ACA Speaker short list
Since the ACA has such low gain and low voltage swing, it may still be advantageous to stick with dual 8ohms for 4ohms nominal.
Hmm, that's a tough call. How do I decide now... :dunno:
To put things into perspective, let me ask this: will two 16 ohm drivers in parallel (8 ohm effectively) have lower volume than a single 8 ohm driver at the same voltage?
Hard to say because the specifications are not clear. It says Sensitivity 1w/1m but sensitivity, by definition is 2.83 V in:
if 1w/1m (simple math P=v^2/R -> V =sqrt(pxR) assume 8 and 16Ω) someone please check my math
16Ω 3FE25 90 dB 4V in, add a 2nd driver, you get 6 dB more, helf due to doubling the number of drivers, half from double the power in, ie 96 dB, 2W in, 93 dB, 1 w in.
if sensitivity, then ½w in gives 90 dB, double th edrivers gives 3 dB, twice the power gives 96 dB 1 w
8Ω FaitalPro 3FE25 91 dB, 2.83 V in is 1 w so 1 driver is 91 dB 1 w in both scenarios.
dave
Certainly the latter is true (id specs are on target). Because of the ambiguity of the specifications the 16Ω could be 93 or 96 dB 1W.
Thanks Dave. Even if it's just 93dB @ 1W, it's still quite a bit more volume as one driver. To me that means I should be ok with two 16Ω drivers, without fear that the the ACA's won't be able to drive it to sufficient volume.
I hope my reasoning is realistic.
Christo
There is one big difference between 4ohm and 8ohm speakers: the 4ohm ones let you extract twice the power from the ACA for the same voltage drive level.
ACA is a nominal 5w amp into 8ohms. That means it can drive 6.32v rms into 8ohms. That same 6.32v rms into 4ohms draws twice the current and it is now a nominal 10w amp. Probably distortion climbs if you try pushing that much more current from it, but nice to know the capability of there for more dynamic transients. I wouldn't worry about hurting your ACA. At worst you blow a common $1.75 IRFP240 MOSFET. I have yet to blow one from overdriving it (and I have used over 3 dozen of them in all my amps). I lost a few from thermal runaway on a Class AB where the temp comp wasn't working right - and that happens almost instantaneously.
Here is my drawing of the 0.53x Karlsonator for dual FaitalPro 3FE25's. Material is 12mm MDF.
That looks great Skylar. I am sure you will be pleasantly surprised how good it sounds.
Thanks X. Part of the reason that I've decided on Karlsonators is that I've heard how good the 0.40x sounds. Twocents built a set from foam board and I was blown away by the excellent sound of such small speakers.
Thank you for all the hard work testing and promoting the design.
Some feedback: This afternoon I received four 3FE25-16's for my dual driver 0.53x Karlsonator build. I ended up having to import the drivers from a shop in Italy (cheapest option) because two local suppliers couldn't get them for me. Apparently, there is a minimum order quantity of 36 from the factory.
Anyway, I have another question about speakers for the ACA's.
X posted the following in the Mini Karlsonator (0.53X) with Dual TC9FD's thread:
“For anyone wanting to try a more HiFi upgraded sound with deeper bass, very smooth mids and clear highs, I can recommend the Tang Band W5-2143 in an XKi. I think it should work in a Karlsonator as well but the box is a good size due to the larger Vas. Great sounding driver though.”
Would these be suitable speakers for a pair of ACA’s? I’m considering building a second sound system for my office consisting of B1 + ACA's and I’ll need speakers. The idea is to use the 0.53x Karlsonators with dual 3FE25's in my office and then build bigger speakers for the lounge/listening area.
Let me hook up my ACA to my XKi fitted with W5-2143 and let you know what I think. Personally, I think you might want an amp with more oomph than 5w bit then I don't know what kind of levels of dynamics you are used to listening to. I had the dmm hooked up while playing from a larger Babelfish J amp and to get the SPL levels I like, it was routinely hitting 4.5 to 5v rms. That certainly is within range of ACA but 5v rms is about 14v peak-peak. Can ACA do that comfortably?
To get the ACA to put out 14v requires a preamp capable of hitting 1.4v p-p so a cellphone isn't going to be able to do that. Will need a real preamp.
If the ACA's can't drive the XKi fitted with W5-2143, then it may be a good idea to use the 0.53x in the lounge and build 0.40x K with maybe single 3FE25-8 drivers for the office as bookshelf speakers.
But I still want to know what you think about the XKi with W5-2143, driven by your ACA.
What a pretty sight. Four Faitals and two ACA PCB's. 😀
The PCB's took two months to arrive from China. That's the price you have to pay if you live in a remote country.
Skylar,
Just got a chance to test ACA with XKi fitted with W5-2143. Works exceedingly well. Nice deep bass, very smooth wonderful sounding. Almost like a match made in Class A heaven. Decent SPL's - I used headphone out from CD player as source so sort of like a real preamp with good juice. I can highly recommend this pairing.
X
