I don't quite understand your question...do you ask if I have compared the SIT amp to the FO connected to my high sensitivity Full Range speakers?
No I didn't. I may in the future but I don't expect nothing spectacular because of system matching...
I was asking about you experience with your SE solid state amp and if you have compared the FO with the SE design (which would mean comparing them with the same speakers).
I don't know what speakers you have. I just mentioned HE speakers because they are usually needed in the realm of SE amps.
OK. I already answered negatively to that, then.
As I said, I may compare them, provided time and energy (second floor system) but I will be wasting 179Watts 😀
For passive multi-way big speakers, I can't imagine better amps right now, though I haven't had the privilege to listen to TSSA.
And FO's price is so low that I can't understand people's hesitation... 😕
M.
I know people happily using the a v2 TSSA on a mid-high way (>150 Hz) with a sensibility of 109 dB/1m, so I guess you would not be the first to be "wasting" watts.
I find the FO 1.4 intriguing and I will most probably grab a pair of modules after completing another (tube amp) project.
Please comment if/when you test!
S
S
i have read about F.O. the best sound is at 45C.i wonder what is going on at temp 55C or 60C.
is the sound worse than 45C?
I have huge heatsinks but with 3 modules each and seems to keep up 45C-50C.
But what about in the summer?
how much is the max temp allowed soundwise an safety wise?
Hello,
Here are some pictures of my FO 1.4 build 🙂
I used the zero switching SMPS from Cresnet, works great.
There's also a softstart module mounted on the back panel, that allows me to use a low DC switch on the front panel and keep all the mains AC wire at the back, far away from signal.
There are also extra CDE LX381 caps on each rail, works great with the SMPS.
The softstart keeps the inrush current at startup low, even with the extra caps.
It is also a very good sounding amplifier 🙂
Danny
Danny
First One L deliveries started
Hi guys
Happy to announce that the First One L modules series is tested (personally by me) and ready for deliveries (first four modules already sent). 🙂
Measured at +/-80 V supplied by SMPS3kA700 it gives 648 Wrms/4 Ohm, 20 kHz.
Members already sent inquiries expect to get proformas in next following days, all other requests welcome, contact email in the first post. 😉
Happy Seasons Holidays, L.C.
Hi guys
make a guess at 120-130, should be close 🙂 well, at least knowing the product I d be ok to pay 250 for a stereo pack.
nice Xmass gift LC ! can you provide more details on total bias (and minimum acceptable) so we could think about heatsink ?
Hi guys
Happy Seasons Holidays, L.C.![]()
Is 2 x 84 dc Ok? Hmm I thought The L had 4 sets of mosfets?
It's hidden on the back of Mundorf cap if I'm not mistaken.
Yes +/-85 V is OK. First One L has four double die mosfets, two modules on the way so you could inspect them in person. 😎Is 2 x 84 dc Ok? Hmm I thought The L had 4 sets of mosfets?
Referred by a friend. interested too!
Please send request to an email stated in post #1 😉
Balanced input board
Hi All,
i was browsing and saw this input board which accept both balanced and SE using a Neutrik NTL1 transformer, not sure can help anyone just sharing.
https://world.taobao.com/item/52475...spm=a312a.7700824.w4002-15260864961.19.8kCQJc
cheers,
ck
Hi All,
cheers,
ck
It would be nice to know the price 🙂
First One L module price is 220 EUR. First One Cap Bank Positive or Negative module consisting of two four pin Mundorf MLytic 3,3 mF/100 V and two WIMA 0,22 uF/100 V, price is 68 EUR/pcs, including one DUELUND silver bypass 0,01 uF/600 V, price is 148 EUR/pcs. 😉
Thanks! 🙂
- Vendor's Bazaar
- First One - mosFET amplifier module
