I want to share this to your project, please see the information here:
http://www.diyaudio.com/forums/quanghao-audio-design/300246-dac-es9038-pro.html
I want to share this to your project, please see the information here.
I need a minimum of 15 people to help me implement this project. Thank you very much!
DAC ES9038 Pro have these features: : Design by Andrea-Quanghao
Ouput: Stereo - 2 Channels 8 to 1 parallel
- PIC Microcontroller to remap DAC and share I2S connection with DSD signals
- Amanero module integrated to have USB input
- Support 44,88,96,192,352,384KHz PCM tracks
- Support 64,128,256,512 DSD tracks
- Able to play also SACD ISO from PC
- Full ground isolation from USB module
- On board reference 100MHz TKD oscillator
- Ultra fast oscillator buffer
- 4 inputs: USB, Spdif coax on BNC, AES/EBU Professional on XLR, Optical Toslink.
- Many output stages choice
- 4 row x 20 characters LCD
- Controller compatible with any 5V LCD and VFD
- Simple and cheap firmware upgrade
- Large dB volume display
- Ultralow Noise, Ultrahigh PSRR RF linear power supply regulator
- Separated LT3042 for any digital section
- Separated LT3042 for any analog channel
- Remote volume control
- Remote mute control
- Remote input control
- Digital filter control
- Stanby control
ES9038 DAC MODULE
The DAC module use a dedicated power supply with LT3042 separated for any section of the ES9038PRO:
Digiltal supply:
- 1.2V core: LT3042
- 3.3V oscillator: LT3042
- 3.3V digital: LT3042
- 3.3V Top-botton chip
- 3.3V USB: LT3042 (If you not like us 3.3v from Computer for USB)
Analog supply:
- 1.2V analog (left and right separated): LT3042
- 3.3V analog (left and right separated): LT3042
- 5V for LCD: LT1117
- 5V Analog supply: LT117
- 5V Digiltal supply Digiltal supply: LT1117
All the power supply use a LT3042 Ultralow Noise, Ultrahigh PSRR RF Linear.
This module the ES9038PRO when connected to the controller module can be configured to select 4 different inputs with button or remote:
- I2S/DSD to use with USB OEM Combo 384 (Amanero)
- This DAC match with Amanero USB
- Coax Spdif RCA
- AES/EBU professional transport on XLR
- Optical Toslink.
This options are available and here the new cost:
1) DAC module assembled and tested with all components:
- ES9038PRO chip,
- CCHD-575 Ultra-Low Phase Noise Crystal Oscillator: Ultra-low phase noise CMOS oscillator provides 168-dBc/Hz noise floor | Electronics EETimes
- 7 x LT3042 linear power supply regulator 1uV noise
- 5 x LT1117 linear power supply regulator.
- All input connectors
- BUT NO OUTPUT STAGE
price 400$
2) DAC controller- Encorder + 4x20 LCD:
see video for LCD: https://www.youtube.com/watch?v=4owue3-wXpE&feature=youtu.be
- 20x4 LCD
- Infrared remote command
- Remote silver
- All connectors
price 150$
3) Amanero module
price 97$,
Please purchase directly from: : https://amanero.com/
4) Transformers, for the DAC: 6.5V x 2 / 15VA
price 30$ each
5) Chassie: include: weighs: 10 kg
- 1 x chassis, iron powder coated black, size: 420 x 380 x 86 mm,
- 1 x front surface silver anodized scratch: 430mm x 92mm x 10mm.
- 4 x rubber feet: 20mm high, 50mm wide
- 2 x aluminum knob 26mm x 38mm
- 1 x Plug + switch
- 20 x copper base 10 x 3 mm
- fasteners: catch the front, the back, motherboards, storage tank foam.
price 150$
Shipping by TNT:
A. The options : 1 to 3 : 50$ ( the same price)
B. The options : 1 to 4 : 70$ ( the same price)
C. The options : 5 : very heavy, calculated separately for each country.
This project is a great DAC, I want to share with you,
However, I need your help, let me do it!
