Soekris' DAC implementations
Aha! So, out of interest/curiosity (thus the name) - if you were to add an output transformer to the raw output, would a 640 Ohm to 640 Ohm transformer be a good choice...?
It's probably much easier to find 600 ohm types 🙂 And I don't think the difference is enough to matter.... Be aware as even as transformers are specified for 600 ohm use, you get lower distortion at low frequencies when driving by lower source impedance....
Not that I used to be fond of transformers, but research for another project have enlightened me a little....
You must be very experienced with them given all the ethernet implementations. 🙂
Thanks soekris 🙂
Yes - 600:600 would be easier to find!
Please could you explain
in a bit more detail in relation to the DAM? I'm a bit of a newbie!
I have heard a lot of people mention utilising an output transformer between the DAC out and power / integrated amp can have a lovely effect on the sound...
I don't have the knowledge or experience myself, but, was looking into whether I should pursue this train of thought with the DAM board.
If so: what recommendations of transformers would you give?
Thanks soekris
also: any recommendations on getting the 3.3V necessary for the i2s input please?
I have quite some experince with ethernet transformers, actually I started out with ARCnet transformers, if anybody rememeber ARCnet.... But I meant to say: Not that I used to be fond of Audio Transformers ... but you probably knew....
Thanks soekris 🙂
Please could you explain in a bit more detail in relation to the DAM? I'm a bit of a newbie!
Thanks soekris
It's something about basic core behavior at lower frequencies, don't know the specifics as I have never used audio transformers.... But when you look at t.ex. a Jensen Transformers datasheet you would notice that low frequency THD increases with higher Rs, higher level and smaller cores....
So my recommendation would be a premium 600:600 audio transformer, like Jensen or Lundahl, with the largest core you're willing to pay for....
Best source 3.3V for I2S input would be the I2S source power.
Thanks soekris :up:
I'm thinking of using this board to provide the I2S input to the DAM board, should I attempt to find a 3.3V output from it/do you have any advice on using a board such as this please?
http://www.diyaudio.com/forums/digital-line-level/267948-soekris-s-dac-implementations-100.html#post4984687
If we use a transformer here, it only acts as a low pass filter and there is no other benefit. I think this DAC doesn't need more filtering.
What about phase splitter, and isolation?
There is pretty much always positive (and negative) aspects of everything - so it's a matter of what you perfer.
In this case i would myself rather buy a secondary board if balanced is the primary thing your are looking for.
Isolation is occasionally a good idea, but if you want to use a balanced connection, it is the input end that is important, not the output (driving a balanced, differential connection and input from an unbalanced output still gives most of the benefits of a fully balanced setup).
If the following stage is a native balanced, it is of benefit...
But why would a transformer phase splitter be worse than op-amp phase splitter that is there today? I would say it have more benefits, except the THD measurements....
If you use a 600:600 transformer why not connect dirrectly to the raw Vout?
Yes - the raw output was my original suggestion :up: to keep things 'pure' (but I'm a mere newbie!) - however, you mentioned:
In your opinion, if adding to the raw output, what sort (if any) of transformer would you suggest?
If you want to use a transformer then use a Bifilar wound balanced type connected to the balanced outputs with no ground connection.
I use a Sowter 9545 for the simple reason that bifilar winding means the common mode rejection is high so any unwanted common mode noise on the output of a dac cancels. It is this, just as much as noisy ground isolation that is the reason for using a transformer in my opinion.
Sowter Type 9545 DAC INTERFACE TRANSFORMER
Very interesting batteryman 🙂
What about from the raw output please? If I wanted to use that output, what would your suggestions be please?
THD, IM, and limited frequency range are the main downsides. Galvanic isolation is the only real upside. Do you need that?
Limited fequency rangers is really not a problem with a good transformer like LL1690, check datasheet.
Also if THD is what matters most, then why are we even looking at a R-2R dac? At least that is the way i have feel about audio all the time..
I have a pre-amp with both input and output transformer (k&k audio style linestage) sounds wonderful, and i have not yet found a reason to replace it.
There is often alot to get from galvaniserad isolation when it comes to current flows.
What i'm trying to say is that people shouldnt be so fast to dismiss transformers without even trying then.
No, I do not suggest any transformer. I am not sure why you read that I suggest to use transformers. I think it's best to add a buffer, solid state or tube depending on your preference.
