6BQ5 Ayumi model is in the 'pc tube' library, posted way back at the beginning of this thread.
http://www.diyaudio.com/forums/tubes-valves/243950-vacuum-tube-spice-models.html#post3662623
Please remember that if you re-post any of the Ayumi models, you should include the copyright information. These models are copyrighted by their author.
Thanks for your reply. Believe me I indeed plowed through all the pages here but must have overlooked it somewhere.
Leaves me with the question: Where can I download that library?
You can download the library from Post #2, the one I linked in my previous post.
The file is in .zip format, you have to unpack it before you can use it.
rongon
"You can download the library from Post #2, the one I linked in my previous post.
The file is in .zip format, you have to unpack it before you can use it."
cogsncogs
"To use the Ayumi models in LTspice, you must change all instances of ^ to **. "
Many thanks guys for your help!
cogsncogs
looking for a LTspice model for the Russian 6H13 (6N13).
Did not find it in one of the model libraries.
How different is 6N13P from 6AS7G or 6080? I know there are 6AS7 and 6080 models available.
It is similar to 6AS7G model, but here it comes:
*Eugene V. Karpov library
*For tube of manufacture in USSR
.SUBCKT 6N13S 1 2 3 ; P G C (Triode) 31-Agu-2002
+ PARAMS: MU= 2.35 EX= 1.247 KG1= 637.1 KP= 12.40
+ KVB=300.0 VCT=0.0 RGI=1k
+ CCG=8P CGP=10P CCP=3P
E1 7 0 VALUE=
+{V(1,3)/KP*LN(1+EXP(KP*(1/MU+(V(2,3)+VCT)/SQRT(KVB+V(1,3)*V(1,3)))))}
RE1 7 0 1G
G1 1 3 VALUE={(PWR(V(7),EX)+PWRS(V(7),EX))/KG1}
RCP 1 3 1G ; TO AVOID FLOATING NODES IN MU-FOLLOWER
C1 2 3 {CCG} ; CATHODE-GRID;
C2 2 1 {CGP} ; GRID-PLATE;
C3 1 3 {CCP} ; CATHODE-PLATE;
D3 5 3 DX ; FOR GRID CURRENT
R1 2 5 {RGI} ; FOR GRID CURRENT
.MODEL DX D(IS=1N RS=1 CJO=10PF TT=1N)
.ENDS
E1 7 0 VALUE=
RE1 7 0 1G
.ENDS
http://www.diyaudio.com/forums/tubes-valves/243950-vacuum-tube-spice-models-11.html#post3992239
What do you mean by "spice format"?
Dear jazbo8,
I am using the PSpice 8.0(student version),the library like as this format then working
.SUBCKT EL34 1 2 3 4 ; P G1 C G2;
+ PARAMS: MU=11 EX=1.32 KG1=650 KG2=4200 KP=60 KVB=28
+ CCG=14P CPG1=.85P CCP=12P RGI=1k
RE1 7 0 1MEG ...............
thx!
EF50 PSpice Model
Code:
* Generic pentode model: EF50_AN
* Copyright 2003--2008 by Ayumi Nakabayashi, All rights reserved.
* Version 3.10, Generated on Tue Jul 15 13:48:26 2014
* Plate
* | Screen Grid
* | | Control Grid
* | | | Cathode
.SUBCKT EF50_AN A G2 G1 K
.param GG {(V(G1,K)+0.075140135)}
.param EP {URAMP(V(A,K))}
.param EG {URAMP(V(G1,K))}
.param EG2 {URAMP(V(G2,K))}
.param M1 {((0.016755255*EG2)^-1.7905817)}
.param M2 {((0.45584646*URAMP(GG+EG2/32.476589))^3.2905817)}
.param P {(0.0062465593*URAMP(GG+EG2/71.244579)^1.5)}
.param IK {(U(GG)*P+(1-U(GG))*0.008577125*M1*M2)}
.param IG {(0.0031232796*EG^1.5*(EG/(EP+EG)*1.2+0.4))}
.param IK2 {((IK-IG)*(1-0.4*(EXP(-EP/(EG2+1e-10)*15)-EXP(-15))))}
.param IG2T {(IK2*(0.62975016*(1-EP/(EP+10))^1.5+0.37024984))}
.param IK3 {(IK2*(EP+11000)/(EG2+11000))}
.param IK4 {(IK3-URAMP(IK3-(0.0032552566*(EP+URAMP(EG2-EP))^1.5)))}
.param IP {URAMP(IK4-IG2T-URAMP(IK4-IG2T-(0.0032552566*EP^1.5)))}
BIAK A K I=IP+1e-10*V(A,K)
BIG2 G2 K I=URAMP(IK4-IP)
BIGK G1 K I=IG
* CAPS
CGA G1 A 0.003p
CGK G1 K 6p
C12 G1 G2 4p
CAK A K 5.3p
.ENDS
You need to change the URAMP function to LIMIT in PSpice. Perhaps some PSpice users can help, I am not too versed on the syntax used by PSpice.
