900W H-class PA Amp with Limiter
Hi sir stewin, in your post #3597 can I put resistor in parallel with MUR810 (ex: 10K, 2watts) to serve as load resistance of IRF540 with respect to +MV? this will ensure that the voltage at +DMV will rise close to +HV when IRF540 switches ON. Without load resistance the voltage at +DMV will be undefined due to the collectors of C3856 acting as current sink and the IRF540 as current source in my opinion, am I correct?
hi guys,sir miles
just want to know if i can use the step drive schematics of vertex 3 tier using 0-42-94-142 dc split power supply from jbl mpx1200 transformer with 4 pairs of mjl21195/96 output devices?did someone here try 3 tier supply in h900?hoping somebody can help me this? thanks in advance!!
Merry Christmass and Happy new year to all!!
I will post schematic for PSU and protect soon.
Full power of this amplifier is not 900W. Power with THD 0,5% is 1200W on 4R load, and 1800W on 2R load. Output transistor must be MJL4281A/MJL4302A for maximum power. For step mosfet use IRF2807. MJL21193/MJL21194 can be used for full power on 4R load.
Transformer minimum 1500VA for one channel 4X40V AC + 2X20V for protection circuit. 2X35A bridge and 8X100
00uF/63V for PSU... are you still interesting to build this amplifier?
sir,can I replace 2pair IRF 2807 instead of IRF540??my outputs are MJL4281/4302 total 4 pair.Rail voltage is 4*40v ac..and can i bridge it with this rail voltage ??my subwoofer is 1500watt RMS 8 ohms .is it perfect for my subs??And Thank you for B500 it's nice amp.
