmation popup after clicking Expand. After clicking Confirm, the message below should appear and then the system will automatically reboot.
FS expansion job submitted
Reboot initiated
-Tim
Have finally upgraded my main RPi (Pi 3b) to 4.0. Only broke the process once, due to seriously dumb mistake, aka switching off lights for the evening that had the Pi power supply on same power strip. Doh!
Everything looks and runs great, with a few issues. I'm liking an apparent improvement of response over all, seems snappier now. I also had some crackle and pops in my set up, started w 3.84 and didn't quite go away in 4.0 b12, seems very solid now.
So, on to the few issues...
1. I occasionally lose some display features, the time ring will not be there, or sometimes the entire playlist isn't visible in playlist page. Also, lately have been seeing most or all of these appearing properly, but no pic for the radio station playing. My playlist load so far has only consisted of radio stations. I've fiddled with various things, reloading, going to other pages and returning... sometime it comes back, sometimes not. Not sure of a single fix yet.
2. More a feature change opinion than a problem, I'm finding the volume control a bit of an issue in that I miss the bump up/down buttons, which were handy for fine adjustments without accidental large motions. And I like the new slider bar, but I don't like the "no change till you let go and drop it" feature. Very difficult to judge how much change you made, especially on a small phone screen. Is the "drag around the circular volume indicator" no longer available? That used to be a smooth transition, with the occasional user issue of hitting the wrong side and blasting a high volume.
Most of the things in 1 have been seen on Firefox on my Android phone, otherwise I'm on Firefox on Win 10. I have seen 1 problems on the phone, and seen normal operation on the Win 10 browser.
Hope that helps...
I agree about the usefulness of the volume bump up/dn buttons. Maybe adding them back in under the slider would work.
-Tim
Hi Tim, as a compromise to the data nerds among us, me being one, could the "System Information" page be made directly accessible from the "Moode" menu rather than having to go to it via a configuration page. This should avoid about 4 clicks to find the cpu temperature.
If the cpu temperature could be moved up a bit on the page so it is visible on the rpi display without scrolling that would also be good from my perspective.
I also noticed the "Customise" option disappears form the "Moode" menu after the "Configuration" option is clicked. I assume this is intentional but it is not intuitive that to get it back, you need to click on one of the buttons on the bottom of the display to reset the menus.
Hi Tim, just a friendly bump of the idea of having the System Information page accessible from the Moode menu without having to go to a Config page.
but there are also no dots ...
There aren't any line separators anywhere in NewUI 🙂
-Tim
Hi Tim,
ok ... no lines anymore, but there are also no dots on the right side of "Browse"-tab. Not possible to call "Add", "Play" or "Clear/Play" anymore ???
At the moment I only can play music from "Library"-tab (Firefox & Chrome). In Safari (iPad) I see only "white pages" on all tabs, except "Configure"screens. MMI customize setting is all standard.
Not good ...
Hi Tim,
Not good ...
Just click the icons on the far Left and the popup menu will appear.
Very odd about Safari and iPad because I develop and test moOde on Safari, Mac, iPad and iPhone.
-Tim
Thats odd. Connect both USB drives, reboot and then post the output from cmds below and I'll have a look.
cat /var/log/moode.log
ls -l /media
-Tim
Thanks Tim.
Here are the outputs
login as: pi
pi@192.168.1.199's password:
Linux kernel 4.9.78-v7+ running on armv7l architecture
____ __
__ _ ___ / __ \___/ /__
/ ' \/ _ \/ /_/ / _ / -_)
/_/_/_/\___/\____/\_,_/\__/
moOde audio player
(C) 2014 Tim Curtis
The programs included with Moode are free software; the
exact distribution terms for each program are described
in the individual files in /usr/share/doc/*/copyright.
Moode comes with absolutely no warranties expressed or
implied, or any other guarantees.
