Moode Audio Player for Raspberry Pi
Thanks for the tips, the windows program shows the genre as being correct and after changing the genre again the log shows this...
pi@moode-lr:~ $ cat /var/log/mpd/mpd.log
Aug 13 18:22 : avahi: Service 'Moode MPD' successfully established.
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-04-Rotterdam Nation.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-09-Game Over.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-01-Ridge Racer.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-05-Speedster.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-07-Attract.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-03-Feeling Over.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-11-High Score Screen.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-06-Rhythm Shift.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-08-Car Selection.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-02-Rare Hero.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-12-Ending.mp3
Aug 13 18:23 : update: updating NAS/AS1002T/mp3/Namco/Ridge Racer (Playstation)/1-10-Replay.mp3
No error I guess?
The last track is the one that does get the correct genre assigned.
Hi @IM35461,
Examine the problem files using the Mediainfo utility.
MediaInfo
Also look at MPD log to see if there are any errors.
-Tim
-Tim
Hi Tim
Here's a feature request that might chime with absent-minded types like me.
As Moode has moved through releases to 3.8, every upgrade has been smooth apart from my repeated “oh nuts” moment when I realise that yet again I have forgotten to preserve my custom radio stations and playlists. I'm thinking it might be useful if there were a UI switch that gives the option to force Moode to save these items offboard on an attached USB device rather than the SD card. That way they would survive the reimaging process. Nothing complex, maybe just a couple of standard folders in USB root called MyPlaylists and MyRadios.
Anyone else want to +1 this idea.
Great work on Moode Tim.
Stu
Hi, Stu.
I agree this would be a useful built-in feature. Indeed, I scripted a portion of this functionality for my own use back at r3.1.
At the time, I was gathering URLs for stations and also creating appropriate logos for them. Basically, I wanted to be able to roll the stations into moOde Player all-at-once through the command line, rather than one-at-a-time through the Web Client, and to store the logos in the appropriate directory. I wrote a simple shell + sql(lite3) script, almost a no-brainer. It was trivial to copy and use it on multiple installations of the same release.
Frankly, I got lazy and didn't pursue this further because Tim has been so good at incorporating our station submissions into each new release.
Saving and restoring user-defined stations across moOde Player releases would be a bit trickier. Some "business logic" is required regarding the station entries because of a detail of the database structure which I won't go into here. As well, the squashfs introduced at r3.5 makes it hard to add station artwork [1].
I haven't gotten around to creating my own playlists and haven't even looked at how that information is stored. Still, I can imagine having to recreate them is even more labor intensive than recreating radio stations.
Kent
[1] This may not be an issue for anyone else. The display of radio station logos is one of the features which first drew me to moOde Player and I hate falling back on the default image.
Hi Tim
Stu
Here's a hack that removes the need to do anything about your own station entries. The downside is that they don't appear under radio listings. The do appear in your NAS, SDCARD, or attached USB music area.
You use a .pls file exactly like you would when you create a new radio station entry (leftmost image). Place this .pls file in your top level music file directory. (middle image -- Nas directory viewed from Windows) Once you index that directory, those file will show up in Moode browsing. (Rightmost image). Use them just like an album directory or a single song.
Not stylish, but perfectly functional and low-effort.
Skip
attachment.php
No error I guess?
@IM35461
The question here is, what information does moOde Player see in these files?
Running mediainfo from the moOde Player command line as Tim suggests is an easy way to find out.
Here's the first stanza from the output when I run it on a randomly selected file on a USB thumbdrive on my moOde player
Code:
[FONT="Courier New"]General
Complete name                            : 01 Hearts of Space - Kevin Braheny ,
Starflight 1 (Galaxies).flac
Format                                   : FLAC
Format/Info                              : Free Lossless Audio Codec
File size                                : 10.5 MiB
Duration                                 : 1mn 35s
Overall bit rate mode                    : Variable
Overall bit rate                         : 920 Kbps
Album                                    : Universe One
Part                                     : 1
Part/Total                               : 1
Track name                               : Kevin Braheny / Starflight 1 (Galaxie
s)
Track name/Position                      : 01
Track name/Total                         : 15
Performer                                : Hearts of Space
Genre                                    : Ambient
Recorded date                            : 1990
Cover                                    : Yes
Cover type                               : Cover (front)
Cover MIME                               : image/jpeg
[/FONT]
Does mediainfo report a Genre value for each of your files and is it the same value?
