Xover to filter woofer SB 23NRSX45-8
6.5ms to 10ms?
  • impulse 6.5ms 10ms w+t e fase midwoofer fuera fase LR12 + 3.9mH 1R5 56uF.png
Bufff, you have so many and so stong reflexions in the first 5ms, so we can't make any idea if the bump is due to reflexions or to a problem with the crossover.
Only thing we can do is repeating the measurement a different distances and locations to make a better idea.
One measurement at 1m at listening height for instance...
But it is also clear that we have no FR data of the scanspeak, excepted that we now by its datasheet of a bump in the 500-1000hz, and probably edge diffractions from the cabinet boost this area too...
But without measurement data to feed the simulator..:spin:
Creative Sound Blaster 128 + ARTA LIMP 1.7
I wanted to try this really old soundcard and so I've followed the user manual to perform impedance measurements and at first id didn' work well for it was showing impedance of DUT and a series 100 ohm resistor together. So I have swapped the input channels and it was okay then. It seems that sound card is good until 16-17 kHz. At first I did the loopback calibration but since the channel difference was 0,18 dB I've repeated the calibration with 100 ohm resistor in place without the DUT (device under test) which improved the results.
I don't understand... When you run the calibration process, Limp checks for imbalance and if imbalance is less than 2dbs, it self calibrates indicating you the value of the imbalance found.
In other words, when after running calibration Limp informs that channel difference is 0,18dB, it is not an error message, it simply means that calibration has been achieved successfully and this 0.18dB difference will be accounted for in the measurements further performed.
