TDA1387 X8 NOS DAC
I am very curious about the JLH headphone amp - in the description it says its 'single ended classA' but the original JLH 1969 circuit was push-pull, not SE. Clearly this amp has changed output transistors due to the lower power requirement, its possible the design got changed into an SE topology. I shall go in search of a schematic.
I've not experimented with reducing jitter at any of my DACs as I've never noticed a problem - for example between using a DIR9001 or CS8412 and direct I2S coming from a media player or PC.
I had a trawl around but couldn't find the schematic - I did find a few component details though from looking at the pictures of the PCB's silkscreen. Looks to have LM7912/7812 regulators for the supply and TIP41 output transistors. Also one more TO92 device per channel than in the original design.
What headphones are you using with it?
My suggestion to get maximum 'punch' would be to build yourself a true single-ended classA headphone buffer - like this schematic I'm attaching.Its a higher power variant of one I have on my blog. I've built this and its the best headphone amp I've heard, particularly good in terms of 'drive' and 'energy'. I put this down to the extremely good PSRR.
<edit> Ah I see from your .sig that you're using HD650s - they're 300ohm types and will need more gain to get to full level when driven from a DAC. Maybe 6 to 10dB would be sufficient.
Mortenhoe,
I have one. I bought it for work
The best passive filter in my opinion is
220 omh (thinfilm resistor) (stok 576 omh)
3300 pf (stok 4700 pf)
22 omh (stok 22 omh)
220 pf (stok 330 pf)
Next I put the separating capacitor: silmic ce-bp 16v 10uf with parallel 0.1 np0
Thank you Abraxalito
Dear Thank Abraxalito,
Thank you for your work on the TDA1387, really enjoying the DAC. Have you compared it to the 9018 or 9028 ? or TDA1541 ?
Have been doing some comparisons:
In order of Sound Quality
1. DT770 250 ohm > JLH 1969 Headphone Amp > TDA1387 x8 DAC > MacBook Pro. Sounds natural and easy, not the largest sound stage, not that largest range, great left / right separation, very musical.
2. DT770 250 ohm > JLH 1969 Headphone Amp > iFi Nano > MacBook Pro. More "digital" sounding, sharper
3. DT770 250 ohm > JLH 1969 Headphone Amp > HiFiBerry DAC+ Pro > Raspberry Pi. Sounds small, not rich, compressed and confused, all the information is there, but not musical.​
Also tried all of the above using the Sony MDR-7506, small soundstage, brittle sounding, too close
Building an amp from scratch is beyond my abilities (someday).
How do I change the TDA1387 x8 from 6 to 10dB for the Sennheiser HD650 ?
All the best,
-Mark
I've only compared my TDA1387 DACs to the ES9018K2M in my mobile phone - no competition (except perhaps in the bass). Not heard any of the next generation ESS chips yet.
Your JLH already will have enough gain to feed your HD650s - you'd only need the extra 10dB if you used my suggested MOSFET buffer in place of your JLH.
I just got one of the Taobao TDA1387 x8 DACs, and have been playing with it.
As stock, I was concerned about the big pops on switch on/off, and was hoping there was a neat way to fix that (without doing a full relay circuit).
I removed the stock opamps, replaced with AD845 and removed the 2N2 caps over the opamp output.
This made the pops much worse, and there's often quite noticeable opamp oscillation (in the 15kHz+ region, from a scope at switch on/off. The oscillation ends up in the 1-2MHz region, as the +15/-15V rails collapse.
Any ideas on what to tweak to help reduce the turn on/off pops?
Sure, I understand best practice. However sometimes my mains power may fail and restart unexpectedly, and I'd rather not break my amplifier and voice coils because the DAC popped 😛
Most professional DACs don't pop at turn on/off (or just have a very minor pop). Do you know what we can tune to decrease the popping on this DAC?
Those are polarized caps, means we have to figure out which way around to put them in the circuit. I seem to recall that the opamp's output is negative (because the DAC's output current is always positive) by a few volts so put the positive side to the output.
Mortenhoe,
I ended up with a change in the filter
