Tim. Promoting Moode on UK forum Pink Fish Media I am getting asked if Moode can process Tidal see Moode player 3.5 - pink fish media
Is it possible either now or as a development? Thanks
It's possible to stream Tidal, Qobuz and Google Play to Moode from an Android phone or tablet running Bubble UpNp. I would imagine it's also possible via Airplay with Apple devices.
Bought 3.5 as soon as it came out (tho not had time to try it out yet)
and I hardly need to say that Moode is fantastic and Tim is worth his weight in gold
However I do find myself a bit conflicted about Tims decision to go for paid releases, I think it will definitely damage the project and its community in the long run.
My reasoning is as follows ... in selling the software you turn it from a project to a product and if people have paid for a product then they have reasonable expectations that it is going to work in whatever setup they have
Tim will eventually lose the collaborative spirit that is so evident on this forum - all support will have to be down to Tim
Also Tim has mentioned that there maybe paid for releases every 6 months or so - this is starting to feel like a subscription and users will become less and less inclined to be on the latest version - especially if what they have is working
It is bound to drive users to Runeaudio/Volumio etc which in the long run will be bad for Moode
What is so great about Moode is Tim himself - the level of involvement and support is way above the competition - this must involve a lot of work and i wonder whether this is what the users should be paying for (a membership scheme maybe) which could allow Moode to remain free
Anyway just my thoughts, there is no easy answer to this
Lx
Lx
I am not sure what Newton's law has to do with it.Does "Newton" ring a bell? To every action there is always opposed an equal reaction: or the mutual actions of two bodies upon each other are always equal, and directed to contrary parts (law III).
Another question: Would Tim stop developing Moode if nobody pays? If he would depart the project all the previous work would have been useless, so he will not drop Moode. I think Moode is a good reason for a donation, but the users should decide to spend money. There are people around who accept being a milk cow, but some prefer to keep the control.
To me this all about added value. If you consider the effort of writing a piece of software like Moode Player and the support that Tim delivers (lots of examples in this thread) 10 bucks is very modest imho.
We all pay a significant amount for every new Winblows release and i personally find the money far better spent for Moode, which gives me pleasure every day.
Hey, my ALLO BOSS option is gone!
I apologize for adding to this, but I just have to say... You're an idiot, please go away.Does "Newton" ring a bell? To every action there is always opposed an equal reaction: or the mutual actions of two bodies upon each other are always equal, and directed to contrary parts (law III).
Sent from my x600 using Tapatalk
Isolate speakers with GPIO pin and relay
Hello all,
I am a happily using Moode with an old RPI B, TPA6116 class D amplifier and 6N3 preamp.
Thank you very much, the perfect player for me!
When I power on the system (everything goes ON at the same time) I hear a thump in my speakers. Also when turning off but less loud.
I would like to add a 5V relay controlled by one of the GPIO pins of the raspberry pi to isolate the speakers from the system at startup.
Can somebody tell me how to program Moode so that one pin goes high a couple of seconds after boot up?
I really like Moode and the sound of my system. Works very well!!!
I had a little problem in the beginning and maybe it is good to tell others:
I first tried to use an old power supply from an external Hard Drive (12V + 5V) but I did hear a lot of noise from the RPI in my speakers.
Afterwards, I did try a 19V laptop power supply with a DC/DC converter added (to power de RPI with 5 volts). I still had the same noise in my speakers.
So now I use a separate 19V PS for the amplifier and a separate 5V PS for the RPI. That way, I do not have any unwanted noise in my speakers. Very very silent when ON but without music playing.
Oh, and I did also try it without the 6N3 valve preamp and I must say that I did not hear a great difference. So with or without the preamp, the TPA3116 amplifier sounds great (for me). But since I had the preamp lying around, I added it , nice eye candy
So if you know how to configure a GPIO pin in Moode, please let me know as I know close to nothing about programming the RPI.
Ron
Hello all,
Ron
Hello all,
Well, with RPI you will always get a static if you are taking audio out from that 3.5 mm jack.
You need a DAC such as the one from HiFiberry or Allo or IQAudio.
Then you do not need any separate power supplies, and the speakers are saved from the loud thump. A much cheaper and safer option?
order sections for small screens
Hi Tim,
Thanks a lot, all fine for me. Fantastic work !
(except save playlist , but you already noticed).
As I prefer to display coverart above control and then playlist in colomn display for small media, I added this lines in /var/www/css/moode.css in section @media (max-width: 768px):
#playback-panel .row-fluid{
display: flex;
flex-direction:column-reverse;
Perhaps a new configuration choice to implement?
Pascal
Hi Tim,
display: flex;
Pascal
I suppose you are using MoOde 3.5?
Try installing the Advanced Kernel.
Hi Tim.
I want to rebuild kernel with aufs4 patch.
Please tell me the difference from the original kernel 4.4.50.
I can send you the sources for 4.4.39 advanced kernel if you would like, but beyond that you would have to rebuild it on your own.
-Tim
As @joiners mentioned, it possible to stream any music service through Moode by using either Airplay, UPnP or Squeezelite renderers.
-Tim
Its a bug. Try the workaround in the post below. Note the Boss driver is only in the Advanced kernels.
http://www.diyaudio.com/forums/pc-based/271811-moode-audio-player-raspberry-pi-706.html#post5052081
-Tim
Hi Tim,
display: flex;
Pascal
Hi Pascal,
Thats cool. I'll check it out later today.
-Tim
-Tim
Yes.. version 3.5
thank's for your support!
Hi Pascal,
Thank you for your quick reply but I am using a Hifi Berry DAC and still had the noise when using a combined 12V/5V PS.
But the noise in the speakers is gone now with separate PS, perfect music quality now, so that problem is solved for me.
What I need now is a means to isolate the speakers for a couple of seconds when powering the system on.
Ronald
Ronald
Sorry, I meant Vakharia off course, not Pascal....
Anyway, I think the thump comes from the power amplifier, not from the RPI with or without DAC.
Ron
Power amplifier: switch on last, switch of first.
So to avoid any noise you will need a couple of lines of code, maybe?
atb
Ronnie, who thinks there should be a little more Rons (see what I did there?)
- PC Based
- Moode Audio Player for Raspberry Pi