Last login: Sat Feb 10 21:45:20 2018 from 192.168.1.5
pi@moode:~ $ cat /var/log/moode.log
20180210 232730 worker: - Start
20180210 232730 worker: Successfully daemonized
20180210 232730 worker: - Init
20180210 232730 worker: Session loaded
20180210 232730 worker: Debug logging (off)
20180210 232733 worker: Host (moode)
20180210 232733 worker: Hdwr (Pi-3B 1GB v1.2)
20180210 232733 worker: Arch (armv7l)
20180210 232733 worker: Kver (4.9.78-v7+)
20180210 232733 worker: Ktyp (Standard)
20180210 232733 worker: Gov (performance)
20180210 232733 worker: Rel (Moode 4.0 2018-01-26)
20180210 232733 worker: Upd (None)
20180210 232733 worker: MPD (0.20.12)
20180210 232733 worker: USB boot not enabled yet
20180210 232733 worker: File system not expanded yet
20180210 232733 worker: HDMI port on
20180210 232734 worker: File check ok
20180210 232734 worker: - Network
20180210 232734 worker: eth0 exists
20180210 232734 worker: eth0 address not assigned
20180210 232734 worker: wlan0 exists
20180210 232734 worker: wlan0 trying SSID (DangerousDevil)
20180210 232734 worker: wlan0 (192.168.1.199)
20180210 232735 worker: - Audio
20180210 232735 worker: ALSA outputs unmuted
20180210 232735 worker: Audio out (I2S audio device)
20180210 232735 worker: Audio dev (Allo Boss DAC)
20180210 232735 worker: ALSA mixer name (Digital)
20180210 232735 worker: MPD volume control (software)
20180210 232735 worker: Hdwr volume controller exists
20180210 232736 worker: Chip options (Burr Brown PCM5122)
20180210 232736 worker: - Services
20180210 232738 worker: MPD started
20180210 232738 worker: MPD scheduler policy (time-share)
20180210 232738 worker: MPD output 1 ALSA default (on)
20180210 232738 worker: MPD output 2 ALSA crossfeed (off)
20180210 232738 worker: MPD output 3 ALSA parametric eq (off)
20180210 232738 worker: MPD output 4 ALSA graphic eq (off)
20180210 232738 worker: MPD crossfade (off)
20180210 232738 worker: Shellinabox SSH server started
20180210 232738 worker: - Last
20180210 232738 worker: USB sources (Seagate Expansion Drive)
20180210 232738 worker: NAS sources (mountall initiated)
20180210 232739 worker: Volume level (64) restored
20180210 232739 worker: Maintenance interval (21600)
20180210 232739 worker: Watchdog started
20180210 232739 worker: Ready
pi@moode:~ $ ls -l /media
total 8
drwxr-xr-x 1 root root 4096 Mar 8 2015 Seagate Expansion Drive
drwxr-xr-x 1 root root 4096 Nov 29 2015 SONY HD-E2
pi@moode:~ $
Hi Matteo,
Reboot and post output from moode log and I'll have a look.
cat /var/log/moode/log
-Tim
Hi Tim,
this is the log.
I'm using a pi zero w with alientek d8 connected by usb cable.
Thank you
Matteo
20180211 134538 worker: - Start
20180211 134538 worker: Successfully daemonized
20180211 134538 worker: - Init
20180211 134539 worker: Session loaded
20180211 134539 worker: Debug logging (off)
20180211 134542 worker: Host (moode)
20180211 134542 worker: Hdwr (Pi-Zero W 512MB v1.1)
20180211 134542 worker: Arch (armv6l)
20180211 134542 worker: Kver (4.9.79+)
20180211 134542 worker: Ktyp (Standard)
20180211 134542 worker: Gov (performance)
20180211 134542 worker: Rel (Moode 4.0 2018-01-26)
20180211 134542 worker: Upd (None)
20180211 134542 worker: MPD (0.20.12)
20180211 134542 worker: USB boot not enabled yet
20180211 134542 worker: File system expanded
20180211 134543 worker: HDMI port on
20180211 134544 worker: File check ok
20180211 134544 worker: - Network
20180211 134544 worker: eth0 does not exist
20180211 134544 worker: eth0 address not assigned
20180211 134544 worker: wlan0 exists
20180211 134544 worker: wlan0 trying SSID (G&M)
20180211 134544 worker: wlan0 (192.168.1.190)
20180211 134544 worker: - Audio
20180211 134545 worker: ALSA outputs unmuted
20180211 134545 worker: Audio output (USB audio device)
20180211 134545 worker: ALSA mixer name (Mic)
20180211 134545 worker: MPD volume control (disabled)
20180211 134545 worker: Hdwr volume controller exists
20180211 134545 worker: - Services
20180211 134548 worker: MPD started
20180211 134548 worker: MPD scheduler policy (time-share)
20180211 134548 worker: MPD output 1 ALSA default (on)
20180211 134548 worker: MPD output 2 ALSA crossfeed (on)
20180211 134548 worker: MPD output 3 ALSA parametric eq (on)
20180211 134548 worker: MPD output 4 ALSA graphic eq (on)
20180211 134548 worker: MPD crossfade (off)
20180211 134548 worker: - Last
20180211 134548 worker: USB sources (none attached)
20180211 134548 worker: NAS sources (mountall initiated)
20180211 134548 worker: Volume level (0) restored
20180211 134548 worker: Auto-playing id ()
20180211 134548 worker: Maintenance interval (21600)
20180211 134548 worker: Watchdog started
20180211 134548 worker: Ready
Thanks Tim.
login as: pi
____ __
moOde audio player
(C) 2014 Tim Curtis
total 8
pi@moode:~ $
The output looks ok except for a bug in moode logging that only lists the first usb drive. Both drives were auto-mounted to /media. If only one of the drives shows up in MPD database then it could be a permissions issue.
Examine MPD log for errors.
cat /var/log/mpd/log
-Tim
