60 WPC Amplifier for DIY Turntable Motor Drive
Dual 120 toroid transformer
I received the TDA7492 Class D amp from e-Bay yesterday:
TDA-7492 50WPC Class D Amp
The PCB is 3" x 2.5", about the same size as the SG4. I connected the outputs to an Amgis L01-6362 12V toroid transformer and powered the amp using a GST60A24 24VDC 60W wall adapter. To drive the toroid output to 120VAC no load, you will need to reduce the output of the SG4 to 920mVPP using a pot or a fixed voltage divider of 8.2K and 1.8K resistors.
Hi Pyramid,
Thanks for your knowledge and work. I have a couple of dual 120 vac pri. 12v+12v sec. 100va toroids in my junk box. Can one of these be used as the OPT instead of the 115vac transformer that you specified?
David
Hi Pyramid,
David
I've not tried it with 100W xfmrs; it is a bit overkill, but it should work. Although there may be some differences, it wouldn't hurt to try it. You can always go to the smaller xfmr if it doesn't.
The SG4 has a 5V regulator already on the PCB. The problem is the voltage drops briefly and resets the uP. It's easy to isolate from the MK-154. Add a 1A diode (1N4001 or similar) between the MK154 filter cap and the input to the SG4 (anode to MK154, cathode to SG4) and a 1000uFd cap from the SG4 input to ground.
rif
Joined 2003
Hi Pyramid,
Is it possible to tap off the GST60A24-P1J 24Vdc for the 12Vdc supply to the SG4 board via a 7812 regulator instead of having 2 separate AC power adapters?
I was planning that too, but don't take my word for it. I haven't done the math but a 12V drop does concern me from the little i know.
I was also going to put a few seconds delay circuit between the 7812 circuit and the sg4 to prevent the sg4 from going into the startup loop Pyramid described.
So apparently I have the Chinese version of the Texas Instruments IC.
It only has a printed bar across the body at one end for a reference for mounting.
Is this the O end?
Sorry to ask what I am sure is a stupid question, tried to find some info on the web first and everything I found, they referenced a dimple or dot.
