Aleph J illustrated build guide
Hmmm...
I'm not sure it's the bridges.
Try hooking it up with one bridge for the entire PSU as such -
The secondary centertap will be made by connecting the 'middle' of the two secondaries together.
J is one tough bugger ....... but only you can test that
start with measuring DC offset on output - it must be near 0
then check Iq
if that's good , connect test speaker
however - as you said that you are again hearing some buzz , it's likely that amp survived ......
what you did is same as that you cut your own leg , to check will you be still wobbly , after 2 beer packs last night
:rofl:
Hi Zen Mod,
In shear terror I dug up an old pair of in wall speakers destined for the garbage and hooked them up, using my iPod as a source and after a lot of sweating and panicking the music becan to play! Both channels working, music gets quite loud actually. The transformer buzz can be heard through the speakers though when no music is being played or the iPod isn't plugged into the input. Bias is 411mv on both channels, dc offset 0.01 and 0.04. I can hold my hands on the heatsinks for 8-10 seconds when the amp has been running for an hour.
I've also noticed and audible clicking sound when I put my ear close to the transformer, and it comes through the speakers as well.
I'll have to try 6L6's idea later, and report back.
Hi Zen Mod,
The xformer was a custom order from Primrose here in Canada. It's a 400VA toroidal with 120v primary, and dual 18v secondaries. The manufacturer provided the following specs for the transformer:
Secondary:
1. 18v full load, 19v off load, Iac 11.20, output VA 202
2. 18v full load, 19v off load, Iac 11.20, output VA 202
Here are a few pics from different angles and zoomed in on different areas. The chassis is a little cramped, in retrospect I should've gone for the deeper 4U chassis.
try different bridges
if buzz persist - disconnect one channel completely from PSU
if buzz goes down , issue is load - meaning - Donut is bad for task
also worth thinking of possible DC in mains but that's less likely possible
have you problems with any other amp , connected to wall juice in same place ?
So I hooked up the amp as per 6L6's suggestion and the transformer buzzed regardless of which bridge I used. Zen Mod, I'll try one board at a time to see what happens and report back. As for noise on any other amp, there is no noise at all. I've got a Sansui AU-717 circa 1977 that is dead silent on the transformer and outputs, before and after the full recap last year.