Kent
Kent,
Being a fool I did not realise MediaInfo was already installed on the MoOde.
My next challenge was trying to work out the path to the files :)
Anyway, he is the output
Code:
pi@moode-lr:/mnt/SDCARD/Music $ sudo mediainfo *
General
Complete name                            : 1-01-Ridge Racer.mp3
Format                                   : MPEG Audio
File size                                : 6.10 MiB
Duration                                 : 5mn 19s
Overall bit rate mode                    : Constant
Overall bit rate                         : 160 Kbps
Album replay gain                        : 0.10 dB
Album                                    : Ridge Racer (Playstation)
Album/Performer                          : Namco Games
Part/Position                            : 1
Track name                               : Ridge Racer
Track name/Position                      : 1
Encoded by                               : iTunes 8.0.1.11
Genre                                    : Game Console
Recorded date                            : 1994
Tool Name                                : ool Name
Tool Version                             : ool Vers
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Format version                           : Version 1
Format profile                           : Layer 3
Mode                                     : Joint stereo
Duration                                 : 5mn 20s
Bit rate mode                            : Constant
Bit rate                                 : 160 Kbps
Channel(s)                               : 2 channels
Sampling rate                            : 44.1 KHz
Compression mode                         : Lossy
Replay gain                              : 0.30 dB
Replay gain peak                         : 0.666077
Stream size                              : 6.10 MiB (100%)
General
Complete name                            : 1-02-Rare Hero.mp3
Format                                   : MPEG Audio
File size                                : 5.25 MiB
Duration                                 : 4mn 35s
Part/Position                            : 1
Track name                               : Rare Hero
Track name/Position                      : 2
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Mode extension                           : MS Stereo
Duration                                 : 4mn 35s
Bit rate                                 : 160 Kbps
Replay gain                              : 0.50 dB
Replay gain peak                         : 0.701935
Stream size                              : 5.25 MiB (100%)
General
Complete name                            : 1-03-Feeling Over.mp3
Format                                   : MPEG Audio
File size                                : 6.12 MiB
Duration                                 : 5mn 20s
Part/Position                            : 1
Track name                               : Feeling Over
Track name/Position                      : 3
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 5mn 21s
Bit rate                                 : 160 Kbps
Replay gain                              : -0.30 dB
Replay gain peak                         : 0.677399
Stream size                              : 6.12 MiB (100%)
General
Complete name                            : 1-04-Rotterdam Nation.mp3
Format                                   : MPEG Audio
File size                                : 6.24 MiB
Duration                                 : 5mn 26s
Part/Position                            : 1
Track name                               : Rotterdam Nation
Track name/Position                      : 4
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 5mn 27s
Bit rate                                 : 160 Kbps
Replay gain                              : -0.50 dB
Replay gain peak                         : 0.844757
Stream size                              : 6.23 MiB (100%)
General
Complete name                            : 1-05-Speedster.mp3
Format                                   : MPEG Audio
File size                                : 5.89 MiB
Duration                                 : 5mn 8s
Part/Position                            : 1
Track name                               : Speedster
Track name/Position                      : 5
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 5mn 9s
Bit rate                                 : 160 Kbps
Replay gain peak                         : 0.711212
Stream size                              : 5.89 MiB (100%)
General
Complete name                            : 1-06-Rhythm Shift.mp3
Format                                   : MPEG Audio
File size                                : 5.81 MiB
Duration                                 : 5mn 4s
Part/Position                            : 1
Track name                               : Rhythm Shift
Track name/Position                      : 6
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 5mn 4s
Bit rate                                 : 160 Kbps
Replay gain peak                         : 0.696014
Stream size                              : 5.80 MiB (100%)
General
Complete name                            : 1-07-Attract.mp3
Format                                   : MPEG Audio
File size                                : 2.33 MiB
Duration                                 : 2mn 2s
Part/Position                            : 1
Track name                               : Attract
Track name/Position                      : 7
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 2mn 2s
Bit rate                                 : 160 Kbps
Replay gain peak                         : 0.833771
Stream size                              : 2.33 MiB (100%)
General
Complete name                            : 1-08-Car Selection.mp3
Format                                   : MPEG Audio
File size                                : 1.48 MiB
Duration                                 : 1mn 17s
Part/Position                            : 1
Track name                               : Car Selection
Track name/Position                      : 8
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 1mn 17s
