Don't think I'll need help working on this one, problem is that it power on and plays audio when rocked from first glance I see a swollen capacitor going to clean up the board and check everything, then I'll repost my findings
Sent from my iPhone using Tapatalk
So I can't find any 4700 uf capacitor can I add a 3300 with a 1500uf in parallel to get 4700uf?
You could, but 4700uF is a very common value.
However, are you sure it's faulty? - it's not usually a problem on these large reservoir capacitors, and from the picture it looks like it's just the plastic 'disc' which is domed (something you see quite a lot, and doesn't mean it's faulty).
I'm not quite sure what you mean by your fault description, but a common cause of intermittent audio (or intermittent distorted audio) on Kenwood amps is the input selector switch, or any other switches.
I could use 2 in parallel and it'll work.. As well as your saying it could be the switches and potentiometer, when I check with a multimeter I get different readings
So now I cleaned up the board reinstalled capacitors and it won't power on
No voltage to upc494c 14.5v on both caps no VoLTE on gate pins cause I have no voltage at 494 chip
Follow pin 12 back to see what it connects to. Likely a PNP transistor.
I don't have the service manual for this amp so I can't give specifics.
I followed it to a 2sa1543 transistor 12v on base and emitor and no voltage from collector which is in line with pin 12 of the 494 ic
705 on multimeter and pin 12 connected tithe collector of the a1543 center pin
Does the amp have good fuses in it?
Is that transistor shorted or reading really low resistance from base to emitter (ohms, no power applied)?
If not, follow the circuit back to the next transistor. Black on emitter of that transistor, voltage on base and collector with power applied.
- General Interest
- Car Audio
- Working on a kenwood kac-921
