The simplistic Salas low voltage shunt regulator
Well, some consider greed a deadly sin. I was merely aiming at more noise suppression at lower frequencies... Subjectively, larger capacitors there produce fuller and thicker soundimage, but it depends on capacitor brand as well!
The main objective difference with very large Vref filtering capacitance is further 1/F (below 10HZ and near DC) noise suppression rather nice to digital clocks and chips but not that interesting in analog audio preamps. Fuller sound can sometimes be side-effect of larger also slower. Most here from what I remember ultimately preferred film capacitors when the noise was passable with small filtering like 10uF in line and headphone stages where the gain is low. But not all.
Thanks again to Salas for the wonderful schematic and to selfy for making DIY small compact PCBs. Here are some of my builds, configured to 5V at 600mA to power up the digital power supplies of a XMOS USB board.
The trimmer potentiometer to be replaced later with a fixed value resistor.
Two boards
I bought the heatsink from TME. It is drilled using a standard drill press, the threads are milled with a tap. The aluminum alloy is very hard of this one.
Non magnetic, brass crews are used.
Here I soldered the rest of the components.
Here's also I third one I made today configured at 5V 1A to power up my SSD drive. It dissipates quite of heat. 😀
Best regards! 🙂
I use 500mW Vishay zener diodes or a combination of zener and LED for Vref. They sound better than the trimmer, at least to me. A good quality fixed-value resistor is worth experimenting as well 😉
I use 4V3 zener for 5V. I buy a batch of 20 or 50 and pick/match to my specific needs.
You did a great job with the finished regulators. Heatsinks look huge 😎
Hey all,
I am building a DAC and i can't decide which PSU to choose of about 7.5K posts written!!
DAC needs 2x 3V3. One for digital and one for analog
A 5V PSU is needed for the USB decoder and 2x 12or15V for the I/V converter
There are 3 different schemes i have read about
1.Reflector-D
2.SSLV1.1 BIB
3.The SSLV drawn by QuangHao For DAC End 2
Can you guide me to make the right decicion, which PSU for each output?
Salas 24V BiB problem
I built up the BiB positive reg SSLV v1.1 pcb from TeaBag.
For Q2 used lowest measured Vidss of (3.4) 2sk117 as supplied from TB.
For Q3 used medium measured Vidss of (4.27) 2sk117 .
For Q3 used highest measured Vidss of (5.18) 2sk117 .
--as per Appendix 5, suggested fet placement.
Appendix 1 c. 10V-25V Mosfet reg. indicates 2 1vpv LED + 1k8R for R3 + 5k trimmer, jumper other parts.
Here's what I get twiddling the 5k pot.
Lo 12v9, Hi 14v5, with Vac=27v15, Vdc35v4 (after diodes).
What I require is +25Vdc for a Pass BA-3 preamp board.
Thanks in advance for direction. 🙂
ICHI aka Joe
24v BiB problem pics
So it does not add voltage. That makes me think maybe there is a problem with load current vs CCS current available. Do you use a dummy load, and what is its value?
Load with 100 ohms, measures 150.25mA at 14v533,
1v276 drop across 8r2 (R1 current Adjust resistor) = 155mA
Load with 50 ohms, ------------154.12mA
Heat sink is mildly warm, no components feel hot. 😕
Transformer output is 27v15acV
voltage past the diode bridge is 35dcV
The heavy dummy load eats up all your CCS early. In other words the reg enters constant current protection mode (just like a lab PSU) when the CCS preset is met. A dummy must be calculated as a representation of your goal load. Say 500 Ohm for a 25V rail 50mA bias load.
I suggest you try again with the reg in original R303 state and a 500 Ohm dummy.
Now tried a 226R load, which with 24v should give a 106mA load to reg.
The result was I got to set voltage out to 24v 🙂 but current measured 91.86mA ?
So, you nailed it! 😉 I was drawing too much current demand.
Don't quite understand why I'm only getting 151mA through R1 (8R4)
when instructions table shows 240mA for an R1 of 8R2 ? I would
guess it has to do with variances of the active devices ? But, that's
beyond my understanding.
What the Pass BA-3 pre-amp requires is a +- 24V supply with 53 mA
per channel, so 106mA total.
Cheers :cheers:
Cheers :cheers:
Is it the calc sheet that pointed 240mA? Measure your green leds Vf in circuit and if its significantly lower than assumed in the calc it can be due to surely lower current provided to them in circuit by a source resistor degenerated JFET than nominal which is stated for high enough current.
Think of 2-3mA and look up their Vf curve in datasheet to see if its near what you can measure across each. Correct to your original goal with a smaller value CCS set resistor or by paralleling one extra to reach the proper value together. Some spare current is good to have.
