Those are Cornell Dubilier (CDE) 33000uF x 25V Snap In type.
http://www.mouser.com/ProductDetail/Cornell-Dubilier-CDE/380LX333M025K052/?qs=sGAEpiMZZMtZ1n0r9vR22dctXbdJ0qvskRDEMgDnjAA%3d
non-anodized heatsink 300mm * 150mm
Can you measure the temperature of left and right heatsink and possibly of the output MOSFETs?
heatsink left 42.6 and right 43.3 degree
on one mosfets 50.1 degree
thx, nice experiment. I would concur with attila. Low enough temperatures, not a big difference. But interesting to see it can be measured.
...nice experiment...
But unfortunately incomplete. What was the room temperature at that moment? Unless you know that, it is not possible to evaluate how good a job the heat sinks are doing.
room temperature 19 degree 🙂
It looks as if it will be all right, even during the summer when temperatures in Hong Kong reach close to 30˚C. Also, from the pictures it appears the case is sitting directly on the table top. If that is true, once you add feet convection will be more effective and temperature should drop another 3˚C or so.
That tells you that the internal temperature is ~ 20Cdegrees above room ambient.
When room ambient goes up to summer temp of ~ 30degrees C, then the internal temperature will rise to ~ 60degrees C.
That is too hot.
What is the chassis ventilation like? Are there any holes in the floor. Is there room for air to pass through.
Is the heatsink causing the whole chassis to rise to that high temperature?
I have never known an internal temperature to be so close to heatsink temperature.
That is too hot.
Yep, that sounds like February in HK 🙂
That is too hot.
i encountered that the internal temperature as hot as on the heatsink , it may be the thermometer touched the top plate.
yeah, the measurements done yesterday🙂
- Pictures of your diy Pass amplifier
