Soekris' DAC implementations
Advice for power supply requirements please
Although I'm slightly embarrassed to ask the Forum - please could you advise as to whther, if using +12V 0V -12V DC power supply to the Soekris DAM 1021 board, should I connect it as I have drawn on the reference manual page?
I've just received my board and don'twant to make a stupid mistake and watch smoke curl into the air above it.......!
Thank you Forum 🙂
I'm thinking of using the following transformer: 30VA & voltage regulator board to feed the Soekris DAM with the +12V 0 -12V DC supply.
Any comments would be valued - thanks again everyone 🙂
and this board (powered from the 9V ac output of the above transformer) to provide the i2s input to the Soekris DAM from an optical/coaxial S/PDIF input.
I'm just figuring out how I'm going to provide the 3.3V dc that I have read that the i2s input requires though!
Again, thank you everyone for any comments/feedback you could give me
Hi
Sorry for my ignorance. Is this a voltage output DAC or is it a current output DAC with a built in i/v stage? If so what is the design of the built in i/v stage?
Where can I find information about its power supply design? One single AC input seems to be very basic. Is it good enough? I see that many high performance digital gears feature multiple AC supplies. The processor must be quite noisy. How is the noice isolated from entering R2R ladder?
Have you looked here
Soekris Engineering ApS, Products
And this "official" thread
http://www.diyaudio.com/forums/vend...crete-r-2r-sign-magnitude-24-bit-384-khz.html
I am sure some of your questions may be answered there.
Thanhks bambadoo, I found information about the power supply at wordpress. It was initialy blocked by my ISP.
I am still looking for information whether there is a current output from the r2r network. The official thread is over 500 pages :-(
Thanks, Soren. I was just thinking about any possible DIY thing that can be done with your DAC. Do you recommend to use external DC power supply as an upgrade or there would be no audible difference compared to the built-in supplies fed by AC i.e. Just a transformer.