Bit rate                                 : 160 Kbps
Replay gain                              : -0.20 dB
Replay gain peak                         : 0.755859
Stream size                              : 1.47 MiB (100%)
General
Complete name                            : 1-09-Game Over.mp3
Format                                   : MPEG Audio
File size                                : 231 KiB
Duration                                 : 11s 781ms
Part/Position                            : 1
Track name                               : Game Over
Track name/Position                      : 9
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Bit rate                                 : 160 Kbps
Replay gain                              : 0.00 dB
Replay gain peak                         : 0.607910
Stream size                              : 230 KiB (100%)
General
Complete name                            : 1-10-Replay.mp3
Format                                   : MPEG Audio
File size                                : 2.37 MiB
Duration                                 : 2mn 4s
Part/Position                            : 1
Track name                               : Replay
Track name/Position                      : 10
Year                                     : ear / ear
REPLAYGAIN_ALBUM_PEAK                    : 0.844737
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 2mn 4s
Bit rate                                 : 160 Kbps
Replay gain peak                         : 0.576843
Stream size                              : 2.37 MiB (100%)
General
Complete name                            : 1-11-High Score Screen.mp3
Format                                   : MPEG Audio
File size                                : 1.89 MiB
Duration                                 : 1mn 38s
Part/Position                            : 1
Track name                               : High Score Screen
Track name/Position                      : 11
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 1mn 39s
Bit rate                                 : 160 Kbps
Replay gain                              : 0.60 dB
Replay gain peak                         : 0.683655
Stream size                              : 1.89 MiB (100%)
General
Complete name                            : 1-12-Ending.mp3
Format                                   : MPEG Audio
File size                                : 2.88 MiB
Duration                                 : 2mn 30s
Part/Position                            : 1
Track name                               : Ending
Track name/Position                      : 12
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 2mn 31s
Bit rate                                 : 160 Kbps
Replay gain peak                         : 0.678558
Stream size                              : 2.88 MiB (100%)
Only Track 10 is assigned the correct Genre
@IM35461
Code:
Format                                   : FLAC
Duration                                 : 1mn 35s
Part                                     : 1
Part/Total                               : 1
s)
Genre                                    : Ambient
Cover                                    : Yes
[/FONT]
Kent
Hi @IM35461,
Other troubleshooting steps:
1) When playing one of the problem songs, connect to MPD and dump out currentsong info.
telnet localhost 6600
currentsong
2) Edit /etc/mpd.conf and change logging to "verbose" then restart MPD.
tail -f /var/log/mpd/mpd.log --or-- cat /var/log/mpd/mpd.log
Start one of the problem songs playing and then examine the log.
You can also perform a RESCAN to see in detail what MPD is doing when it adds the song to its database.
3) Zip up a few of the problem songs and send me a download link. I'll take a look at them when I get the chance.
-Tim
Kent,
Code:
General
Format                                   : MPEG Audio
Duration                                 : 5mn 19s
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 5mn 20s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 4mn 35s
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 4mn 35s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 5mn 20s
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 5mn 21s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 5mn 26s
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 5mn 27s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 5mn 8s
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 5mn 9s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 5mn 4s
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 5mn 4s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 2mn 2s
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 2mn 2s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 1mn 17s
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 1mn 17s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
File size                                : 231 KiB
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 2mn 4s
Part/Position                            : 1
Track name                               : Replay
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 2mn 4s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 1mn 38s
Part/Position                            : 1
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 1mn 39s
Bit rate                                 : 160 Kbps
General
Format                                   : MPEG Audio
Duration                                 : 2mn 30s
Part/Position                            : 1
Track name                               : Ending
Year                                     : ear / ear
Audio
Format                                   : MPEG Audio
Mode                                     : Joint stereo
Duration                                 : 2mn 31s
Bit rate                                 : 160 Kbps
@IM35461
Perhaps it's just coincidence, but I notice Track 10 is the only one which does not have tag fields Tool Name: and Tool Version:. Perhaps those fields are causing mpd to choke. As well, the values of these fields are truncated (e.g.; "ool Name and "ool Version") but then so is the value of all incidences of the Year: field, Track 10 included.
