Yup, did that - lowered the gain. Helps somewhat... thanks.
Still wondering about the sound a bit... not quite there... about 10db between k2/k3. A bit dark and mudded... but I guess it's still running in.
Got some caps thought! Couldn't help myself. 😀 Happened to have a couple Mundorfs around. A pic at:
http://www.diyaudio.com/forums/pass...-your-diy-pass-amplifier-391.html#post5001681
Volume control wiring for BA-3 preamp
Hi Guys, I am preparing for BA-3 preamp ... I am still not able to figure out the wiring diagram for Volume control for this setup. I have a spare Alps - 20K stereo pot lying idle, hope I can use it.... From the pics on the first page it is not very clear how the Goldpoint ATTENUATOR has been wired...Guess those are multi-layered cables...any wiring diagram would be really helpful
Of those two, yes. I used 25K and many encouraged to drop to 10K. 6L6 used 50K, as he had a 50K goldpoint at hand. This looks like what I, and a few others used. Out of 3, I had one with a bad internal connection. Best 20 bucks I've ever spent on a volume pot. I used them on both BA-3 FE I built.
4POLE 24 Step Attenuator Volume Control Pot Log A 25K 25kA Stereo Potentiometer | eBay
Russellc
Or a detailed pic maybe from anyone who has added a pot to BA-3 pre
Sent from my iPhone using Tapatalk Pro
🤣 ZM, want to add it at the input level, just like B1...will it be same for BA-3
exactly the same
signal hot from selector to top of pot
bottom of pot to signal gnd
pot wiper is hot to preamp input
I found great inspiration in the 6L6 photos and assembly at start of thread... also from the father material. I got some boards and matched FET's from DIY Audio Store and started on this journey. Getting close to assembly time...soon. This is my 'thank you' message.
I have trouble adjusting the bias. I did not get up to 390mV. Use K170 / J74 paired and IRF610 / 9610. P1 and P2 of 500 Ohms. The power supply is +24.20V and -23.90V. In both channels the same thing happens. Should I raise the value of P1 and P2 to 1K Ohm?
I believe you should. IRF610/IRF9610 (like the Fairchilds) have higher Vgs than the Toshiba parts.
Dennis
Nobody noticed the attached picture was a soft start PCB?
Nobody stood out to question that post #649?
Oh Boy!
Well, not bragging, but when I saw it I was
puzzled by the pic. 😕
Good times. I can't wait to get this thing assembled in a box and hear it. I too did the unspeakable and used IRF9610 and IRF610.
I have a second PCB and may just go ahead and order the FQP3P20 and FQP3N30 but let me hear the IRF devices first.
........ I too did the unspeakable .......
isn't that normal , for Tom Waits ?
Can we take out a balanced output from the BA3 preamp board? If yes which connections should I be using as I want to pair with XLR cables to my Aleph J. Also can I give balanced input from my DAC to the BA3.
Sounds like this PCB will need a few pots swapped for 1k. Yikes...
They're really not as hard to remove as you might think...heat the outside pins from underneath one at a time rocking the trimmer back and forth...then the inside pin...then outsides again...keep this sequence up until it's out.
It's helpful (I would say essential) to have a pcb holder for this.
- The BA-3 as preamp build guide
