900W H-class PA Amp with Limiter
Greetings mr,apex sir
i try to make your hx 900 problem on step driver positive side +55vdc and negative side-65vdc increased on full volume. my rail 109-59-0-59-109vdc
friends good morning I want to thank God and all for their contributions in this post of the apex h900 because thanks to all the friends that shared it was possible to join me with great satisfaction this amplifier and I was not any mishap at the moment of putting it to work
Hi friends I have build a h900 but facing some problem if I have on the power supply 100 ohms resistance start the burning near mje340
hi sir please take note that when going to supply power on the amp see to it that all transistors output and driver are on heatsink...mje340(bias ) adjust according to drivers and outputs transistor temperature,,,dont forget to put series bulb in main input supply to minimize damage on parts when there still problem,,,Goodluck...🙂
Thank you very many sir Apex. H900 is no joke. I just woke up a Peavey PV1500 power amp that uses +-90Vdc from a 65-0-65Vac toroid and 8 pair C5200nA1943 trannies both channel so 4C and 4A per channel. Was burnt beyond repair but i have a working channel H900 n modified the toroid for H Class. I am impressed by performance. Thanks Apex. Here are some pictures.
