diyAB Amp The "Honey Badger" build thread
what transformer is best to use for dual mono setup with the honey badger?
It depends.
What exactly do you mean by "dual mono"? Two mono block amplifiers, each with its own transformer? Or a stereo amp with one single transformer, but otherwise separate power supplies for each channel?
Also, what rail voltage are you aiming for? The Honey Badger will work well with a range of voltages (mine has +/- 45 VDC, but most use higher voltage).
Need help with wiring
I think I bit off more than I can chew with the Honey Badger. I've had it nearly done for a while but I'm not sure of the final wiring. Attached is a wiring diagram that probably looks confusing but it's my best attempt at figuring out how to do this. I would really appreciate some help in reviewing this to see if I'm on the right track.
Matt
draw just one channel, so that you can see what you are doing.
Build this one channel and prove to yourself that you have no mistakes.
Make sure the Mains Bulb Tester stays off at each stage of the assembly.
Measure the output offset and output hum + noise.
Once that is proved, then copy it for the second channel.
The first mistake I can see (and I went no further) is at the unput. You have two wires from the input going off to different destinations. Why?
Matt
Thanks! To get even simpler, here is just the power wiring for one channel. This should be much easier to read.
I am looking again at your "simplified" wiring diagram
The antek0124 is a dual primary transformer.
You have shown two reds together and two blacks together.
Think of driving one primary winding. Where are your Flow and Return PAIR?
Twist them as a close coupled pair all the way from entering the enclosure/chassis until they reach the insulation of the transformer.
Repeat for the second primary.
I think you will end up with one red and one black twisted as a PAIR. And another red and black twisted as a pair.
DO this for EVERY inter-module connection.
eg,
is that a soft start for the big transformer? Then it should have mains power PAIR arriving from the mains input to the soft start. You do not split the pair into separate wires and run those mains wires to different destinations. Your MUST keep them as a close coupled pair all the way from Source to Receiver.
Jw said
Everything should return to a common point,
My suggestion is to ignore this completely. Every current MUST return to the Source, not to a common point.
Keep the loop area of every inter-module connection at a minimum.
This is easily achieved by thinking of EVERY connection as a close coupled PAIR. Twisting or coaxial is the best way to do this. Many connections will not suit coaxial, so that leaves twisted pair as your solution. That implementation is exactly opposite to Jw's advice.
Jw saidMy suggestion is to ignore this completely. Every current MUST return to the Source, not to a common point.
Star grounding techniques are now wrong? Thank you for again basically regurgitating what I just said, but saying I'm wrong.
said another way, every power rail lines to load must have a return line to its source.....
however if the return point of the source is made into a common point,
then the requirement of the first line is met...
i do not see any confusion here...
this is how i did it in my HB amp...
said another way, every power rail lines must return to its source.....
i so not see any confusion here...
In his imaginary amplifier builds power must not come from a power supply. It would be a lot easier accepting advice and constant correction if he'd ever actually done what he's such an expert on.
