I've been able to match all specs in simulation.
The only thing I'm considering is whether to FAB the biasing circuit or put together a thermally compensated biasing circuit for the output stage.
Probably try it without thermal compensation to start with.
Well there you go, although it's worth a word of caution from lhquam who
has been exploring the failure of the semi models to accurately predict
distortion and such.
As to biasing, you can do it the regular way, or you can just use a big sink
and adjust the value until it settles into where you want it - just takes a
little longer warm-up time.
That sounds a bit more heavy than normal, we all wish you a short recovery time.
And in the dull hours no monster amps but lovely ones might stride through your brain
Three stages, DF is about 700, high current, high slew, .00x% distortion,
40 uV output noise, big Class A envelope, 25 watts into 8, 100 watts into 2.
And it sounds great.
Thank you mr. Pass for these, what a person you are 🙂 Some constructor would not say even a word of his construction, just that it sounds good 🙂
Ok, mine 2 cents: something with square law in output stage (gives high class A swing), input maybe singleton /vas stage with bootstrap...?
Just blubbering.. 😛
Papa: Back about 30 years ago I have some co-workers from LapLand who served a Spiced Red Wine (Glögg) for winter holiday events. It might be the right prescription for your flu.
Nelson, I feel for you I don't have the FLU but I did pick up a bad cold
and have been coughing so bad my stomach and some back muscles hurt.
So I am wishing both of us make a quick recovery !
Has anyone noted that IXYS has announced SIC MOSFETs in the SOT-227B package, in particular IXFN50N120SK? IXYS launches 1200V SiC power MOSFETs in SOT227 MiniBLOC packages for higher-power applications PartDetail. The datasheet is rather sparse, but indicates Ciss < 2000pF!
Independent of SIC vs. silicon, the SOT-227 package also introduces the possibility of using the second (Kelvin) source connection for current sensing in PCF.
The press release shows a Kelvin connection on the gate. Doesn't seem correct the other parts it is the source.
The datasheet shows the Kelvin connection to the source:
http://ixapps.ixys.com/Viewer.aspx?p=http://ixapps.ixys.com/DataSheet/IXFN50N120SK.pdf
It looks like mouser will have them but the price is steep. It says the kelvin connection is on the gate. http://www.mouser.com/ixys-ixfn50n120sk-ixfn70n120sk/
http://www.mouser.com/ProductDetail...WkS%2bI7uVPsPlBEqn5aWCsrKIdY9/ikzF4eC9Qbvgw==
The hocky-pucks are a game changer for Class-A amps in several ways that I can elaborate on at another time. Nelson claims that the XA25 amp is very simple (I believe him), and if the released specs are (relatively) accurate then here is my guess:
- JFET input stage with positive current feedback (PCF) of either Type-2 or my recently discovered topology described in the F7 thread.
- Complementary, undegenerated common-source laterals for the front-end stage outputs. What laterals (NOS) might your suggest for the front-end?
- Complementary, undegenerated IXYS output fets running at about 1.3A with 26V-28V rails. With the SOT-227 package the thermal coefficient is about .2C/W Junction to heatsink. With the devices running at about 35W each that means that the junction temperature is only about 7 degrees higher than the heatsink, and thermal runaway can be easily prevented with simple thermistor feedback to the output stage bias circuit.
Any suggestions for medium power complementary laterals that are available for the front-end stage outputs?
Perhaps the Exicon/Alfet laterals?
I am looking for a TO-220 size complementary laterals with low Ciss for the front-end stage. The Alfet parts are really power fets suitable for output stages.Perhaps the Exicon/Alfet laterals?
I could imagine that the "no degeration" statement in the advertisement is only meant for the outputstage.
The XA25 description in Pass Laboratories XA25 says the following: "This also allows elimination of degeneration, “that other negative feedback” in all stages". If that is to be believed, then the front-end outputs would not be degenerated. That could be safely done with laterals, but I am not sure that would be a good idea with vertical MOSFETs.I could imagine that the "no degeration" statement in the advertisement is only meant for the outputstage.
GRR....you are right and I am wrong....🙂
So even the J-Fets could be without resistors at the sources. An excercise Nelson already showed with the F6 as a possiblity, if you have the right Idss in the drawer.
I addressed some the topic of degeneration in my BAF 2016, and I have
the raw video for that thanks to WBS. Just waiting for bandwidth to arrive
on the 1st....
In any case, the drift of Ids against temperature is quantifiable and can be
easily handled without degeneration if you have adequate sinking and are
willing to do lengthy adjustment and put up with longer warm-up times.
Just things that DIYers are good at and commercial manufacturers are not.
on the 1st....
I already have those parts, but I don't believe that is what is used here.
Any chance we can get a sound comparison of XA25 against some similarly powered X products from Mr. Pass? I am curious how the "half X" amp compares to the "full X" models. My SPICE fiddling shows impressive figures for my guess at an XA25-like circuit, but the SPICE numbers don't tell us how it will sound in real life...
- Pass XA25?
