MPP
Any other low noise bipolar transistor can be used.
You can convert to npn transistors also:
- leave the circuit and transistor connections as they are,
- reverse polarity of both supplies in the schematic and
- reverse polarity of all electrolytic caps.
These hints are for the first picture in the linked article.
I use the zeetex low rbb transistors in a phono stage, but I have also used biss transistors.. somehow they tend to sound more crisp and direct. Jfets are dull and noisy but not leaking. A real issue with bjts are base current. I have solved this by running them in floating balanced inputs and then really make an effort to pair the input transistor-pair. I have also made a servoed version where I mirror in the driving currents of each transistor and then let ithe nput DC differential drive the currents. The bjts are so quiet that only one pair is needed
I did not find jfets to be dull.... and they do sound good if well used 🙂
I like the Pearl phono.... very good design.... maybe it could be improved with a good psu.
I am sure the psu is an integral part of any amp because it sings along with it.
I use a pair of jfets in the input of my phonostage... and it is quiet. 🙂
