100W Ultimate Fidelity Amplifier
NX14
Apex, this is just amazing. I built the mosfet version and just replaced the P250s with 40N60 IGBTs and the results were amazing. Little heating and very good sonics were the results. I couldn't believe it. It behaves well even with a 2 ohm load with 30Vx2 ac which produces 41.5V dc. Thanx man. I loved this version😀
F6 idea
FH11/FH9 OCB arrived!
For $2.50 each (all inclusive) I got 10 of these boards.
It will last a while until I can test it. The heat sinks are still on order.
P.S. Of course PCBs arrived! (No possibility to correct the headline!)
NX14? The only change was output devices?
Very interesting. Any measurements available?
FX10
hello Mile, i build the fx10 and have around 29v dc on output, rails voltage +/- 35 v, but if the 2 resistor (22k) connected to each emitter A837 & C4793, on output have around 2 mv dc. is it ok to change like this ? btw this amp have a good sound (for me) thanks
Usually the current source resistors (22K) would be connected to the power rails (+-40v here). I can see no benefit to the connection to the VAS shown in the design.
