Official M2 schematic
Before starting GB PCB M2 amplifier, here last documents.
JP
  • PAS_M2-CASCODE_SCH.pdf
  • PAS_M2-CASCODE_PBA-TOP.pdf
  • PAS_M2-CASCODE_PCB.pdf
Hello, I just finished my Nelson Amp M2 and I wanted to know what its used to twist the cables output hp between the cards and the terminals inside the amp? For I did not do it I cabler with wire hard of 1,5m. On a power supply I understand for the parasites that have the twists but on the output wires hp ....... Thank you for your help
