What is wrong with op-amps?
It is indeed going away. Right now its on lifetime buy but I'm not sure on the exact date when production officially stops. Better get an order into your distributor. 🙁
Initially a much larger group of the LME devices were going EOL, but thanks to much screaming some of them seem to have been spared (I believe the LME49600 is off the chopping block for now). But LME49990 wasn't one of the ones brought back from the dead.
If the natsemi parts are on special or tweaked processes then I can understand that the cost of transferring the process vs sales is a factor in killing them off.
Are the 4562/49710 etc being spared/transferred?
The LME49990 is a nice chip - I used it one of my pre's inside the f/back loop of a LME49710.
Another alternative is the TPA6120. Its not an open loop buffer like the LME49990 but it is very wide bandwidth (re-purposed ADSL/Video driver IIRC), very low distortion etc. This chip easily drives a pair of 32 ohm headphones. Other alternative is to go discrete - then you can also go class A if that appeals. I did this on my last preamp and got good results.
Or go completely discrete: http://www.diyaudio.com/forums/soli...k3-cfa-pre-phone-amp-very-low-distortion.html
Dado
what do you think did LM2407 and other similar HD CRT video drivers chips is usable for some audio app.?
I'll tell you if you can explain what "transistor linearity" is.
"Transistor linearity" is, the extent to which the proportion between input and output amplitude (for the transistor acting as amplifying device) is the same for high amplitude and low amplitude input... according to Wikipedia. Now you owe me the answer to the question: 😉
What do you think the result will be?
which is a question related to an effort (3 schemes as examples) to improve LM4562 stability in a low (signal) gain circuit.
I started in my early teens with Knight and Heathkits, and then Dynakits.
Philips sold on the Dutch market a clever box with components, and a board on which spring loaded connecting nodes could be placed. It also had some schematics with radio's and other stuff that could be built with it. My dad bought it for me when I was still in elementary school, after he had explained to me how a triode amplifier works, and I apparently had understood what he was saying. Many funky things could be built with it à l'improviste, and all this contributed to the fact that I never formally studied EE.
I think you might have the LME49990 confused with LME49600. The 49990 is a bipolar op-amp similar to OPA1611, whereas the 49600 is the buffer.
You guys had it too easy with your fancy premade kits.
School mates and I went dumpster diving at the local telephone exchange...all sorts of goodies.
The local TV/Radio repair shop was 5 doors from home, same deal I had free reign to dive into their dumpster also....really cool goodies for a 12 yo to strip and repurpose all manner of parts.
I even made my own pcb's, and built an amp using TH parts using surface mount layout.....long before ever hearing of SMT/SMD.
Dan.
You guys had it too easy with your fancy premade kits. School mates and I went dumpster diving
at the local telephone exchange. I even made my own pcb's, and built an amp using TH parts
but surface mount layout.....long before ever hearing of SMT/SMD.
I couldn't dumpster dive until attending university, then it was hog heaven. Also made pcbs in my apt sink,
but soon wised up and found a nice small company in NC (Atlas Circuits) who made photo pcbs, big improvement.
I just ordered a used copy of Thomas M Frederiksen's (RIP) 'Intuitive IC Opamps' from Amazon which arrived today - I used to have this years ago but lost it in one of my many moves. If you don't work with opamps professionally, this is a very good introductory text to these devices with a discussion on the inner workings of opamps, lots of worked applications circuits covering filters, oscillators, a good section on feedback and compensation etc.
This book is still in demand 30 years after it was first published in 1984. I paid $6-00 for my copy - shipping about $15 on top of that. There's still a few around - highly recommended.
