hi everybody.
In class D amp. Must I use buffer and preamp or just buffer or just preamp ?
Thanks for reply !
Thanks for reply !
hi everybody.
Thanks for reply !
Go to post #661
Good day All.
Can someone point me to the post regarding the etd59 winding specs please.I would like to try and build the SPS-1000 .I will have the transformer made by a company locally.
I hope someone can help me !
Audiobrad.
Audiobrad.
D2000 with +/-150V DC
Where we can find schematic and pcb as built for this D2000?
hi apex .what is your inductance in your output coil, and the impendance of the speaker tou tested with??
No one know?
Is it a full range amplifier?
D2000 and D4000 is aplifiers for subwoofer, you can find schematics in this thread.
Hi
I made d200.2 and its working but sounds like snoring
I tried output coil from behringer dpa400 and powersoft digimod 1000
But problem still exist and its worst when turn the volume up...
Supply is +/-60
Mosfets are irf 540
Please help me
Supply is +/-60
Mosfets are irf 540
Please help me
Hi
Supply is +/-60
Mosfets are irf 540
Please help me
😱😱 you are using wrong fets . you are lucky the irf540 are still alive . use irfb4227 or irf 640 use at 8ohms only . your voltage is too high for irf540 fets
I changed fets but still have the problem😱😱 you are using wrong fets . you are lucky the irf540 are still alive . use irfb4227 or irf 640 use at 8ohms only . your voltage is too high for irf540 fets
I tried 640 and 260!!
That mean that isn't a fully band amplifier?D2000 and D4000 is aplifiers for subwoofer, you can find schematics in this thread.
It can be use up to 4kHz, for bass in 2 way active speaker or for subwoofer.
Thanks Mile!It can be use up to 4kHz, for bass in 2 way active speaker or for subwoofer.
- Class D
- Class D Amp with LM566, LM393 and 2XIRF530
