Salas DCG3 preamp (line & headphone)
diyAudio Chief Moderator
Joined 2002
It's a short spike, long before relay enagages.
If you look carefully on the sheet, it's only for around ~3sec. EDIT from 1sec. to 3Sec.
This Almemo thing i brought home from work, is soo cool, can meassure 1/100 pro. secunds data log. -I am using it for periodical failure faultclearence on our cranes at Port of Fredericia https://www.adp-as.dk/
Jesper.
I suspected so. Because after 5 secs the relay takes to engage it still goes lower for offset but a spike is unlikely. Danish are big in sea cargo transports (Maersk for instance) but also among leaders in power windmills I think?
So I am going to put on some headphones now, probably the Senheiser HD-600 for midline balance reference to compare the tonal balance of the full speakers system including the bass columns in room from a far distance. So to fine tune the buggers during weekend if I am lucky. Because measuring and preparing one head at 70cm alone does not tell the whole story regarding all angles sound illumination in stereo and much bigger room. Also the Foobar needs to be set again for DSD after I migrated to minix atom pc for the stereo and Kodi. Aaargh! :D
Joined 2002
No, Linux I hope on Nuc will be when able to have it later on. El Capitan OSX on virtual machine even. But now on kitchen TV monitor or on 140 Euro Minix atom PC on larger TV with so small keyboard that if I type in one try and succeed a word its so big event like winning the Olympics :D
Warning offtopic
Speaking of olympics : This might be yourself ::
Apollo
Apollo was the god of moral order and music, but his main capacity was to protect the art of divination. This is revealed by the plethora of oracles in various regions of Greece, the most famous being the oracle of Delphi, in Fokis. Apollo is also seen as a pastoral god, protecting his flock from the wolves. He was worshipped by the farmers as the god of the harvest. From Antiquity onwards, he had the reputation of a god of healing.
:D:D:p
Houston, I lost my canon printer too last week! I hope there won't be any sequence...BTW I' ve found that my sound card' s native ASIO drivers work better than Wasapi and ASIO4ALL. In this case Foobar is NOT set for ASIO, it only sees the sound card (Asus essense stx II)
OK, I' m not playing native DSD at the moment so I' m not aware of this. It just makes me curious that that the above mentioned setting also works when I use Foobar's SACD component for DSD to PCM playback! No ASIO settings in Foobar.
Anyway, today I lost the ATX psu of my audio PC...I should have kept my mouth shut!
Joined 2002
Jinx or our PC stuff is reaching MTBF. Bad thing is when one thing fails usually the standards have been changed and it takes to upgrade other stuff too when replacing it. PSUs are more standard usually though.
DoP works without need of ASIO settings or alike if I remember well. And it sounds good too. Native DSD is not nice ergonomically by the way. Can't have visualizations, can't play with volume fader (less than 100% mutes), and there is audible glitch on forward - back - next.
