A Thread for those interested in PPSL enclosures
Driver Properties
Type: Standard one-way driver
No. of Drivers = 2
Mounting = Standard
Wiring = Parallel
Fs = 40 Hz
Qms = 6.55
Vas = 220 liters
Cms = 0.212 mm/N
Mms = 74.71 g
Rms = 2.867 kg/s
Xmax = 7.5 mm
Xmech = 11.25 mm
P-Dia = 329.9 mm
Sd = 855 sq.cm
P-Vd = 0.641 liters
Qes = 0.32
Re = 5.5 ohms
Le = 1.42 mH
Z = 8 ohms
BL = 17.96 Tm
Pe = 400 watts
Qts = 0.305
no = 4.242 %
1-W SPL = 98.42 dB
2.83-V SPL = 100.1 dB
Box Properties
Name:
Type: Vented Box w/ Active HP Filter
Shape: Prism, square (optimum)
Vb = 6.6 cu.ft
Fb = 40 Hz
QL = 5.978
F3 = 40.04 Hz
Fill = minimal
No. of Vents = 2
Vent shape = other
Vent ends = one flush
Av = 38.23 sq.in
Lv = 12 in
Active 12 dB/oct. HP Filter
Fx = 40 Hz
Qx = 2
Hi Djk,
I decided to go with the PD.1550 specs you've provided rather than the Fane as I have 2 ready, but might hurt my pocket later on if I decided to expand to 4 cabinets.
I attached the link for the cabinet, if you have free time, please check the specs for any corrections.
External dimension L33 1/2" X H 21 5/8" X 23 5/8" (approx.) as it was drawn in metrics 85cm X 55cm x 60cm.
I will be using 18mm/13ply Russian Baltic Birch and will be built fully rebated.
[images removed]
Plus, I enclosed another 15" PPSL driver candidate, somehow similar with the OEM 15629 and Kappa Pro 15. maybe you can also provide the best cabinet dimension for this driver (15FH500).
FaitalPRO | LF Loudspeakers | 15FH500
Djk,
Will (2) Two PPSL 2X15" cabinets perfectly match (2) Two Sls920 per side outdoors?
Thanks.
Here's the PPSL 2 x 15" (for PD.1550)
- bracing wil be as described by Djk and wil have pocket handles.
- will utilise the PPSL upright for singles, sls920 pole mounted on top.
- external dimension H 550mm x W 850mm x D 605mm.
Thinking of building it in double baffles to add strength,
Any suggestions and comments will be appreciated.
Thanks.
I haven't read this entire thread, but this seems like a very intriguing design.
However, kind of large & heavy. Has anyone tried this in a 2 X 12", PPSL ?
Yes, and in this thread somewhere c/o Norman Bates, IIRC. They were Dayton drivers - I don’t think that particular model is still manufactured, however. I could be wrong - I didn’t see it on PE any longer last time I looked.
Edit: Norman’s POST - my mistake: 4 x 12”
