Reflektor-D builds
You don't need low Vgs (th) TTL type like it since you won't use it for below 5.5V Vout. See to get a robust PMOS that you like with comparably low Crss & low RθjC or better.
Very helpful information, thank you ! One last question before I start my search: how much should be the minimum Vdss and drain current? I am planning to run on 0.3A CSS and I have a 12Vac transformer.
using Reflektor D to supply analogue
It Is mentioned that Vref filtering electrolytic 1000 uF has Impact to sound quality
Is 1000 uF value recommended when we power digital loads
what type and value for Vref filt cap would you recommend If we use reflektor D to power analogue
Hi, Salas,
What is the component under the green led in this photo? (in orange square) Would love to buy some since it helps rolling the parts. Thanks.
WYAN