[edited for clarity] This may turn out to be a problem with mpd (on which moOde Player is built) which only the mpd maintainers can address, but if these fields are causing the problem, the quick fix would be to use an ID3 tag editor to delete them.
As for mediainfo, don't feel bad. If you go back through this forum thread, you'll find where Tim had to point out to me that he includes it in moOde Player.
Kent
Hi @IM35461
I analyzed the three files you sent and the Mediainfo dump looks ok but for some reason MPD is not parsing the Genre tag in the first two files. I have no clue why this is the case.
The ? in ?/44.1 will appear for song files encoded using lossy compression since there is no concept of bit depth in lossy compression.
Btw, these are AWESOME tracks :)
pi@rp3:~ $ telnet localhost 6600
Trying ::1...
Trying 127.0.0.1...
Connected to localhost.
Escape character is '^]'.
OK MPD 0.20.0
currentsong
file: USB/VFAT-8GB2/Test_mixed/Genre Issue Files Except Track 10/1-09-Game Over.mp3
Last-Modified: 2017-08-13T22:10:06Z
Artist: Namco Games
Title: Game Over
Album: Ridge Racer (Playstation)
Track: 9
Date: 1994
Time: 12
duration: 11.800
Pos: 49
OK
currentsong
file: USB/VFAT-8GB2/Test_mixed/Genre Issue Files Except Track 10/1-11-High Score Screen.mp3
Artist: Namco Games
Title: High Score Screen
Track: 11
Date: 1994
Time: 99
duration: 98.997
Pos: 50
OK
currentsong
file: USB/VFAT-8GB2/Test_mixed/Genre Issue Files Except Track 10/1-10-Replay.mp3
Artist: Namco Games
AlbumArtist: Namco Games
Title: Replay
Track: 10
Date: 1994
Date: 1994
Genre: Sony Console
Disc: 1
Time: 124
duration: 124.101
Pos: 51
OK
pi@rp3:~ $ sudo mediainfo --Inform="Audio;file:///var/www/mediainfo.tpl" "/var/lib/mpd/music/USB/VFAT-8GB2/Test_mixed/Genre Issue Files Except Track 10/1-11-High Score Screen.mp3"
<no bit depth>
44100
2
160000
MPEG Audio
pi@rp3:~ $
Not sure what happened there..but @Tim.
I noticed that on the 7th August in another forum Allo stated that they had submitted an updated Digi One driver to Raspbian. Are you in contact with Allo, I am sure that it would be in their interest that you are, can you find out if the latest driver is in Moode 3.8?
I don't want to join the other forum.
FYI The reason I am asking is that I am seeing occasional brief dropouts in playback. While I haven't yet ruled out the network yet, it its the same WIRED network I have been using for the last year with a HiFiberry Digi + with no issues (so no network troubleshooting tips please guys). Google finds some comments about this behaviour with Max2play and I think Volumio, or at least some reference to dac syncs.
I have tried all three kernels with Real Time being the best for stable play.
I will try some local playback files to rule out the network but I am interested to know what driver version I have.
Hi @Serverbaboon,
Yes, working closely with Allo, mainly on the Piano 2.1 dual modes. If you have been following moOde Twitter feed I recently posted about the new 4.9.41 Linux kernel and the DigiOne fixes moOde audio player on Twitter: "Hi, some nice fixes 4 Allo DigiOne & Piano 2.1 r in new 4.9.41 Linux kernel :) I'll get an update out for these. https://t.co/z5Sa63S3PM" These will be included in upcoming moOde 3.8.2 release.
I'm planning to release moOde 3.8.2 this week :)
-Tim
ok thanks, bit of a social media luddite :)
