CFH7 Amp
Hi Thimios,
You must be exhausted from working on this amp non stop and now taking a break. Take your time - just wondering what we need to do to implant the fixes.
Thanks again.
X
Yes X,just stil working on it!
The first critical modifications is to leave these C14,C16 positions empty.
Νow simply playing with different VAS current to see what is better.
I see a little higher distortion in the high frequency area.
Maybe Shaan or Valery can help.
This config has consistently given me good results.
Showing only the positive rail.
The negative is the same, only capacitor/diode polarity reversed.
C1= 100uF (right after PS input).
C2,C3= 100nF (as close as possible to drain pin of MOSFETs).
D1=1N4007 (powered with separate trace from C1, with a close-by ground trace from PS ground to connect C2,C3,C4).
R1= 10R.
C4=220uF (VAS and input powered right from C4 supply pin).
Hope this helps in future designs.
R1= 10R.
R2=?what about VAS current?
post782 describes well what one needs to do, to layout the local supply rail decoupling.
Note the statement
This is the decoupling ground. It is where the half sinewaves going to the output get resolved.
Layout design is not about making it look aesthetically pleasing, it is about getting the currents to follow the desired routes that maximises circuit performance.
Try running 150mA to 180mA bias (ea MOSFET) on the outputs and see if that helps. I did not notice rising distortion at the speaker - which natively have -50dB THD.
Was it the fact that the original power rail caps were improperly grounded or because they were so big (4700uF) that caused problems by allowing a low frequency ground loop to form?
See post#781.
Shaan you mean like in this photo.
I haven't try the Shaan's last modification yet but i have modify the circuit(15K+4K7) for about 18mA VAS current and the idle current adjust to 136mA.
Here are the results.
c
Using RMAA software.
Shaan, the amp schematics has gone through many iterations and some are representing proposals for improved modifications, it makes the discussion of the amp somewhat confusing, but lets straighten out a few things.
On a general note, when the audio signal enters the input stage it is ground referenced, but after T1(T2) there is a level shifting, the audio signal is not anymore ground referenced, this is very important to keep in mind, it is now split up and referenced to + and - rails respectively.
That means, when the audio signal enters the VAS stage T3(T4), these transistors must have both base and emitter referenced to the same + and - rails, but when adding a 10R and another big electrolyte on the other end of the 10R that splits up the reference point between base and emitter for these VAS transistors, they now have 2 different references with respect to the signal to work against, this is suboptimal, please remove R17(R21) and add a short in place of these resistors.
