well maybe my computer is possessed?
That link brings you to the first post... and the link on the first post brings you to... the first post. <lost>
Wanted to mention that you might edit that text and put a date WRT the boards availability? 😀
So, what's the deal, PM you or??
Post links have never quite worked right on this site...
I designed the current PCB. It's a mono 5x5cm board. Pricing is $3 shipping plus $8 per board. PM me your info. I will try to get something more convenient set up.
Construction and BOMs:
http://www.diyaudio.com/forums/anal...error-correction-superbuffer.html#post4834519
My browser bounces to the first page, then skips to the correct page and post. Maybe you're not waiting long enough? Maybe you're on that horse **** satellite internet so it takes forever?
I can truncate the link so that it takes everyone to the right page. The problem is, that only works when the link is not on the first page of the thread! The mind boggles. What a pain. Try it again, I did something else.
OnSemi owns several fab plants, bought at different times, and situated at different locations. From vendors, it occurs that some are parts shipped at half-specs, and rather too often. This is especially inconvenient if you had expected matched pairs. I'm finding it unnecessary to say more on that.Why is it recommended to use the Fairchild transistors? What is wrong with the ON Semi ones?
guys I apologize for the stupid question, but where is this buffer reccomended to be placed at best? between the preamp and the final amp? between the analogue source and EQ/preamp?
Also i have a few questions
When we have the need to put a buffer between source and amp?
my source has 0.1Ω output impedance and my amp 100ΚΩ its necessary the buffer?
The source with 0.1Ω output impedance should see a constant load ?
Can i put the pot after the buffer between buffer and amp lets say 10ΚΩ pot?
Post722 has a link that takes me to posts695Post links have never quite worked right on this site...
Here is the link
this link also took me to post695.
Then post696 suggests you add a link to post1. But that has still not been done !
A Buffer gets added to the output of a stage that is incapable of driving the cables that follow it.guys I apologize for the stupid question, but where is this buffer reccomended to be placed at best? between the preamp and the final amp? between the analogue source and EQ/preamp?
I have seen a few of your posts stating this 0.1ohm for output impedance.Also i have a few questions
What kind of output stage does your DAC have?
Engineers would say there is usually no need for a buffer, unless you're driving long cables or you have a high impedance input like a phono cartridge. One good place for it is after the volume control to reduce the source impedance seen by your amp. It can be good to have a few available as a diagnotic tool as well.
With a direct connection there is no technical reason to use a buffer. Since the volume pot can have a high output impedance, it is usually best to put the buffer after the volume pot.
Actually I did right after you posted that. I even updated that link earlier today.
Hi Andrew
AK4490 Mirand Discrete..
Your link does not work.Actually I did right after you posted that. I even updated that link earlier today.
Go to post695.
click on the post number and the Browser takes post695 to the top of your screen,
Right click on the post number. Firefox gives the option to Copy Link Location, Click on that.
Paste that into post1
IE offers the option after right click of copy shortcut.
Click on that and then paste into post1.
going toHi Andrew
AK4490 USB Dac with dsd support – Without shield | Mirand Audio - Solidstate designs
does not tell me what kind of output stage is fitted to your DAC.
going to
AK4490 USB Dac with dsd support – Discrete DIFF/SE shield, PCM Filter setting | Mirand Audio - Solidstate designs
found it:
Now where does it say 0.1ohm output impedance?Output stage – Fully discrete differential and single ended
Thin Film resistors 0.1%
PPS capacitors 2%
Discrete SSR relays for muting
6 discrete JFET input opamps running in class A
found it:
Here is the answer that i get from Sonny.
""It is below 0.1Ohm on all the outputs. Main limit is the mosfet's used for switching.""
- Analog Line Level
- The Kuartlotron - keantoken's simple error-correction superbuffer
