Vacuum Tube SPICE Models
You may want to check the LTSpice manual wrt the current flow convention.
would you please help to double check the EC86 SPICEL model and help to build EC88 SPICE model?
My current EC86 model seems does not work.
* Generic triode model: EC86
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Sat Mar 8 22:42:35 2008
* Plate
* | Grid
* | | Cathode
.SUBCKT EC86 A G K
BGG GG 0 V=V(G,K)+0.22760069
BM1 M1 0 V=(0.0026112468*(URAMP(V(A,K))+1e-10))**-0.29355976
BM2 M2 0 V=(0.83632563*(URAMP(V(GG)+URAMP(V(A,K))/62.680543)+1e-10))**1.7935598
BP P 0 V=0.0095464624*(URAMP(V(GG)+URAMP(V(A,K))/74.947533)+1e-10)**1.5
BIK IK 0 V=U(V(GG))*V(P)+(1-U(V(GG)))*0.0059140675*V(M1)*V(M2)
BIG IG 0 V=0.0047732312*URAMP(V(G,K))^1.5*(URAMP(V(G,K))/(URAMP(V(A,K))+URAMP(V(G,K)))*1.2+0.4)
BIAK A K I=URAMP(V(IK,IG)-URAMP(V(IK,IG)-(0.00496493*URAMP(V(A,K))**1.5)))+1e-10*V(A,K)
BIGK G K I=V(IG)
* CAPS
CGA G A 2.2p
CGK G K 3.5p
CAK A K 0.2p
.ENDS
here is the datasheet file.
http://www.tubebbs.com/tubedata/sheets/030/e/EC88.pdf
http://www.tubebbs.com/tubedata/sheets/030/e/EC86.pdf
Best Regards
Leo
This model is traced by me using CurveCaptor, Koren8 model, pretty close, maybe you like to use it, there is more than one way to get the model, included also the marker and data file for reference.
* ec88 LTSpice model
.subckt ec88 P G K
Bp P K I=(0.1271584816m)*uramp(V(P,K)*ln(1.0+(-0.08785188791)+exp((2.922603012)+(2.922603012)*((70.68877455)+(-2844.697934m)*V(G,K))*V(G,K)/sqrt((66.12972009)**2+(V(P,K)-(34.81182848))**2)))/(2.922603012))**(1.087629465)
Cgk G K 3.8p ; added
Cpk P K 0.055p ; added
Cgp G P 1.7p ; added
Rpk P K 1G ; to avoid floating nodes
d3 G K dx1
.model dx1 d(is=1n rs=2k cjo=1pf N=1.5 tt=1n)
.ends ec88
  • ec88-s.dat.txt
    ec88-s.dat.txt
  • ec88-s.crv.txt
    ec88-s.crv.txt
Reactions: Adriel
Here is the EF14. it worked well in PSpice
**** EF14 ******************************************
* Created on 07/19/2017 Sam
.SUBCKT EF14 1 2 3 4 ; P G K G2
+ PARAMS: CCG=9.5P CGP=0.15P CCP=10P RGI=1000
+ MU=31.2 KG1=387 KP=82.4 KVB=11.4 KVC=1.57 VCT=-1.24 EX=1.2 KG2=7.33
RE1 7 0 1G ; DUMMY SO NODE 7 HAS 2 CONNECTIONS
E1 7 0 VALUE= ; E1 BREAKS UP LONG EQUATION FOR G1.
+{V(4,3)/KP*LOG(1+EXP((1/MU+(VCT+V(2,3))/V(4,3))*KP))}
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1*ATAN(V(1,3)/KVB)}
* Alexander Gurskii screen current, see audioXpress 2/2011
RE2 8 3 1G ; Dummy
G2 8 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG2*(KVC-ATAN(V(1,3)/KVB))}
E2 8 4 VALUE={0} ; Dummy
RCP 1 3 1G ; FOR CONVERGENCE
C1 2 3 {CCG} ; CATHODE-GRID 1
C2 1 2 {CGP} ; GRID 1-PLATE
C3 1 3 {CCP} ; CATHODE-PLATE
R1 2 5 {RGI} ; FOR GRID CURRENT
D3 5 3 DX ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
.subckt ec88 P G K
d3 G K dx1
.ends ec88
I tried to use this model,but got an error.please refer to attached screen short.
Hello everyone,
I'm designing a phono stage in LTSpice.
For the input stage I would like to use the EC8010, but I could not find the spice model.
Can anyone share the spice model of this triode?
Thank you very much.
Alberto.
Code:
* EC8010_TF LTSpice model
* Modified Koren model (8 parameters): mean fit error 0.462343mA
* Traced on 3/23/2015 by Wayne Clay using Curve Captor v0.9.1 and
* Engauge Digitizer from Telefunken data sheet
.subckt EC8010  P G K
    Bp  P K  I=
+ (0.2131738609m)*uramp(V(P,K)*ln(1.0+(-0.09421188573)+exp((3.696690166)+
+ (3.696690166)*((62.74970209)+(-2822.087803m)*V(G,K))*V(G,K)/sqrt
+ ((52.12000848)**2+(V(P,K)-(3.725990169))**2)))/(3.696690166))**(1.146897295)
    Cgk G K 7.5p ; 1.0p added
    Cgp G P 2.5p ; 1.0p added
    Cpk P K 0.2p ; 0.1p added
    d3  G K dx1
.ends EC8010
Edit: I see matejsirk linked to my post with the same model(s).
