Moode Audio Player for Raspberry Pi
Btw, I just uploaded a new ZIP and corrected the md5 hash. Please re-download!
rel-stretch.zip
f1f94898ee060df253d19bf0d3705d38
A way to avoid the Linux partition surgery in the first couple steps is to plug the USB stick into a Windows or Mac which should show the FAT32 boot partition. Create a file named ssh in this partition.
Remember, Stretch Lite does not ship with ssh enabled!
-Tim
rel-stretch.zip
-Tim
One other item is that Stretch Lite also ships with the new hashed network interface names and not good old eth0 and wlan0.
The cmd below from STEP 2 adds a setting that reverts to the familiar names. Or manually edit /boot/cmdline.txt
sudo sed -i "s/^/net.ifnames=0 /" /mnt/tmp1/cmdline.txt
-Tim
pi@moode:~ $ nano /var/log/moode.log
GNU nano 2.7.4 File: /var/log/moode.log Modified
20171102 112519 worker: Hdwr (Pi-3B 1GB v1.2)
20171102 112519 worker: Arch (armv7l)
20171102 112519 worker: Kver (4.9.59-v7+)
20171102 112519 worker: Ktyp (Standard)
20171102 112519 worker: Gov (performance)
20171102 112519 worker: OS (moodeOS deprecated)
20171102 112519 worker: Rel (Moode 4.0 2017-MM-DD)
20171102 112519 worker: Upd (None)
20171102 112519 worker: MPD (0.20.10)
20171102 112519 worker: USB boot not enabled yet
20171102 112519 worker: File system expanded
20171102 112519 worker: HDMI port on
20171102 112520 worker: File check ok
20171102 112520 worker: - Network
20171102 112520 worker: eth0 exists
20171102 112520 worker: eth0 (192.168.1.246)
20171102 112520 worker: wlan0 exists
20171102 112520 worker: wlan0 trying SSID (cheungtsw)
20171102 112520 worker: wlan0 (192.168.1.254)
20171102 112520 worker: - Audio
20171102 112520 worker: ALSA outputs unmuted
20171102 112520 worker: Audio output (On-board audio device)
20171102 112520 worker: ALSA mixer name (PCM)
20171102 112520 worker: MPD volume control (software)
20171102 112520 worker: Hdwr volume controller exists
20171102 112520 worker: - Services
20171102 112522 worker: MPD started
20171102 112522 worker: MPD scheduler policy (time-share)
20171102 112522 worker: MPD output 1 ALSA default (on)
20171102 112522 worker: MPD output 2 ALSA crossfeed (off)
20171102 112522 worker: MPD output 3 ALSA parametric eq (off)
20171102 112522 worker: MPD output 4 ALSA graphic eq (off)
20171102 112522 worker: MPD crossfade (off)
20171102 112522 worker: - Last
20171102 112522 worker: USB sources (none attached)
20171102 112523 worker: NAS sources (mountall initiated)
20171102 112523 worker: Volume level (51) restored
20171102 112523 worker: Watchdog started
20171102 112523 worker: Ready
S Y S T E M P A R A M E T E R S
Date and time = 2017-11-02 11:33:47
System uptime = up 8 minutes
Timezone = America/Detroit
moOde = Release 4.0, 2017-MM-DD
moodeOS = Version deprecated multi-kernel
Host name = moode
ETH0 IP = 192.168.1.246
ETH0 MAC = b8:27:eb:a1:a6:dd
WLAN0 IP = 192.168.1.254
WLAN0 MAC = b8:27:eb:f4:f3:88
HDWR REV = Pi-3B 1GB v1.2
SoC = BCM2835
CORES = 4
ARCH = armv7l
KERNEL = 4.9.59-v7+
KTIMER FREQ = 100 Hz
USB BOOT = not enabled
Warranty = OK
ROOT size = 29G
ROOT used = 6%
ROOT avail = 26G
FS expand = expanded
MEM free = 612 MB
