Measure DC-bias in a operating class AB (or A) amplifier
@Osvaldo, No there is no isolation cap, but the simulation supplied is valid, and yes I did have a good look at the datasheet, and yes I do know that isolator (for as long as it exists).
The question is 'how to measure the DC bias', the question is not how to measure the average current in the ballast resistors, for that the opto would function nicely.
@AndrewT, Post #19 shows the same amp as post #13, the bias is functioning (see the .MEASURE directive in #13) and is 182mA. Post #19 can not show the DC bias while the (opto) isolated measurement has no ground reference.
Let me explain what would work, build a zero crossing detector and feed it with the amplifier output, then use a instrumentation amp to measure the voltage across the ballast resistors this will also reference the signal to ground. Next use a S&H to measure the value of the instrumentation amp output at the moment of zero crossing.
Simple you would think, but it is not, to take a sample at 20kHz you only have a few uSec's, timing must be impeccable, the S&H must be extremely fast (I think Jan Didden once went this way [I think], maybe Jan can jump in)
@Osvaldo, Yes that works, that is how it's done all the time (to adjust the amplifier bias). But, I would like to know (for sure, 100%, all the time 🙂) that it is stable under all operating conditions (some one must have done this, some ware, some time, some how).
I just want to know how to do that, and if possible use it to dynamically and automatically adjust a class-AB amplifier (and also to create such an measurement device). I'm sure that (most) amplifier builders would like to have a thing like that 🙂
Thinking in the air, I believe that in a class A is simplest because the mean level of the signal is zero, then filtering out the AC signals will give the Dc component alone. But in class AB it is not true. I was also thinking in a double winded coil, wired substractibely...
Something like this:
@Ketje, 'can not' is not in my vocabulary, if 'can not' then I would like to know 'why not' 🙂, it's there, so we can measure it (see post #13) the question is how? and how simple?
You state "it's there", that's just the point, it isn't.
The bias current is only there in classA situation.
I supose with your vocabulary (or the lack of it 😛 ) you can eat food that isn't there 😕
Measuring the current at zero (voltage) crossing is fine with a resistive load.With speakers zero voltage is no garanty for zero load current.
Mona
@Ketje, it is actually there, in the simulation the .MEASURE directive actually takes a measurement (182mA, see box [in the picture] 'ibiasa' and 'ibiasb')
> I supose with your vocabulary (or the lack of it ) you can eat food that isn't there
I fail to understand what that means (for now)
Edit: O.k. I see now, it refers to the lack of 'can not' 🙂 [in my vocabulary], that's what you get in a world where all is possible (maybe you need to get my CV from LinkedIn 🙂)
@Osvaldo, here is the filtered result for several AC output voltages(vg)
.step param vg list 1m 1 10 45
The results vary from about ... mV to near 800mV
@Osvaldo, here with transformer it looks way better, but I needed to use a 100kH coil to get the shown result. I may be wrong to implement the transformer like this, any suggestions are appreciated.
The simulation shows 178mV (not 182mV) due to the fact that the 10 Ohm transformer is in parallel with the ballast resistors.
The transformer needed is also problematic, a huge bandwidth is needed, say, ...1Hz to 50kHz..., but when all fails this may be a direction to work on.
One problem is, that it will fail at low frequencies but not at DC 🙂
