Hi Tim,
what about TauDAC ?
It's an I2S DAC, which uses two WM8741 DAC-chips in dual-mono mode.
- Does it run out-of-the-box with an existing (generic) DAC setting or
- has to be some driver stuff in Moode integrated ?
Configuring MPD to use the TauDAC as audio output is described here.
Best regards
Tom
How can one non existing DAC be configured ?
Good point but the designer does have his DAC drivers on Github so at least there is the intention of having it exist.
Hi all,
I had contact to the TauDAC developer. The DAC will be available soon …
Have the drivers been accepted into the Linux kernel?
-Tim
Tim, you've been a busy bee!
+1
I updated an RPi3b running r36 without incident even before you posted. I must have checked for an update just after you "went live".
It seemed to me that I had to reboot twice before "About" and "Sysinfo" gave me the correct answers. Other than that, everything seems to be working.
However both an RPi2b and an RPi0w running r36 failed to update properly. In both cases the update process took a while, as expected; the "Reboot required" box popped up as expected; but when rebooted they came up in anomalous, unresponsive states.
All three RPis were connected via WiFi and had adequate power.
Pulling the uSD cards and examining their contents on a Linux laptop, I noticed several odd things, among them /var/www/relnotes.txt hasn't been updated and the size of /var/local/moode.sqsh is only some 900MB rather than the ca 1.9GB I would expect. I can't mount it as a squashfs.
Any thoughts?
Kent
Oh, duh! Guess who tested the RPi2B and RPi0W with fresh r36 installations and forgot to expand their filesystems before trying to update them.
The update downloads and unzips update-r36.zip but then runs out of space while copying the new moode.sqsh to /var/local. That's why I was seeing truncated moode.sqsh files (note that I slipped my decimal points in my first message. Shoulda been ca 90MB and 190MB, not 900MB and 1.9GB).
Might I suggest updater.sh begin with a test for sufficient filesystem space so others can't accidentally poke themselves in the eye with a sharp stick the way I did?
Kent
Kent
Hi Kent,
Moode image is same size on any Pi so if there were an insufficient space condition for the update it would fail on all Pi's with non-expanded root partition.
None of my Pi's have expanded root partition and no issues with updates.
Not ruling out a space issue or other bug, and for sure UPDATER should be checking for available space, md5 checksum for update package, etc. Its on TODO list.
-Tim
Arch Linux vs Rasbian?So there seem to be differences between the kernels used by Rune Audio and Moode Audio.
My DAC (Arcam irDAC) has a remote control with play/stop/previous/next buttons. They worked when connected with foobar2000 on Windows. I am now using moOde, and they do not work for me. It would be very useful, especially to stop reproduction, without having to get hold of the tablet or phone.
Is there a way I can get that working? If not, are there plans to have this supported in the future?
Thanks in advance,
Javier
Thanks in advance,
Javier
Thanks in advance,
Javier
Hi Javier,
I don't know but minimally you would need to solder or wire in an IR receiver on the Pi and then install / configure lirc.
-Tim
Hi Tim,
Can you make the default location for playlists configurable?
I would like to save them on my disk, not on the SD card.
Peter
Hi Peter,
Whats the usage scenario?
-Tim
hi,
is Moode affected by SambaCry? Are there measures we need to take?
thanks,
Walli
Hi Walli,
I don't know but Moode is not guaranteed to be secure.
-Tim
Hi sinski,
moode 3.7 remove isolated cpu core for mpd (1 core) that I found the sound different or you can experiment with 2 cores if your cpu load was too much like me.
But when I tested with my diy digi+ pro that didn't required sox upsamling, unisolated cpu core generated better sound to my ear.
Hi Joe0097,
Can you please tell me more?
Did you edit your config.txt file?
Is it similar to the Sound profile settings from Rune Audio?
Hi, This is my current configure.
http://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-796.html#post5090331
The sound profile setting is new to me, I think you mean irq prorities.
Where I was talking about:
https://github.com/RuneAudio/RuneUI/blob/master/command/orion_optimize.sh
Thanks for your settings.
I am also tweaking for better sound performance based on the aforementioned Rune Audio profile settings, you can read over here
Hi Javier,
-Tim
I'm afraid my question was not clear. The remote control I'd like to use is that of the USB DAC, the DAC already has an integrated IR receiver. The DAC receives the signals from its remote control, then issues commands back to the player, through the same USB connection.
I've read of the HID protocol in the Apple world. As for Windows, when my DAC was connected to my Windows PC, foobar2000 would understand those commands. So I wonder if there a standard we can use on Linux, and whether it would be compatible with moOde.
My question then is: can moOde understand play/stop/next commands sent through USB by DACs?
I hope my question is clearer now, sorry for that. And thank you for this great product, if I'm focusing on these little usability tweaks it is because making moOde work with great sound took no time at all
Javier
- PC Based
- Moode Audio Player for Raspberry Pi
