Transistor Preamp
Aspen Preamp
Thiago,
Here's one from 2002. I sold quite a few. This uses a SS gain block and tube cathode follower output, with Zout around 130R. Sounds very, very good.
In 2010 I redesigned the SS section to use a CFP with gain. It actually sounded much better.
Hugh
VHex-Pre
Hello all!
Here is my view on the overall preamp solution, including the line stage with 12db gain and optional unity gain balanced line driver.
Note - it's very, very quiet. Noise is below any practical level - with the input shorted, you hear nothing (better than -110db).
The circuit is powered from +/-15V DC rails.
We will most likely come up with the layout for the whole thing pretty soon.
Valery
Thiago,
Hugh
Hi Hugh,
I like the tube section.
I assume, V2 is buffering inverted signal for the balanced output, right?
Valery
Hello all!
Valery
Looking forward to the layout/Gerber on this one! Thanks for the design.
Hello all!
Valery
Hi Valery,
Thank you so much for posting here.
What is your recommendation for PSU (shunt or LM78XX) for your pre-amp design, and can it be incorporated on the pre-amp PCB itself (if at all possible), so all that is required is a XFR to have a working pre.
regards
Prasi
edit: changed text as per underlined.
Hi Valery,
I might disappoint you!
No, this is unbalanced output. The inverter and CF is set up to compensate the high impedance B+ supply to ensure seggtrong bass output that was atypical for a tube. The tube was a variable frame grid 6ES8 which added extra H2 / H3 for a cathode follower.
HD
Hi Valery,
HD
Ahha ... This is even more interesting!
Thanks for sharing 🙂
Hello all!
Valery
Hi Valery,
This looks like the revised Ampliwire with the op-amp balanced circuit added to it.
Is this correct?
Thanks.
I have made yesterday a simple preamp. A bit similar to marantz PM7000 front end or the AD797 OPamp. The ADPreamp is very simple, performance is good to. It is dead quiet at idlle. I have measured it with 1k load and didn't blow up 😀. The modulated 3kHz 4kHz and 5kHz doesn't show any IMD products (only my crappy psu noise).
With two mosfets at the back or BD's could create a nice headamp.
I have shorted the NFB cap and the offset was about 5mV, so with a bit of the work it can be done a full DC coupled (I hope anyway).
Regards Pit
I like the SR PP8 Mile; it has bandwidth. This also puts the high pole so high that compensation is trivial. I believe it is a emitter drive version of the 1972 Hitachi AN for lateral fets. I have heard this in a power amp and it's very good, with very little phase shift.
Congratulations! Like many of your designs, it is both elegant and simple.
Hugh