MEM used = 59 MB
Temperature = 43.5°C
CPU GOV = performance
MPD SCHDPOL = TS
P3-WIFI = On
P3-BT = On
HDMI = on
ETH0 CHECK = On
MAX USB CUR = Off
UAC2 FIX = On
SSH server = Off
LED0 = on
LED1 = on
C O R E S E R V E R S
PHP-FPM = 7.0.19
NGINX = 1.10.3
SQLite = 3.16.2
Bluetooth = 5.43
C P U L O A D
CPU %usr %sys %idle
all 0.13 0.00 99.87
0 0.50 0.00 99.50
1 0.00 0.00 100.00
2 0.00 0.00 100.00
3 0.00 0.00 100.00
P R O C E S S L O A D
PRI RTPRIO COMMAND %MEM PSR %CPU
19 - sysinfo.sh 0.2 0 1.3
19 - systemd 0.6 1 0.5
29 - mpd 2.9 1 0.4
19 - sudo 0.3 1 0.3
19 - worker.php 1.1 2 0.2
19 - cifsd 0.0 0 0.2
19 - systemd-journal 0.4 3 0.1
19 - systemd-udevd 0.3 0 0.1
19 - kthreadd 0.0 1 0.0
C L O C K F R E Q U E N C I E S
arm = 1200 MHz pwm = 0 MHz
core = 400 MHz emmc = 249 MHz
h264 = 300 MHz pixel = 148 MHz
isp = 300 MHz vec = 0 MHz
v3d = 300 MHz hdmi = 163 MHz
uart = 47 MHz dpi = 0 MHz
SD card = 50 MHz
S Y S T E M V O L T A G E S
core = 1.2688V
sdram controller = 1.2000V
sdram I/O = 1.2000V
sdram chip = 1.2250V
/var/www/command/sysinfo.sh: line 57: squeezelite-armv7l: command not found
/var/www/command/sysinfo.sh: line 58: squeezelite-armv7l: command not found
/var/www/command/sysinfo.sh: line 65: shairport-sync: command not found
U I C U S T O M I Z A T I O N S
Theme color = Emerald
Playback history = No
Extra metadata = Yes
Library = Use Artist
A U D I O P A R A M E T E R S
Audio device = USB audio device
Interface = On-board
Hdwr volume = 65
Mixer name = PCM
Output stream = S16_LE / 44100
ALSA version = 1.1.3-5+rpi3
SoX version = 0.1.2-2
Volume knob = 51
Volume mute = Off
Volume limit = 80
Airplay receiver = Off
Bluetooth controller = Off
Squeezelite = Off
UPnP renderer = Off
DLNA server = Off
Rotary encoder = Off
Encoder params = 100 2 3 4 5
Crossfeed = Off
Parametric EQ = Off
Graphic EQ = Off
Auto-shuffle = Off
Autoplay = Off
MPD crossfade = Off
M P D S E T T I N G S
Version = 0.20.10
Volume control = software
ALSA device = hw:0
SoX resampling = disabled
SoX quality = very high
SoX multithreading = off
Audio buffer (kb) = 4096
Buffer before play = 10%
Output buffer size (kb) = 81920
Volume normalization = no
DSD over PCM (DoP) = no
Replay gain = off
A I R P L A Y S E T T I N G S
Version =
Friendly name = Moode Airplay
Metadata display = Off
ALSA device = hw:0
Volume mixer = auto
Resume MPD after = No
Output bit depth = S16
Output sample rate = 44100
Session interruption = no
Session timeout (ms) = 120
Audio buffer (secs) = 0.0
S Q U E E Z E L I T E S E T T I N G S
Version = "DSD/SRC disabled"
ALSA device = hw:0
ALSA params = 80:4::1
Output buffers = 40000:100000
Task priority = 45
Codec list = flac,pcm,mp3,ogg,aac,alac,dsd
Other options = -W -D 500 -R E
M O O D E L O G
20171102 112517 worker: - Start
20171102 112517 worker: Successfully daemonized
20171102 112517 worker: - Init
20171102 112517 worker: Session loaded
20171102 112517 worker: Debug logging (off)
20171102 112519 worker: Host (moode)
Close
From the GUI itself
pi@moode:~ $ cat /var/log/moode.log
Thanks :) The line below indicates On-board audio and not USB audio.
Go into MPD SETTINGS, set Audio output to "USB audio device" and then APPLY.
-Tim
