getting rather circular here?
Andy, while once again it would be OT to this thread - perhaps you could describe an ideal audio system that would be completely absent blasphemy.
And isn't "digital amp" actually a misnomer, at least in reference to the class at which, offerings by numerous high end manufactures aside, I think you're apparently thumbing your nose?
Indeed the D in Class D does not stand for digital. Some are indeed idgital but the Class D descriptor only refers to the nature of th eoutput devices. When Infinity brought out the 1st Coass D amp (at least in my experience) a small computer was still in the future. It was very much an analog device.
dave
I can see there are some high end digital amps, but a plate amp is far cry from high-end. Either way, I wouldn't listen to a digital amp unless somebody putting a gun on my head.
There are no ideal system but only those which makes you happy. I like the musical experience of a 1st or xover vs. sterile sounding of higher order xover. Any decent amp and cd player would be fine.
dave
Class D or digital or whatever is basically passing a PWM (pulse width modulated) signal then to a low pass filter without any analog signal.
Theoretically you can take a purely digital signal without ever having to convert it to analog, do dsp process on it, convert it to PWM, put it through a transistor amplifier stage, then put it through a low pass, then put it through a pair of speakers or where ever makes you happy the most.
When pontificating, I think words matter - so just be prepared to be called on it - I certainly am.
I'm pretty sure you could engage in some interesting dialog with members who've built more than a few audio systems and speakers regarding the relative merits of "orders" of XOs - let's presume you're referring to high level passives (after the amplifiers). I was for quite some time a die-hard FR only, then 1st order only advocate, but after building 3 quite different 'FAST' / 'WAW' systems over the past couple of years, I'm now have a different perspective. It's all about the implementation of the total system - synergy, if you like - although that suggests a result greater than the sum of its constituent parts.
edit - as for who is he - just "search for other posts by" to get a taste for his point of view and contributions to the fora dialogs
I agree.It's all about the implementation of the total system - synergy, if you like - although that suggests a result greater than the sum of its constituent parts.
I only have short term memory.edit - as for who is he - just "search for other posts by" to get a taste for his point of view and contributions to the fora dialogs
That's what the search functions are for - although the time to thoroughly research relevant posts on the subject, or those by any given forum member can certainly create speed bumps in the badinage which, speaking for myself is as much an attraction as anything.
Why should I trouble myself with this "scottjoplin"? Is he a like an audiophile superhero? Even then, I really got better things to do.
Are there new vinyls ( still sounds weird. Records I call them) that are all analog other than repressings? If not, you would hope that whatever conversions are done are of higher quality than usually be done at home so still may be an argument for an all analog chain?How would I play vinyl? I know you're going to say "put the vinyl through the ADC of the DSP" but then that sort of defeats the purpose the vinyl doesn't it?
Andy - you’re the one who asked, and I think phivates gets a gold star for the OT comment
Ah, OK - now I understand. No rational argument, no look at the crossover I proposed, no analysis of how well - or not - the woofer would work with the Harbeth, no proposal of a circuit. Just pigs and lipstick. I'm cool with that.I supposed you could put lip stick on a pig but not something I would want, but as the saying goes, your speakers your money your choice.
hey, Michael there are guys who pay extra for that lipstick - just saying
andy - your professions of better things to do with your time, and the frequency of your posts in this thread alone seem to me to be, what's the word - inconsistent"
yky - all this sandbox squabbling aside, have you settled on a plan of attack?
I suppose life is full of contradictions. Mine don't offend people as others.
im back on to this project
but I wont go the passive way to highpass the P3esr
Ill build 2 subs to go right underneath the P3esr, xo around 120hz.
Im thinking either Behringer DCX2496 or Pass b5/b4 as active xo.
- Could I turn my small Harbeth into a big 3 way with passive crossover?