The minimum required number 15 set: DAC+ Controle DAC
I started producing.
Payment: half the amount for the selection, the remaining amount of money + shipping payment before shipping.
Payment by paypal: quanghao168@yahoo.com.vn
Paypal free: 2%.
Note: Because this is a shared project, and need money to produce,
Therefore, you have paid half of the money for the project will not be allowed to get back the money - this is a mandatory provision of this buying group!
One-year warranty.
You send me back defective products and carrier billing yourself.
I return it to you and I pay for shipping to you, after you're done!
please write your nick to the list below with the choices you love:
- Stanby control
ES9038 DAC MODULE
Digiltal supply:
- 1.2V core: LT3042
Analog supply:
- Coax Spdif RCA
- Optical Toslink.
- ES9038PRO chip,
price 400$
- 20x4 LCD
- Remote silver
- All connectors
price 150$
3) Amanero module
price 97$,
price 30$ each
- 1 x Plug + switch
price 150$
Shipping by TNT:
Paypal free: 2%.
One-year warranty.
Will this be able to play PCM converted to DSD512? Also, I am interested in the 1 to 3 option but was wondering if I could get the transformer outputs? Thank you!
Bao
Bao
Hi bvtrinh!
1. Will this be able to play PCM converted to DSD512?
yes, run depending on your computer.
DSD runs 64 and 128 is simple.
2. I could get the transformer outputs?
You can buy directly from lundal LL168
Welcome you!
Thank you!
Welcome you!
Thank you!
Hello, is there a list to add my name or should I just post it here?
EX; please write your nick to the list below with the choices you love:
1.bvtrinh : options : 1 to 3
thanks
Please write your nick to the list below with the choices you love:
thanks
thanks
Bao
As specified in Amanero website DSD256 and DSD512 are supported on Windows but some software like JRiver convert on the fly the PCM to DSD only at DSD64 or DSD128.
[SIZE="2
- ES9038PRO chip,
- Crystek TKDMHz performances oscillator
- 3 x LT1117 linear power supply regulator
price 450$
Do you meant separate I/V is needed?
Ouput: Stereo - 2 Channels or 4 Channels
- Stanby control
ES9038 DAC MODULE
Digiltal supply:
- 1.2V core: LT3042
Analog supply:
- Coax Spdif RCA
- Optical Toslink.
- ES9038PRO chip,
price 450.00$
:[/B][/I]
When did the price change? I thought this was 350?
i see that, because the chip ES9038PRo is very expensive and need buy big
about : 75 pound / chip
Ok, i think again the price!
thanks
Hi syklab!
Thanks[/QUOTE]
yes, you need use IV make or, get my PCB and make tube IV for this DAC.
Link: http://www.diyaudio.com/forums/group-buys/282836-hq-iv-tube-output-balance-dac.html
thanks
Thanks[/QUOTE]
thanks
2. chriselm: : options : 1 to 3
3. Zander Araujo : 1 to 3
4. lindamar : options : 1
And this video ES9038PRO
https://youtu.be/4owue3-wXpE
Buy List
5. akltam option 1,2,3,4,5
Questions
1. Can I use the transformer output stage from the ES9018 DAC (i.e. using Lundahl LL1684 ? Simply install onto the dac ?
2. I need only 2 channel (Left and Right). Do I have to set it on the DAC ? or do I have to specify when I order ?
Alan
Alan
suggestions
Hi Quanghao,
Will you consider to produce a dual-mono ES9038Pro instead ? I will also support a dual-mono setup !!!
Alan
Hi Quanghao,
Alan
Hi akltam
YES, good and simple
That is an option,
A switch: for two-channel and four-channel. Very easy to use.
it is available on-board DAC.
Take a look at my pictures.
Sincerely thank you!
That is an option,
- Group Buys
- DAC ES9038 PRO Group Buys
