I really like that the review has no date that I could find.
6 moons is often good for at least a chuckle or two.
Alan
Alan
Seems like 2008/9 era. To bad this guy got sick, but it shows a side of the underground of virtually one-off components, when the one guy goes it's gone. That thing looked cobbled together from very expensive parts.
Chances are very high that using a spec-an wasn't considered. It's an expensive instrument and knowing how to use one generally precludes flaky design practices.
-Chris
-Chris
Besides, spectrum analysis isn't nearly as sexy as those c**k rings on the preamp tubes. That thing is good to go.
More wasted time... 6moons audio reviews: APL HiFi NWO 3.0-GO
But do read the postscript.
My Bybee has been shipped, I can't wait. 😉
Scott I'll send you a Bybee. I am repairing a preamp that someone modified. They decide they needed a little black magic and installed ByBees on the balanced inputs in series with pin 1. They also installed them on the balanced output but put them in series with pin 2. I think they meant to put them on pin 1 again but struggled to figure out which was the correct pin.
Anyway out they came. Can't have black magic in my electronics.
Thanks for the digital reviews, guys! I can learn from people who are both technical, listen intensively, AND are not so cheap that they cannot consider expensive components as better than typical ones. This Reference Components guy is helpful.
Jim, it is only sad for you when you cannot badmouth someone else and get agreement from others like me. '-)
Hi John,
Pretty much every time I test an expensive audiophile approved part, I can find the same or better in normal industrial parts. That is both measuring different parameters and listening to the darned things.
It should be noted that the normal parts are considerably smaller than the special parts are. When I strip the silly parts out and install the (usually) better parts, a couple things tend to happen. Firstly the chassis looks neater as these parts actually fit. This may be more important than you think! Secondly, the customer tends to fall in love with their "de-audiophilized" device.
Cleaning up after someone who installs these large parts is frustrating. They often destroy plated through holes - and that leads to either a fault or intermittent operation. The other issue is getting rid of literal gobs of silicone or hot glue so you can work on the PCB. I like the special neat guys who thoughtfully drill out the plated through holes. This is especially nice when a trace has a hole in it as it travels by. The hole typically interrupts these traces completely. Lots of repair work. Occasionally I get a unit that is too damaged to be made reliable again at sane money. Those I have to write-off.
Internet modders cause a ton of damage without knowing it. I wish these folks would stick to something they have a good understanding of (really know, not think they know).
-Chris
-Chris
Yeah - keep telling yourself that, I guess.
Hey Chris, i get just about the same experience...
many times a gear is brought to me that after putting in botique parts are really screwed up in terms of looks and sound...
most of the time i politely turn it down as i would not want to have anything to do with it after another has screwed it up...to me it is not about the money....
i usually tell them, if they wanted botique parts, do it right the first time by incorporating the parts of their choice at the start....the one thing i hate is tamper with a good working unit....
😀 Holy crap, that's hilarious. 😀
Sounds like a pin 1 problem.
I like that he spars with both sides, Charles Hansen as well as several reviewers. I also notice none of your stuff gets much (any?) mention. He makes very clear that audio is science but does not seem to have much interest in the scientific method. He also espouses the idea that maximum power efficiency is obviously the ideal situation (intuitively) even though there is no scientific basis for this.
I appreciate the thought, but let me stick with my program for now. I don't want this to get out of hand.
Hi Scott,
You could throw a bunch in the bottom of the chassis to make it heavier.
I wouldn't mind sticking one on the HP 4195A that I have to see what it says about it. I have a 500 MHz playground to study it in. Surely that is enough range to see if there are any effects that could possibly affect an audio component. Of course, to be honest, a 100KHz bandwidth would be more than enough to study one in.
-Chris
-Chris
I keep saying, Thermally Stabilized components will quell the argument. But hey when you have people who have retired on great work, well that is it. But for those who don't think one guy's life work is the best effort in the world has to offer.......the new people just moved to optics...
You are in for some fun with new sounds when you 'get it'......My Bybee has been shipped, I can't wait. 😉
Be prepared to launch some belief systems straight out of the nearest window.
Dan.
- Member Areas
- The Lounge