This should work in PSpice:
Code:
* Plate
* | Screen Grid
* | | Control Grid
* | | | Cathode
EGG GG 0 VALUE={V(G1,K)+0.075140135}
EM1 M1 0 VALUE={(0.016755255*(LIMIT(V(G2,K),0,1e16)+1e-10))**-1.7905817}
EM2 M2 0 VALUE={(0.45584646*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/32.476589),0,1e16)))**3.2905817}
EP P 0 VALUE={0.0062465593*(LIMIT((V(GG)+LIMIT(V(G2,K),0,1e16)/71.244579),0,1e16))**1.5}
EIK IK 0 VALUE={STP(V(GG))*V(P)+(1-STP(V(GG)))*0.008577125*V(M1)*V(M2)}
EIG IG 0 VALUE={0.0031232796*LIMIT(V(G1,K),0,1e16)**1.5*(LIMIT(V(G1,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+LIMIT(V(G1,K),0,1e16))*1.2+0.4)}
EIK2 IK2 0 VALUE={V(IK,IG)*(1-0.4*(EXP(-LIMIT(V(A,K),0,1e16)/LIMIT(V(G2,K),0,1e16)*15)-EXP(-15)))}
EIG2T IG2T 0 VALUE={V(IK2)*(0.62975016*(1-LIMIT(V(A,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+10))**1.5+0.37024984)}
EIK3 IK3 0 VALUE={V(IK2)*(LIMIT(V(A,K),0,1e16)+11000)/(LIMIT(V(G2,K),0,1e16)+11000)}
EIK4 IK4 0 VALUE={V(IK3)-LIMIT(V(IK3)-(0.0032552566*(LIMIT(V(A,K),0,1e16)+LIMIT(LIMIT(V(G2,K),0,1e16)-LIMIT(V(A,K),0,1e16),0,1e16))**1.5),0,1e16)}
EIP IP 0 VALUE={LIMIT(V(IK4,IG2T)-LIMIT(V(IK4,IG2T)-(0.0032552566*LIMIT(V(A,K),0,1e16)**1.5),0,1e16),0,1e16)}
GIAK A K VALUE={V(IP)+1e-10*V(A,K)}
GIG2 G2 K VALUE={LIMIT(V(IK4,IP),0,1e16)}
GIGK G1 K VALUE={V(IG)}
* CAPS
CGA G1 A 0.003p
CGK G1 K 6p
C12 G1 G2 4p
CAK A K 5.3p
.ENDS
Dear cogsncogs, Thanks for your support, the lib still shown the errors as below🙁
Try this one, we will get it eventually...
Code:
* Plate
* | Screen Grid
* | | Control Grid
* | | | Cathode
.param GG 0 V=V(G1,K)+0.075140135
.param M1 0 V=(0.016755255*(LIMIT(V(G2,K),0,1e16)+1e-10))**-1.7905817
.param M2 0 V=(0.45584646*(LIMIT(V(GG)+LIMIT(V(G2,K),0,1e16)/32.476589,0,1e16)))**3.2905817
.param P 0 V=0.0062465593*(LIMIT(V(GG)+LIMIT(V(G2,K),0,1e16)/71.244579,0,1e16))**1.5
.param IK 0 V=IF(V(GG)>0,1,0)*V(P)+(1-IF(V(GG)>0,1,0))*0.008577125*V(M1)*V(M2)
.param IG 0 V=0.0031232796*LIMIT(V(G1,K),0,1e16)**1.5*(LIMIT(V(G1,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+LIMIT(V(G1,K),0,1e16))*1.2+0.4)
.param IK2 0 V=V(IK,IG)*(1-0.4*(EXP(-LIMIT(V(A,K),0,1e16)/LIMIT(V(G2,K),0,1e16)*15)-EXP(-15)))
.param IG2T 0 V=V(IK2)*(0.62975016*(1-LIMIT(V(A,K),0,1e16)/(LIMIT(V(A,K),0,1e16)+10))**1.5+0.37024984)
.param IK3 0 V=V(IK2)*(LIMIT(V(A,K),0,1e16)+11000)/(LIMIT(V(G2,K),0,1e16)+11000)
.param IK4 0 V=V(IK3)-LIMIT(V(IK3)-(0.0032552566*(LIMIT(V(A,K),0,1e16)+LIMIT(V(G2,K),0,1e16)-LIMIT(V(A,K),0,1e16))**1.5),0,1e16)
.param IP 0 V=LIMIT(V(IK4,IG2T)-LIMIT(V(IK4,IG2T)-(0.0032552566*LIMIT(V(A,K),0,1e16)**1.5),0,1e16),0,1e16)
BIAK A K I=V(IP)+1e-10*V(A,K)
BIG2 G2 K I=LIMIT(V(IK4,IP),0,1e16)
BIGK G1 K I=V(IG)
* CAPS
CGA G1 A 0.003p
CGK G1 K 6p
C12 G1 G2 4p
CAK A K 5.3p
.ENDS
May be a floating point error...
In the model I posted (post 1276) try replacing this line:
with this to see if it will converge:
Code:
Code:
EM1 M1 0 VALUE={(0.016755255*(LIMIT(V(G2,K),0,1e16)+1e-03))**-1.7905817}
- Tubes / Valves
- Vacuum Tube SPICE Models
