SARA-2016
Stil missing parts...😱 Input capacitor, now changed ,to bipolar one , thermally coupled pairs on input transistors . 🙂
Regards,Alex
SARA 2016 - tested
Happy new year ! to all .
Good news 😀 ,I have tested SARA 2016 with success ,it's a live and playing well.
Power rail supply only for testing +/-35V , load 6 ohms , offset 10 to 12 mV .
Ton correction, not used ,at all in this case . Short movie with amplifier in use ..... https://www.youtube.com/watch?v=KG_K_8rEDu0 😉
Regards ,Alex
SARA 2016 V.3
Thank you greierasul .....
Have layout another PCB for the same schematic with OT in line ....not tested 🙂
I see ,no one interested in this circuit .....🙁 no comments .
Regards ,
Alex
Work in progress ...... 🙂 SARA2016 first rev.
Finished ,populating boards with components 🙂 will test soon 😉
Regards,Alex
Great amp.
If it only half that good as simulation, is still great.
In my opinion CCS-s (Q1, Q2, Q13, Q20) are too complicated. They are effectively bypassed by R40 and R41. You can replace them (CCS) by resistors, like in Leach Amp, and performance would not be affected too much.
Great amp.
I'm only builder of the amplifier 🙂 Tested also SARA 2016 v.1 and work very well , offset only 3mV 😀 Some pictures ..... 😀
Regards,Alex
Great amp.
Yes, you could replace the CCS's with resistors, no problem, but you will lose most of the "constant" of the current from the input stage. For better work, R40 and R41 could be replaces with CRD diodes. In fact, initially, in SARA-2012, there was again another CCS's in that places but I removed them because the schematic was too complex. The CRD's could be the most right parts there. Simple and effective.
The cascode of the CCS ensure a very high impedance and a great input stage immunity against noise of the rails.
Currents provided to diff pairs are already non-constant, because they vary with input signal, due to R40/R41. R40/R41 also makes PSRR worse.
What i wanted to say is that simple CCS with one transistor and Zener is enough. All what You get from cascoding is swamped in R40/41.
CCRD are good idea, but little too expensive (just quick look at mouser.com, maybe You have better/cheaper source).
